Question about Hifonics Brutus BX 1605D Car Audio Amplifier
No output my amp powers up and everything, however there power light and the protection light wont turn on, usually its either one turns on. also there is no output to my subs. i have a hifonics bx1605d
  • jar0440 Dec 30, 2008
    i have the same problem with a hifonics 1206d amp. i have the blue lights lit up on top of the amp but no green or red LED light turns on. please help.
Maybe you should check your remote wire!
Posted on Jun 05, 2008
Its in protect mode and wont go back to normal
disconnect everything except the power, remote, and ground. turn off then on. if it goes into protect mode then there's a posibility that the amp if fried. check all the speaker inputs and outputs to make sure that there are no stray wires shorting out. if it stays on then you may have a short on a speaker wire or an auxilary input wire. plug each one in one at a time until it goes into protect mode, then that's the shorted wire or it could be a shorted speaker.
Aug 09, 2010 | Nitro BMW-486 Car Audio Amplifier
My amplifier turned off while playing and wont turn on at all now
Hello, it sounds like you shorted the outputs of your amp or the power supply mosfets shorted. Very common when people have the music at a loud volume. Does the protect light come on? If not then the power supply is probably shorted not letting the protect circuit get any voltage. Some amps do this and other amps if the power supply shorts have the protect cicuit built in such a way that if the power supply shorts out the protect circuit still works. Cause you checked all wiring and redid it and no fuses blew then this is your problem. I repair amps everyday for a living. ?Most of my out of state customers are from fixya.com. I'm the cheapest amp repair business you'll find. If interested send me a private message letting me know what kind of amp it is, name and model number, and i'll get you back up and running with warranty.
Aug 23, 2009 | Car Audio & Video
Red protection light wont turn 2 green no matter what so the amp wont work
Hello mcis43fan,
The protection circuit can be activated by shorted or grounded wiring or it can be caused by a defect in the amp itself.
First, disconnect all wires except power, ground and the remote turn-on lead and see if the amp powers up normally. If it still goes into protection, the amp is defective, most likely shorted outputs and needs repair or replacement. If the amp powers up normally, test the other wiring for shorts and grounds. You can reconnect them one at a time to determine which one is causing the problem.
Hope this helps.
Aug 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Mxa422 protection
Outputs are fried. Try disconnecting your speakers and see if it still goes into protection mode. If it does then you A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
May 24, 2009 | Lanzar MXA422 Car Audio Amplifier
I have an older red sony xplod 500w 4ch amp. the power/protection light is glowing red. what does that mean and how do i fix it? I have no sound.
The protection light comes on if the amp overheats or if the speaker outputs are shorted.
Turn everything off and check all of your speaker wires for shorts. When you locate and repair the short, the protection light should go out and your amp will work normally again.
Hope this helps!
Mar 26, 2009 | Car Audio & Video
Power light kicks on then off when I turn on the stereo
The amplifier likely has shorted output transistors. To confirm that it's not some other fault, go to the following page. It will guide you through the troubleshooting.
Troubleshooting - Amp Going into Protect
Let me know if you have any other questions.
Jul 20, 2008 | Pioneer GM-5300T Car Audio Amplifier
Protection light is on
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 26, 2007 | Kicker KX600.1 Car Audio Amplifier
Amp in protection mode
Disconnect all speaker wires and signal cables from the amp. If it powers up normally (doesn't go into protection), the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 11, 2007 | AudioBahn A4401Q Car Audio Amplifier
Amplifier wont turn on.
Generally, when an amplifier goes into protection when you attempt to power it up, it means that the output transistors have failed.
Measure the DC voltage across the B+ and ground terminals as well as across remote and ground. If you have less than 11 volts when the amp tries to power up, the amp could be shutting down due to low voltage.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Oct 25, 2007 | Kicker ZX10001 Car Audio Amplifier
Hifonics Brutus BX 1605D Car Audio Amplifier Logo
315 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
