Question about Apple iPhone Smartphone
Iphone locked up
My iphone locked up ! the screen wont work i cant turn it off it just shows the battery life on a dark screen
  • Apple Master
  • 13,433 Answers
Follow these steps
http://www.apple.com/support/iphone/troubleshooting/phone/
Posted on Apr 16, 2008
My iphone 5c stopped working suddenly, its screen darkened and it does not work. What is the problem?
Reset the phone:
  • Plug the charger into the phone.
  • Hold down the Home button while holding down the On/Off button.
  • Continue holding these down until (hopefully) the Apple displays on the screen.
Mar 08, 2015 | iPhone 5c Cell Phones
Tip
Apple iPhone Battery Saving Guide The Apple iPhone doesn't have the best battery...
The Apple iPhone doesn't have the best battery life in the world but if you follow this simple guide it should provide you with a longer battery life.
1. Turn down the brightness: You can reduce the battery consumption by turning down the brightness of the screen. Select Settings, Brightness, and then drag the slider to around the 25 percent mark, or as low as you can stand.
2. Turn Wi-Fi and Bluetooth off: From the main menu, tap Settings, Wi-Fiand select the "Off" switch. Same goes with Bluetooth; if you're notusing a Bluetooth headset, make sure the Bluetooth radio is deactivated(Settings, General, Bluetooth).
3. Check e-mail less frequently: If you are using Pop Mail then you can save battery by checking it less frequently. Select Settings, Mail, Auto-Check, and pick either the "every 30 minutes" or (better still) "every hour" options.
4. Sync less frequently: If you sync with an Exchange server either turn it to manual or set it only to check periodically
5. Make sure "Auto-Lock" is on: TheiPhone will keep its bright screen burning unless you manually pressthe lock/sleep control. If you haven't already, make sure the iPhone's"Auto-Lock" feature is on: tap Settings, General, Auto-Lock, and then pick a time interval (the shorter the better).
6. Turn off the equalizer: Apple has always suggested turning off the iPhone’s built-in equalizer to conserve battery life. Tap Settings, iPod, Equalizer, then spin the roulette wheel up to Off.
on Dec 23, 2009 | Cell Phones
Iphone 4 battery
If your iPhone battery gets low quick, try disabling features within your iPhone which may help increase battery life.
1. Decrease the screen brightness of your phone.
2. Turn off 3G when not in use ( 3G can decrease the battery life greatly )
3. Turn of Location Services in Settings. ( GPS can decrease bettery life greatly )
4. Turn off bluetooth.
5. Charge your iPhone up to 80% everytime and then stop charging. ( Studies show that charging up to 80% everytime can help increase the life span of your iPhone battery )
Feb 25, 2013 | Apple iPhone4 4G iPhone 4
MY IPHONE DIED AND NOW WONT TURN BACK ON
First check to make sure your charger is working, plug it up to the computer and see if the battery charging display comes up.
Second I would check to make sure the battery is actually charging.
Third try a cold boot, hold the power and home keys down while it boots it could just simply be locked up.
Jan 09, 2013 | Apple iPhone4 4G iPhone 4
My iphone wont turn on
Put it on the charger and let it sit there until the battery shows up on the screen. I had the same problem before too. Its probably just dead.
May 06, 2012 | Apple iPhone Smartphone
I have had my iphone less than a week- i did not expect it to have problems so soon. .... i have iphone 2g my battery ran out now it wont recharge or turn back on? .... but it doesn't turn on, it...
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
Jun 28, 2011 | BoxWave Corporation Apple iPhone 2G...
Iphone screen get dark in the middle of the conversation
Changing the auto lock setting will improve that.
  1. Click the settings icon.
  2. Click the general option.
  3. Press the auto lock option.
  4. Change the settings to your heart's desire.
The phone will dim 10 seconds before whatever the time amount selected is. For example, if you chose 60 seconds for autolock, in 50 seconds, it will start to dim.
Remember, changing that option to "Never" will drain your battery life much faster if you forget to lock your phone!
May 23, 2011 | Apple iPhone 3G
How can I improve my iPhone's battery life?
A recent research conducted on cellphones (smartphones) revealed that most of your battery life is drained by "Internet" and "calls". The more you use your phone for any of these two, the faster your battery drains. Next on the list is "Search for network" which consumes quite a bit of your battery power.
Smaller culprits are WiFi, Bluetooth, Screen brightness, themes, Vibration, etc.
* Reduce screen brightness to minimum
* turn off WiFi/3G/4G when not required (same with Bluetooth)
* if you are out of network area, turn off the mobile network so you cell doesn't keep searching for a network.
* If possible reduce internet usage on your cell phone to improve battery life (ie. if you have a laptop handy, use it!)
* Use a darker wallpaper
* Vibration takes up more battery than ringtones
* use a simple theme
* Dont keep your cell phone charging for long periods (eg. overnight)
* If you plan to buy a new battery, buy a branded authentic one
Hope this helped, thanks for using FixYa!
Apr 11, 2011 | Apple Cell Phones
I cant turn on my iphone, dark screen and stuck on the itunes sig
try to hold the home and power button and try 2 reboot it then wen u see the apple come on let both of them go
Feb 28, 2009 | Apple iPhone Smartphone
My iphone does not turn on
********************** SOLUTION!!!! **************************
If you just see an apple logo or your phone does not turn on, there is a software problem and you will need to restore your iPhone. I didn't want to hear it, because now I had to redo everything; but it's the only solution.
Put your iPhone into recovery mode.
To put your iPhone in recovery mode:
Step 1: Plug in your iPhone to your computer, make sure your sound is turned on and not muted.
Step 2: Hold the top corner button for two seconds. You should hear a sound.
Step 3: Now, still holding the top power button, immediately press the home button and hold both buttons for 10 seconds. You should hear another sound from your computer.
Step 4: Release the power button but *continue holding the home button*, for another 30 seconds.
Step 5: Meanwhile, continue holding the Home button and open iTunes. Wait for it to tell you that it’s in restore mode. You should also hear a third sound from your computer during this time.
Step 6: Click on your iPhone in iTunes. It should say it's in recovery mode and need to be restored. Step 7: Click OK and restore it.
Now you will need to re-jailbreak it, and restore your backup, and also put your music back in.
Good Luck!
Nov 29, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
299 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
