Question about Compaq FS 7550 17" CRT Monitor
Monitor problem.... i've compaq monitor...the problem is the monitor has the OSD display but when i connect the vga cable to desktop the display blank after a few second...voltage for b+ also decreasing from 128v to 48v...all capasitor checked already and in the good condition...the resistor and diode also checked.so could you please help me... i've already try to repair this monitor for about 1 week...please....
  • 40 Answers
Please provide some more information ( like when u plug in /on your monitor is it showing some raster or u feel the crt is charging or not?) any way after reading the information u provided it seems that your monitor is remaining in standby mode , possible reasons for this problem are the following:-
1. monitor is not sensing video signal.
2. monitor's microprocessor is faulty (remains in standby mode)
3. monitor's memory chip is faulty.
mail me ur response @ vishwas_4u@rediffmail.com
Posted on Apr 16, 2008
COMPAQ W17Q MONITOR CANNOT UNLOCK OSD
Here is the link to the monitor manual:
http://h10032.www1.hp.com/ctg/Manual/c00881436.pdf
If you can operate the OSD menu, try resetting.
I have noticed in the past that Compaq products have proprietary wiring schemes for their cabling. If you are using a VGA/SVGA cable (D-Sub) make sure that all the pins are present and wired. A pass through type cable will ensure that this is done.
Dec 08, 2013 | Samsung SyncMaster 713BM 17" LCD Monitor
My hp compaq dc5000 sff working but display not showing
Check the VGA cable's connections.(cable running from the CPU into the Monitor]. Remove it and plug it again into the machine.If still can't display,test your monitor on another machine and observe.If its working,replace the VGA cable on your machine.
Hope this helps.Thanks!
Jan 04, 2012 | HP Computers & Internet
Compaq Presario SR1750NX wouldnt come on, installed dynex 400 watt atx power supply now it comes on & fan runs but monitor is still blank. Installed ATI RADEON 7000 GRAPHICS CARD, still nothing, the...
After adding new graphics card monitor display will not work with motherboard display connector.
So, connect your monitor VGA cable with your graphics card display port.
Thanks for using FixYa.
May 22, 2011 | Computers & Internet
Hi! I want to remove the OSD attention from my monitor. How do I manage this? It's necessary to me remove this attention pop out.
OSD popup no signal If you are getting a message that says something like"Check cables" "no signal detected" or something like that,it is likely that your monitor is operating correctly. I would suggestchecking your cables, make sure that the computer is turned on, and if thatdoesn't help, check if your monitor has VGA, DVI, or HDMI inputs. I amthinking that your monitor may be trying to display from the wrong source. This is what a VGA (analog) cable looks like. VGA cables aretypically blue.tgvern_4.jpg
Another common connection that is used is a digital HDMI (left) or DVI(right) connection. DVI cables often have white endconnectors. How your PC connects to your monitor will determine thesource mode you want to use on your monitor. (Obviously this is the cableview but the connection on the monitor itself will look similar.) tgvern_5.jpg
If none of these tips helps, I would suggest hooking the same monitor up to adifferent PC or laptop, and trying once again to get a the display working. Again, make sure that the connection matches the source setting on yourmonitor. If it works on another PC, then your computer may have a videoproblem.
Otherwise, if it still does not work your monitor have a problem displaying viathat connection. If possible I would suggest switching to a differenttype of cable and re-try the above steps.
Mar 20, 2011 | AOC FOVI F19S Monitor
My computer turns on but the screen remains black. What should I do?
The problem can be solved by these steps
1) Check the Video connector properly connected to PC
2) Monitor power supply cable fault
3) The VGA card is not working properly
4) The screen resolution is set to higher than the monitor supported resolution limit
The Best way to solve it replace monitor and see it is working properly
In case the monitor still stay blank you should check the VGA card
Try to start cmos setup and see whether the monitor still remains blank then it's VGA problem
Feb 07, 2011 | Compaq Computers & Internet
My monitor is showing osd locked? what to do
If you disconnect the monitor signal cable and power the screen down, it should auto select VGA next time you power it up. In my experience flatscreens default to VGA to the extent that you can't persuade them to accept a DVI cable instead once they've been powered up with a VGA cable.
You should also be able to access the monitor setup OSD, even with no connection to the computer.
Jan 11, 2011 | AOC F22 Monitor
LCD Monitor Blank/Non-Responsive - Dell E173FPC
Next thing I would check is the VGA cable between PC and monitor.
Make sure is in at both ends and if possible try another one.
Do the Dell Menus come up with no VGA cable plugged in? Is the light amber? Flashing or static?
Mar 18, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
I've fried my monitor - Won't power on
It will be almost impossible to find these components unless you are in Taiwan.
Feb 15, 2009 | LG Flatron 795FT Plus Monitor
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
Check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Feb 05, 2007 | IBM E74 17" CRT Monitor
Compaq FS 7550 17" CRT Monitor Logo
79 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
