Question about Toshiba Televison & Video
Toshiba 32c3035d during viewing made 'pop' noise and sound went off cannot get it back
2 Suggested Answers
  • 128 Answers
SOURCE: Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Posted on Jan 19, 2006
likha
  • 790 Answers
SOURCE: I have a toshiba hd theare view tv. The other day
Hi
did you notice the standby light? or blinking lights? and how many blinks as you see?
Thanks!
Posted on Jul 08, 2009
I was watching my Toshiba 56mx195 DLP tv and heard a popping noise and the screen went blank but the sound was still on, is it the lamp or something worse?
You are correct in this assumption it is more than likely the lamp that blew after too many hours or getting to hot.
Apr 21, 2013 | Toshiba 56MX195 56" SDTV
Tv lost sound
i would take the speakers out, the amplifier my have went out, back there you will find them both hooked up to the amp un plug them and the ground or it will make a horrible popping noise.. hook it up to a home theater system (bought my toshiba rp with no sound for $50 did just that now i have an awesome tv. just trying to get rid of a glow around the white letters.
Oct 08, 2012 | Toshiba 57H81 57" Rear Projection...
My tv made a pop sound and went black. i can still hear sound and change channels but just no pic. it will also turn itself off after about a minute, then turn back on and so forth. got any suggestions?
Sorry to tell you that one of your tubes went. There is a projector bulb and that is probably what went. Is is still under warranty? Check out this link below for a PDF detailed manual for your item Check out pages 59 and 60 for warranty information. The second link is for Toshiba support page. Just copy and paste link into your browser.
http://www.tacp.toshiba.com/tacpassets-images/models/57h83/docs/57h83_om_e.pdf
http://www.tacp.toshiba.com/customersupport/
Hope this helps. Let me know if I can help you out with anything else.
JimmyC
Oct 03, 2009 | Toshiba 57H83 57" Rear Projection HDTV
Hi
Thanks!
Jul 08, 2009 | Toshiba 55H70 55" Rear Projection...
Tv went out after loud pop and has clicking noise does not turn on
If you have a Sony DLP, then the loud pop you heard is your lamp.  The lamps last approx. 4K-6K viewing hours.  Read your manual for replacement part number to reorder and very simple to replace yourself.
Apr 22, 2009 | Televison & Video
Toshiba HD made a popping sound and went out.
Check the lamp to see if it popped. Try replacing it. Also check the web for class action law suit for these sets, Toshiba has an extended warranty for lamps for certain units.
Feb 18, 2009 | Toshiba 43H70 43" Rear Projection...
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Tv went out, made a pop sound and won't turn back on
Sounds like the flyback went out. Your set is a CTC195 you can get a replacement flyback for it at the following link. They also provide free instalation instructions and free on line tech support.
http://servicemanuals.vstore.ca/
Apr 30, 2008 | RCA P56950 56" Rear Projection Television
My TV
The loud pop was the $300 bulb exploding. Don't look for any help from Toshiba either. Their customer service stinks as bad as their product. Put the bulb in yourself and then sell to the next ****** that comes along. I made the mistake of keeping mine, because I thought that Toshiba was still a good product. Wrong, next the color wheel went out. It was back ordered forever. When I finally got one I installed it myself. So, it would only cost me the $530 price of the part with out the $400 charge for labor. Run as fast as you can. I now have vertical lines on the screen after 2 weeks. Who knows what's wrong now.
Apr 26, 2008 | Toshiba 52HM95 52" HDTV Projection...
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
Televison & Video Logo
62 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
