Flickering picture hello i have a sony kv-hx32 m31 tv and just lately the picture starts flickering wildly for a period - could be a few minutes or 1/2 or more - and then all of a sudden stops flickering and is ok for a while until it out of the blue starts doing it again. have you any suggestions as to what the problem is and what i can do to fix it? thanks alan
  • albit Apr 17, 2008
    Hi Dan - thanks for your post - the model no is exactly as it is listed in the spec section of the operating instructions manual - on the front of the set it says Sony Trinitron Truesurround DRC-MF - does this help?
    I am in Australia if that makes a difference?
    Cheers
    Alan
  • 4,234 Answers
Can you please check the model number, what is listed is not valid for a Sony. This could be a simple fix or something expensive. With the model number, I can provide you with details.
Thanks,
Dan
Posted on Apr 16, 2008
  • ABRsvcs Apr 17, 2008
    Unfortunately, you being in Australia means that I don't have access to those manuals. I can get the US models and some European models. I'd first look for poor solder connections that get effected by the set heting up. Next try turnint up the screen control just a bit. This should be the upper control on the flyback transformer (part with large red wire coming out the top). If that resolves the problem, then the picture tube is starting to fail and turning up the screen control is only a temporary "fix" to buy you time to replace the set.
    Good luck,
    Dan
My KV-34HS420 periodically displays an orange screen, then shuts down. The red light on the front flashes 7 times. The weird thing is that this problem occurs during the day, but generally not late at...
hi,
check ur tv for any dry soldering of component leads in the power supply and horizontal output side. also replace the electrolytic capacitor in the B+ supply rail.
u have to check the picture tube base board also for any dry soldering of components, if so the first mentioned complaint ( orange screen) will erase.
ok
Dec 22, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
KV-HX32 SONY WEGA TV
The hight voltage transformer it dead.The FBT(The flyback transformer is dead)The block of plastic with the red wire with a cap hook to the CRT(the tv tube).
Aug 25, 2009 | Sony KV-32S45 32" TV
Sony kv-34hs429
The 6 blinks are a diagnostic code to indicate the problem circuit. I'm on the road at the moment, but will look up the code when I get to the shop. In the mean time, a few questions:
1) Does this occur all the time or just after or before a warmup period?
2) Have you noticed that this is occurring more frequently lately or did this just start?
Thanks,
Dan
Aug 07, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Vega Screen Goes Black and then back to normal picture
Hi There,
Does it seem to be staying black longer? Are there any unusual sounds associated with it?
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV-27V22 scrambled picture and loud buzzing audio
the variation from higher channels from lower channels, few things changes eg frequency, voltage, and current.
take your tv to a w/shop and have the following
tunner voltage pulse variation on a avo meter has you change channels. if the difference of voltage is not unform when you are changing from to channel then you should change the control ic on the rf stage or check the capacitors a round the rf ic for variations in value.
Mar 25, 2009 | Sony KV-27V22 TV
TV switch light flickers 11 times but no function
Hopefully it is only a board component that needs replacing and your dry joints that need re-doing. I would advise that you take it to a television repair shop as this type of repair can be very complex (replacing resistors and capacitors just to name a few).
Dec 03, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Blinking picture until warmup
On Sony TV's they monitor the current drain on all three electron guns Red Green and Blue. Until all are somewhat equal it will keep the CRT blank. As the set ages it means that it might flash a few times until the cathodes are good and warmed up.
Jan 28, 2007 | Sony KV-32V36 32" TV
Picture takes hours to appear
Spounds like the b+ feed filter capacitor off the flyback that supplys voltage to the three drive transistors on the crt board is bad.
Apr 16, 2006 | Sony KV-32V16 TV
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
Electro Med Services...
