Question about Sapphire RADEON X1950Pro 512MB Graphic Card
Radeon X1650 Hi psionics I've bought a less grunty card than I originally asked about. Now I'm having non-geek issues about installing it... I hope you will/can help. OK... I can get the hardwear into the AGP slot just fine, but get no blank monitor and can't install software. What happens if I disable integrated graphics card before I've installed the new one? Is that what I'm supposed to do? I haven't done this because I thought I would then not have a graphics display. I'm very confused, have never before thought of myself as a ditz, but I'm willing to reconsider :o)
  • Delphian Apr 17, 2008
    First one is a typo, sorry. Blank monitor, no post.
    Yes, booting from new card.
    There are no 'beeps' at all when I try to boot with new card in.
    Went back in and made sure new card was seated properly, all good there.
    Double checked cables etc, everyone where they should be.
    I gave the cards supplier my motherboard details and my requirements, so I'm assuming that it should be sweet with my computer.
    TIA Psionics
  • Delphian Apr 20, 2008
    Thanks for your help Psionics. Have taken the card back to the supplier, and they have confirmed that is is faulty. I not going mad (woot).
  • 236 Answers
before doing anything.. What do you mean you get no blank monitor? Do you see anything at all? Do you see the POST running? Also, when you put in the AGP, did you plug your monitor into the new card? Or are you trying to boot from the old intergrated one?
You can change your graphics input in the BIOS from integrated to AGP (after putting in the new card). But, It should pick it up fine without changing it. And if it doesn't work after doing so, your motherboard may keep the settings, and then a deeper problem arises..
Posted on Apr 17, 2008
  • 1 more comment
  • Dave MacPhee
    Dave MacPhee Apr 19, 2008
    have you tried booting with the monitor plugged into the default integrated card (with your new card installed)? Does the screen come on ok?
  • Dave MacPhee
    Also, if you go into the BIOS, and choose advanced menu, and then choose chipset, then choose AGP Bridge configuration. What is your Primary graphics adapter set to? And what is your AGP mode set to?
  • Dave MacPhee
    Dave MacPhee Apr 22, 2008
    Well, that's a good sign.. I thought I was going to go mad as well. Seemed odd that it didn't work.. At least we know why now.
    Have fun with your new card!
Graphics card overheat-Radeon X1650XT
u need to remove the graphic card, open the fan and the copper layer and change the thermal layer on the GPU then clean the fan and put little bit of non sticky oil on to it and fit it back properly ... ur issue would be fixed for sure :)
Jan 11, 2010 | ATI RADEON X1650 Xt, (256 MB) Graphic...
I installed a Radeon X1650 card and having problems
Try the old card & see what happens. If it still does it the monitor is bad. If not make sure to remove the old driver first & then install the new card. Then install the new driver. Should work,if not,then the card may be defective. ATI is kinda common to have a bad one right out of the box.
Jul 14, 2009 | ATI RADEON X1650 Graphic Card
ATI Radeon X1650 Pro overheats and videocard shuts down
check if the games take too much memory so that the card not able to work, if you used to play it before without problem, check the card fan if its working,and at the same time check your computer cooling if its cool enough.
Jun 14, 2009 | ATI RADEON X1650 Graphic Card
Someone Pls. help
You need to install drivers. go to ati.com and get current drivers.
Sep 23, 2008 | ATI RADEON X1650 Graphic Card
Picture break up with ATI Radeon x1650 pci
you already take some steps i hope,you try to warranty
regards
prasanna
Mar 04, 2008 | ATI RADEON X1650 Xt, (256 MB) Graphic...
The game stopped
Hello matbedui,
If you think the Radeon card is overheating you can check this by simply touching the card after it's been running for sometime. Some Radeon cards (high end) do have this problem. PC cases that do not have sufficient fresh air flow cause problems not just to video cards but to everything inside the case. The design of the HIS Radeon X1650 is less than sufficient. Keeping air flow contained. One way in & one way out. This issue is so important many companies creat sites to help you cool your card.
http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=196
Your Radeon X1650 Pro IceQ II runs ATI's chips. Installing the latest software is recomended. Download from here:
http://ati.amd.com/support/driver.html
Pick your OS. Than pick Radeon. Scroll down to your X1600 series. You can also update through HIS. Their software is twice the size of the ATI software.
http://www.hisdigital.com/html/driver.php?id=64
Feb 24, 2008 | HIS RADEON X1650 Pro IceQ II, (256 MB)...
Ati Radeon X1650 goes mad ....
Eeek its the card getting too hot and thus causing the wierd lines , due to dust build up , remove card & connectors , take off the heat sink , remove old thermal paste & apply new thermal paste (if necessary needs to be replaced if it looks dry and cracked) and remove the dust around it using a brush or compressed air.
Dec 09, 2007 | ATI RADEON X1650 Xt, (256 MB) Graphic...
Sapphire RADEON X1950Pro 512MB Graphic Card Logo
55 people viewed this question
Top Sapphire Computers & Internet Experts
John Hong
John Hong
Martin Clarke
Martin Clarke
dhnguyen
Are you a Sapphire Computer and Internet Expert? Answer questions, earn points and help others
