Hello All, I am an opensuse 10.3 laptop user with a PHILIPS CDRW/DVD SCB5265 dvd rom. I had downloaded opensuse 10.3, burned it onto a dvd and installed the same on my laptop.
My dvds were being mounted perfectly until a week ago when they stopped working. I also can no longer boot from my dvd. I dont seem to have any problems with other audio or data cds. They get mounted automatically. I did a little research on this topic and found that the kernel needs to support UDF in order to read/write dvd drives. However, the kernel that i am using is 2.6.22 and from the documentation, it seems that it does support UDF 2.0x and downwards (while the dvdrom , it says used UDF 1.02 with an ISO9660 bridge , implying that it should support the same. ref: http://en.wikipedia.org/wiki/Universal_Disk_Format).
I also read that if you have a SATA hdd (which I do, 160 GB)then activating SCSI CDROM in the kernel can solve the problem. (Could this be the solution as the laptop doesn't even boot from the dvd rom??)But I am unaware of the procedure and would not want to mess with the kernel without any prior knowledge.
Also, will the re-installation of the dvdrom drivers provide an easier workaround. Something like rebuilding those modules??? But I need help as I don't know how to do any of these. I'm just shooting bullets to make it easier for you rather than complicate or confuse which I truly hope it doesn't.
Maybe if we could 1. Query the kernel to find out what version of UDF is supported. Then check if it matches the requirement. However,I suspect that even though UDF 1.02 might be supported, doesn't it alsohave to support ISO9660 bridge as required by the document athttp://en.wikipedia.org/wiki/Universal_Disk_Format.
Please remember that everything was working fine until a week ago. Maybe some update might have changed some settings.. I dont have a backup of those settings so cannot revert back to that state.
Please help me as I am in dire need of it.
Expecting your co-operation.
With Regards Shastha Email: shastha@aol.in Ph: +91-9833076772
Since the drive worked properly a week ago, why don't we try to roll back the driver as you suggested an update may be the culprit?
You can do this by right clicking on "My Computer" and selecting Properties, then under the Hardware tab you'll find "Device Manager" and click on that button, once device manager is open find for your CDRW drive in the list under Disk drives and right click on it selecting it's properties, then under the driver tab click on the "Roll back driver" driver button towards the bottom left (should be the third button), and see if rolling back the driver reverts your system to a state where everything works again.
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area...
(More)
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area but
Windows always used to fit to my laptop screen. The other day I had hooked it up to a Desktop...
(More)
Windows always used to fit to my laptop screen. The other day I had hooked it up to a Desktop montior. I hit Fn F7 or F8 to get it back to laptop screen but now the windows screen does not fit the laptop screen. It show on my laptop screen how it would on the bigger Monitor. If i want to see the time I have to drag my mouse down and the whole screen moves down. But not like scrolling, the whole screen moves. Its really bothering me because I can't get the picture to fit the screen again. I tried everything that I know but still nothing. I even plugged monitor back in and switch to it and back to laptop and unplugged and still nothing. Please Help.
I have verizon Fios, I can't keep connected to the router. Is there a program that I can download to...
(More)
I have verizon Fios, I can't keep connected to the router. Is there a program that I can download to for my router?
