Question about Canon PowerShot A95 Digital Camera
Help how do you "reset" a cam?
  • 983 Answers
There will be reset option in the menu options refer to the manual .....
Posted on Apr 16, 2008
How to reset 9971 cisco phone to factory default
You can do that by pressing the Applications button on the phone and choosing Administrator Settings. From the Administrator Settings menu, unlock phone options, then choose Reset Settings > All Settings.
I hope this helped you.
Oct 06, 2011 | Cisco Unified IP Phone 9971-Charcoal...
My cam BULZER 16MEGA PIXEL is showing white screen.plz respond soon
The cam could have hung up because there are errors within the software. So to reset remove the battery and keep aside. Allow about half an hour for the residual voltage to fall off the circuit so as to reset. Press down the power /play/rec switch. Now replace the battery and switch on . If the cam hangs up then it is confirmed that there are errors within and need a serious check . Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Jul 01, 2011 | Video Cameras
I cannot record, in the corner where it says record, standby, it flashes the number C:31:40 I have a new TDK Hi 8 120 and it keeps flashing. Please help, thank cptaylor2000@yahoo.com
when problem occur while cam is operating, the self-diagnosis function starts working, and may display the service mode display code. in your case, C:31:40, pertains to a part of the cam tape compartment mechanism called the drum that doesn't start up. issues could prevent you from recording, playing back tapes, rewinding or fas forwarding. t/s steps are: try diff tapes esp. w/prev recordings, reset cam (press reset button while cam is on, located just below the menu button, in the panel where the lcd screen goes to), power reset (remove batt and ac adapter and leave cam w/ any power source for at least a minute). if issue persists, unit will require repair. hope this helps.tnx:)
Jul 21, 2010 | Sony Handycam DCR-TRV340 Digital Camcorder
Replace the cam sensor under the timing belt cover. Have not yet reset code. Will engine continue to run poorly until the code is reset or should the new cam sensor take effect prior to resetting?
Hello! The new Cam Sensor will take effect immediately...However, many people are convinced that "only one thing is wrong" when troubleshooting...Be aware that the Cam sensor could have been defective and there is still a problem...
Guru..............Saailer
Jul 02, 2010 | Cars & Trucks
How do i set cam position and timing on an old yamaha xt 500
You didn't say WHY the cam / valve timing needs to be reset. For some reason I get the feeling someone told you that resetting was needed and so you are asking how. Obviously, you may have installed new pistons and that is why the resetting is needed. In either event, when the cam timing is set the valve timing is also set. Other than adjusting valve lash, setting the cam sets the valve timing. Below is a web site where you can do a free download of a factory service manual. The process is not hard but having a manual will be more help and faster help than I can give online.
http://www.carlsalter.com/motorcycle-manuals.asp
May 25, 2010 | 1997 Yamaha XT 600 E
SONY VAIO PCG-TR3AP1 WEB CAM PROBLEM
If you will turn your VAIO upside down you will see reset button. You can press that with pin,. This will reset camera. Reinstall camera drivers after reset and camera should work.
Apr 09, 2009 | Sony VAIO PCG-TR3AP1 Notebook
Evesham 6200 nav-cam. Will not turn on! Just a blank screen, top left LED works when charging and when conected to the computer. Have tried hardware and software reset nothing happens.
Evesham Nav-Cam 6200 turns on then sticks at the front page
( navigator, MP3 Photo, Setup) and won't go any further, tried
hard and soft reset but nothing happens. can you help.
Jul 13, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Nav-cam 7000 Can't start
After you click on each of the corners, you have to tap the center twice. I believe you get a message that tell you that. You just need to read it :-) Once you tap it twice it "accepts" the adjustments and boots up.
Jan 06, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Canon PowerShot A95 Digital Camera Logo
69 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
