Question about LG WD-1080FD Front Load Washer
Lg wm1280fhd Spring loaded door catch
I have a new door handle cant remember how spring should be positioned on door.. can you help/
  • 9 more comments
  • Davina Jones
    Davina Jones Apr 28, 2008
    The door handle snapped. I have a new one but because it came apart as i unscrewed the door, i have no idea how to replace the door handle/catch-spring. The spring maintains a constant pressure on the metal catch that goes into machine porthole to lock it in place. The spring-catch and handle are in the door of the machine. Dee
  • Davina Jones
    I am in the uk, would that make a difference?
    Intello washer dd
    model number..WM1280fhd. Thanx Dee.
  • Davina Jones
    You have the same model number but as a washer dryer.. i.e
    WD-1280 fhd! looks the same? Dee
  • Davina Jones
    Davina Jones Apr 29, 2008
    Will do. Will get organised and take pics post them to you. Do you want pics of machine also or just handle , door and bits?
    Thanx Dee
  • Davina Jones
    Davina Jones May 01, 2008
    I don't seem to be able to send you pics , any tips? Dee
  • Davina Jones
    Hi , don't seem to be able to send you pics . any tips...? Dee
  • Davina Jones
    Perhaps you have an e-mail address i can send pics to?? i know how to do that! dee
  • Davina Jones
    Hey CoolTech,
    I did it!......5 minutes peace and quiet and i solved it.
    I could not work out how to get the tension on the spring, but that tension happens when the rest of the door is replaced! Thanx so much for your interest though.
    Regards Dee... Happy For Now!!
  • Davina Jones
    Hey CoolTech, I solved it!!.... 5minutes peace and quiet, and i did it.
    Couldn't work out how to get the spring to tension on the door catch, that happens when you replace the rest of the door!!
    Thanx so much for your intrest though would have still been sitting here waiting for a solution if you had not asked for photos! thanx.....Dee x
  • Davina Jones
    Davina Jones May 02, 2008
    Ha Ha!! you too, once again thanx. Dee
  • Richard Lew May 11, 2010
    Explain what the problem was that required you to replace this part.
    Also, which part are you talking about??  The door handle or the door catch or the door latch??
  • 489 Answers
Dee,
This one is hard because I don't have any information about your model #.  Are you sure the model # is correct??
Posted on Apr 28, 2008
  • 1 more comment
  • Richard Lew Apr 29, 2008
    Dee,  I can't find the model number listed with LG.  But I'm not ready to give up just yet.  Can you send me pics of what you have??  I will try and work with you that way.
    Just the new handle and parts and the door where the handle is supposed to go into.
  • Richard Lew May 02, 2008
    I'm glad that you were able to resolve the issue.  I had faith that you could do it!!!  Now I can go to sleep peacefully tonight knowing that you can finally have clean clothes once again.  ;)
    Take care and have a great weekend.
I bought a new handle for my washer WFS1073DD but i cant work out how the spring goes on to connect the handle.. PLEASE HELP!!
Its hard to describe how the spring sits, but you have to remember that the catch must be in tension so that it always engages in the lock. there is only one way that it will do this, so im afraid its going to need a lot of patience and trial and error.
if you go to the e-spares website, there maybe a video tutorial.
May 29, 2014 | Washing Machines
Servis easi logic 1500
the doors can be dismantled and a new handle fitted. if you go to google. type in the make, model and end it with spares, it should come up with companies that supply parts. in the uk i use espares.
changing it can be fiddly but take pictures as you strip the door down so you get the pin, catch, handle and retaining spring in the right positions
May 01, 2014 | Washing Machines
Door handle broke
This is not an identical one but is another LG that has the same latch setup. Hope these pics help.
Mar 07, 2012 | LG WD-16115FD Front Load Washer
Its cold and the door was frozen stuck. But after unlocking it, I pried it open and when I got in the drivers seat to close the door. The latch is stuck in the down position and the door wont close or...
spray the latch catch with oil or silicone to loosen the latch mechanism than stick something [a screwdriver/ pen ] that u can use to push the catch upward to open push on catch while lifting handle if catch falls back either latch spring still frozen or latch spring broken and needs replacement
Jan 11, 2011 | GMC Yukon XL Cars & Trucks
Door handles slack feels like springs dropped so cant open door
You can release the catch from inside just keep trying and thern you need to replace the door catch itself this is a simple job
Jun 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Drivers side door will not catch when door is closed it will just bounce away. the door handle does not seem to be as spring loaded as passenger side thanks
Look on the end of the door and you will see the slot where the door catch is located. It should line up with a big stud sticking out from the post by the drivers seat. The gap should be open. If you see a piece of steel blocking the slot, then the door catch is already in the latched position. Insert a screwdriver into the bottom of that catch and pull it up into the open position. If that is the problem, the door will work after that. Hope that helps
Jan 01, 2010 | 1990 Buick Reatta
Cant get oven door back on
Oven doors are made to lift off for routine maintenance but there might be problems if the spring load hinges are not disabled before pulling the door off the body.
There should be a catch which holds the hinge in the open position but if it is the release position (i.e. the state in which it is in for normal use), the I would expect the hinges to snap into the closed position when the door is removed from the body.
To rectify this, hold each spring loaded arm in the position it would be in the "door open" position and move the catch into the position which prevents the arm springing back when they are released.
It should now be possible to fit the door to the cooker.
When the door is fitted, release the catches.
Dec 17, 2009 | Whirlpool RF3020 Electric Kitchen Range
Hotpoint aquarius 1000wm 20 I have to bash front door to start
I do not think it is the door lock that is faulty, more likely to be a weak or broken door spring or broken door catch.
I would replace these first,and then if it is still the same, then replace the door lock.
To replace the spring and or handle catch, undo all the screws that secure the 2 halves of the door, and prize apart the 2 halves,
Replace the spring and catch, reassemble the door.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
How do I get the rear ring clamp with the spring back on the front door seal. I took it of ok and have changed the seal but I cant seem to get the spring to strentch enough Thanks Mark LG wd 8013f front...
It takes another set of hands to stretch and hold the spring in place at the 3 and 9 o'clock positions. With the spring held in place in this manner, pull the remaining portion of the spring straight down at the 6 o'clock position with one hand and hold it while working the rest of the spring into the groove with the other hand. This is the toughest part of replacing these door seals, but it works better with two people. Please let me know if you need further assistance. I hope this helps you.
Jul 11, 2008 | LG Washing Machines
How to replace new door handle
Why can no-one supply a photo. Even with the last set of instructions there are still a lot of assumptions, e.g. which way is the handle pointing when it is face down!
Mar 10, 2008 | Indesit W 123 Front Load Washer
LG WD-1080FD Front Load Washer Logo
699 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
