Question about Dryers
My Whirlpool Clean Touch electric dryer is not drying clothes very well. It is not getting real hot, and it takes two cycles to get most things dry. Towels and jeans take part of a third to dry. I clean the lint trap about every time I add a load. The lint trap is not full of lint, either. I am not overfilling it, it doesn't matter if it is a tiny load or not. I bought it from a reconditioned outlet about 8 months ago. I believe it was new or nearly new. There was not much wear on it. I have no manual.
  • hermitcrab Apr 18, 2008
    Solution above helped a bit, but this is apparently not the problem... I checked the duct in the back of the dryer. There was some blockage of the duct, from being too close to the wall. We cleaned it out and moved the dryer forward to prevent it from happening again. So, this did correct the worst of the recent trouble I have been having. However, it is not fixed. Loads are taking a full cycle (hour) plus another 30 or so minutes; which is back to what it used to be -- still too long. We are in Phoenix, AZ and have low humidity. Clothes would dry only a little slower if I hung them out. (...and I do with a few things, so I know how long it takes to air dry!)
    The lint trap is now filling up pretty evenly, and a little thicker covered. See, a month ago we did a bunch of cleaning in the laundry room to add a chest freezer. We scooted the dryer back a bit to get the freezer in. OOOOPPS.
    I've been doing some reading on the internet and am wondering if we need to replace the door seal? This is the only part that I can find that mentions trouble with the drying time... I looked at it, I cannot see an obvious tear, but given the symptoms ?????? Only other thought is to go get a dryer lint cleanout brush kit from Linens+Things.
    please help.
    Novelist:
  • 184 Answers
IF YOUR DRYER HEATS AT ALL, BUT WON'T DRY THE CLOTHES, 99 PERCENT OF THE TIME THERE IS A RESTRICTION IN THE AIR FLOW. PULL THE EXHAUST OFF OF THE BACK OF THE DRYER AND DRY ONE LOAD. IF IT DRIES O.K., THERE IS A RESTRICTION IN THE DUCT WORK.
CLEAN OUT THE LINT FROM THE DUCT WORK. IF THE DUCT WORK IS FLEXIBLE MATERIAL, REPLACE IT WITH RIGID 4 INCH METAL DUCT.
Posted on Apr 16, 2008
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
I have a whirlpool dryer and the heating eleiment is getting hot but the dryer inside is barley warm
Inside of the dryer gets warmed up when the drum rotates as there is circulation of air. Hope your clothes are drying. If it takes long time then clean the screen filter as it gets clogged with the flint from clothes. As a matter of routine clean this filter every time you use it before starting the drying process.
Sep 16, 2010 | Whirlpool LER4634J Electric Dryer
Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
Whirlpool dryer does not get hot enough to dry clothes.
Clean/repair the dryer vent. If the airflow is restricted the result is the one you just described.
Good luck,
Vlad
First Choice Appliance
Apr 20, 2010 | Roper REX4634KQ Electric Dryer
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
It takes atleast 2 full cycles to dry clothes.
you need to clean out your wall vent it is clogged and holding in the hot damp air that's why it's taking so long to dry,also check the dryer vent hole-mike
Feb 24, 2009 | Whirlpool LER4634J Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
1,088 people viewed this question
Top Dryers Experts
