Question about Symbol MC9060 Portable Terminal
Screen the screen is constantly scrolling.Hard reset etc make no difference
Unit needs to be serviced. Display replacement is required. I know of no known fix for this problem
Posted on Apr 16, 2008
Hard reset zte n817
1: Power off phone
2: Hold volume DOWN (not up) and POWER BUTTON simultaneously until ZTE logo appears
3: With volume keys scroll down to wipe data/Factory reset press POWER button to accept
4: Scroll down to YES press POWER button to accept
5: Press POWER button on Reboot Phone and phone should restart like right out of the box
Many forums say volume up and power button but that is only for FTM mode on ZTE N817. So remember VOLUME DOWN AND POWER takes you to screen where u can choose to reset etc.
Dec 06, 2015 | ZTE Cell Phones
My hand held connot hotsync with my P.C. A message comes up that there is a problem and the program has to close. I un installed the program and re installed it and the program continues. I have had...
This can be a problem between the connection of the PDA to the PC that's why the software cannot synch them so first thing that you can do is toi make sure that computer and pda are communicating fine if possible try a different cable to connect them, then if still have the same problem, best way is to use a different computer to sync your pda...
Hope that helps..........
Sep 04, 2008 | Computers & Internet
Screen keeps scrolling left
Sounds like a key on the keyboard is stuck. unplug the keyboard and see if the problem stops. If it does, then replace the keyboard. If it does not stop, try restarting the Mac using a different keyboard.
Nov 13, 2013 | Apple Computers & Internet
possible bad mouse/trackpad - try unplugging the usb cable and see if that stops it; if so replace the device - can also try plugging it into a different usb port.
Alternate diagnosis - maybe some other device is causing the problem' try unplugging all devices (
NOTE if bluetooth device try turning off bluetooth
Mitsubishi 62725 lines scrolling in picture
Try first a DVD etc connected to a rear audio and video input, that may rule some things in or out.
Set does have a soft reset but it is unlikely to help for this issue
Dec 23, 2012 | Televison & Video
Droid Eris phone only works now when plugged in. hangs up during phone calls. screen is displaced, can't scroll.....
Try to backup your data (messages, contacts, etc.) and software you downloaded or installed first. Then try to soft factory reset. It is on the settings->privacy. or try hard factory reset. turn off your Eris. Hold the volume down key, send, and end. Press trackball to agree to reset.
Mar 09, 2011 | HTC Droid Eris by
I want to reset the LG shine 720
Hello thanks for using FixYa
To hard
reset of
your cell
Type 1809#*500# & select reset option which restores the factory settings.
A confirmation screen will appear, select Yes. It it asks security code then enter 0000 it will take some time and your handset will be restored to original settings.
or try this
to Reset Default
From the standby screen, press Menu
Scroll to and select Settings
Scroll to and select Reset Settings
Scroll to and select Master Reset
Your problem will be solved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Jan 30, 2011 | LG Shine 720 Cellular Phone
Need a phone reset
Part 1
Soft Reset
A soft reset tells your handheld to stop what it's doing and start over again. All records and entries stored in your handheld are retained with a soft reset. After a soft reset, the Welcome screen appears, followed by the General Preferences screen.
Use the reset tip tool (see below), or the tip of an unfolded paper clip (or similar object without a sharp tip), to gently press the reset button inside the hole on the back panel of your handheld.
Reset Tip Tool: On most PalmOS handhelds, the stylus that comes with your handheld has a reset tip inside. To use it, unscrew the barrel from the stylus quill.
Double-Soft Reset
If your device doesn't seem to want to power up after a soft reset, and you've checked the other obvious solutions (fresh batteries, power button, contrast wheel, contrast button) you may want to try the 'Double-Soft Reset'. Simply perform a soft reset as directed above, but press the reset button twice in quick succession.
Warm Reset
A warm reset bypasses any system extensions (such as HackMaster hacks, OS patches, Alarm settings, etc) that are loaded on your handheld. Sometimes a damaged third-party application will try to respond to a reset but will fail and cause the handheld to 'hang'. Using a warm reset, you can start the handheld, then delete the damaged application before it has a chance to try to run again. After deleting the application, follow with a soft reset to start up the handheld normally.
To perform a warm reset:
  1. Press and hold the upper half of the scroll button on your handheld.
  2. Using the reset tip tool (or a similar object without a sharp tip), gently press the reset button inside the hole on the back panel of your handheld.
  3. When the Palm Computing Platform logo appears on the screen, release the scroll button.
If you're not sure which application is damaged, you can use a tool like ResetEmu in conjunction with a warm reset to help pinpoint the offending application.
Hard Reset
With a hard reset, all records and entries stored in your handheld are erased, except for the default or specimen databases predefined by the manufacturer (but see Extended Hard Reset below). Formats Preferences and other settings are restored to their factory default settings. You can restore any data previously synchronized with your computer during the next HotSync operation. If you're running OS 3.1 or earlier, and you're not using a third-party backup utility like BackupBuddy, you may need to reinstall your third-party applications.
Never perform a hard reset unless a soft or warm reset does not solve your problem.
To perform a hard reset:
  1. Hold down the power button on the front panel of the handheld.
  2. While holding down the power button, use the reset tip tool (or similar object without a sharp tip), to gently press the reset button inside the hole on the back panel of your handheld.
  3. Release the reset button.
  4. When the logo screen appears on the screen, release the power button.
  5. When the message appears on the handheld screen warning that you are about to erase all the data stored on your handheld, press the upper half of the scroll button on the front panel of the handheld to complete the hard reset and display the Digitizer screen.
Pressing any other button instead of the upper half of the scroll button will perform a soft reset.
Extended Hard Reset
An Extended Hard Reset will completely erase your handheld, and will also bypass the creation of some default databases.
This differs from a normal hard reset, which will automatically create the databases for the built-in applications, and will insert some specimen records into those databases: numbers for Accessories and Technical Support will be created in your Address database, a registration reminder will be created in your ToDo database, and several helpful memos will be created in your Memo database.
In addition, a normal hard reset will also create a Network database with some default Network profiles for your Network panel in Prefs, and a file of several default MIDI alarm sounds will be created.
If you have the Notepad application, a normal hard reset ensures a sample note will appear on your NotePad, and if you have the Mail application, an email message from 'Mail Help' will be automatically inserted in your handheld Inbox.
An Extended Hard Reset will ensure that all of these startup files are not created.
If you decide to perform an Extended Hard Reset and install one or more third-party applications that expect to see the built-in databases present, you may encounter an error. For this reason, it's suggested that after an Extended Hard Reset, you run each of the built-in applications (Datebook, Address, ToDo, Memo, and if installed, NotePad and Mail) at least once to ensure empty built-in databases are created.
After an Extended Hard Reset, you will not be able to select alternate alarm sounds for Datebook alarms, but the default alarm sound will still be heard for appointments with alarms set.
To perform an Extended Hard Reset:
  5. When the message appears on the handheld screen warning that you are about to erase all the data stored on your handheld, press and hold the upper half of the scroll button on the front panel of the handheld.
  6. While still holding down the scroll button, press, in any order, the Datebook button, the Address button, the ToDo button, and the Note/Memo button.
  7. Release the scroll button, to to complete the hard reset and display the Digitizer screen.
Pressing some but not all the buttons while holding the scroll key will result in a normal soft reset. Pressing no buttons while holding the scroll key will result in a normal hard reset.
Feb 18, 2009 | Palm Treo 650 Handheld
BlackBerry 8700c Hang-up
Try to take the battery first and leave it for 3 hours and put it back again,and try to check if the screen respond in tapping if still not working then do some reset procedure...
Soft Reset
Use the reset tip tool (see below), or the tip of an unfolded paper clip (or similar object without a sharp tip), to gently press the reset button inside the hole on the back panel of your palm handheld.
Double-Soft Reset
Warm Reset
Hard Reset
Extended Hard Reset
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Sep 04, 2008 | RIM BlackBerry 8700g Smartphone
Symbol MC9060 Portable Terminal Logo
177 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
