Question about HP Office Equipment & Supplies
I have just bought C7280 - installed with my Mac - two problems - it keeps turning itself off (that is not the power but the printer) and second the scanner states that there is no scanning options when I try to scan to the computer. What to do?
  • Shadownova May 08, 2008
    i have a HP OfficeJet G55 All-In-One InkJet Printer, but when i try to scan something the message appears saying options not set, and i want to know how to set them
I HAVE IMAC 24'= 10.5. O.S. (1) I SEND A DOC. TO THE C7280 it says "PRINTER READY" Then after a few seconds the printer goes to 'PAUSE'?   I have uninstalled & reinstalled 2x.  Any suggestions? Thank you for your help. Marsha :) :) marshalovesgolf@gmail.com
Posted on May 28, 2008
Hp c7280 making a loud noise when preparation is occuring
Loud noise is not usual. But you may try the below mentioned steps to check if it can resolve the issue.
While the printer is ON, remove the ink cartridges.
Unplug the Power cord from back of the printer .
Wait for 30 seconds.
Plug in the power cord to the printer.
Install the ink cartridges.
If issue still persists, please call HP Tech Support as it could be a printer hardware issue.
Jul 09, 2014 | HP Photosmart C7280 Printer
Oxc18a0206 hp photosmart c7280
Unplug power cord from printer and electrical outlet wait 30 seconds and hold in help and OK buttons while reconnecting power cord. continue holding buttons until screen turns black turn printer on and continue this helped me.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Feb 13, 2013 | HP Photosmart C7280 Printer
I want to disable messages about the inkcartridges.
Sadly not. The HP Photosmart C7280 insists on having a full set of cartridges installed in order to print. It does this because the printheads are actually part of the printer itself and can sustain damage if they pull air into the printhead.
The out of date message is also non-negotiable I am sad to say.
Feb 05, 2013 | HP Photosmart C7280 Laser Printer
I have an HP Photosmart C7280. The printer will not turn on. Every time I try a blue screen comes up on the display and then all of the lights start flashing.
1. unplugged the power cord for 20 seconds (actually went a little longer)
2. Held down the # and 6 keys together and then plugged the power cord back in (still holding the keys).
3. held down # and 6 for about 10 more seconds after plugging the power cord back in and didn't get any messages but once and release them It was able to turn the power on.
The printer then printed an alignment page
hope it works, if so do rate the solution
Nov 28, 2010 | HP Photosmart C7280 Laser Printer
HP Photosmart C7280 color ink running out despite not using it?
  1. Unplug power cable while the printer is ON.
  2. Press and hold the '#' and '3' buttons, and plug the cable back into the printer.
  3. Continue holding the buttons down for 20 seconds, and then release it.
if doesn't initialize successfully repeat
on step 2 press and hold the '#' and '6' button and plug in the power cable.
May 13, 2010 | HP Photosmart C7280 Printer
Experiencing a problem with an HP Photosmart C7280 All-in-one printer, after the yellow ink cartridge was replaced a 'change the cartridge' screen comes up when trying to print, even though the printer...
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
You may also try this: Press and hold the '*' key on the key pad, then press the '#' key and release them both. Then enter '123' to enter maintenance mode. Then press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then press OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then power it off and back on.
May 11, 2010 | HP Photosmart C7280 Printer
HP Photosmart C7280 All-in-one has stopped printing. Window just keep saying Shutting Down What next?
Just unplug it, wait a few seconds, then plug it in again. That should fix the problem.
I had the same problem - my Photosmart C7280 AIO displayed "Shutting Down" message all night, and would not respond to any buttons on the control panel, even holding down the Power On/Off button got no response. I was worried about a couple of ink cartridges that it had warned were low before I tried to shut down, so I replaced those.
After looking in the manual and online for troubleshooting help from HP and others, and finding nothing but a suggestion to unplug it (not on an HP site), I finally did unplug it, after first disconnecting the USB cable to prevent any trouble due to interaction with my Mac. Then I aited about 30 seconds, plugged it back in, turned it on, and it started up fine, with no apparent problem.
Jan 13, 2010 | HP Photosmart C7280 Laser Printer
Internet explorer 7.0 keeps crashing after installing the hp photosmart c7280 printer. Please help. NEW pc. No problems until printer installed.
Please upgrade your IE 7 to IE 8, reinstall the HP software for your printer. IE 8 available from Microsoft at no charge.
I hope this works for you.
Jan 01, 2010 | HP Photosmart C7280 Printer
245 people viewed this question
Seeker5211
Seeker5211
