Question about Canon T70 35mm SLR Camera
Is our Canon T70 dead?
Powers on, wont load film, beeps constantly, Can't select a mode, iso or anything. Shows film and battery bars only. Batteries are charged, spool is clear. Can anyone help please????
  • 1 more comment
  • AndieK Jun 08, 2008
    I'm having exactly the same problem - my T70 just beeps constantly! I've tried changing the batteries and the film, but it didn't help. Anybody have any ideas?
  • josephkemple Oct 08, 2008
    Same thing, T70 worked beautifully until I changed the batteries. Now it only beeps! Someone please help,
    josephkemple@gmail.com
  • awskytiger Jan 17, 2009
    I have the same problem with My T70 as others have described. NO LCD and for a while it just bleeped when switched on. I understand that the T70 has an internal battery that can only be changed by a service agent. This may be the problem.
  • 60 Answers
It sounds like the motor is locked up. The gears under the bottom of the camera may have gotten sluggish from dried out lubrication. You can take the bottom off to see if the gears are able to turn freely or check with a local camera repair shop.
CameraRepairs
Posted on Aug 11, 2008
2 Suggested Answers
SOURCE: Powers on, wont load film, beeps constantly, Can't select a mode,
I had a similar problem today with my camera. I'm not an expert on Cannon cameras or any cameras for that matter, but this is what I did to fix the problem.
I removed the bottom cover(has 6 screws i believe) carefully sliding the cover up starting near the battery cover. Holding the camera still I checked what gears I could to make sure they were free, but one small gear that moves up and down was stuck. I applied a very small amount of force to the gear to free it, reattached the cover and all the screws, and BAM! I was back to taking pictures.
Hopes this helps.
p.s if you can't find one of the screws its under the battery cover flap :).
Posted on Jul 22, 2010
Canon AF35mm 2 (Quartz Date) Film Camera, How to set Date?
Go into the camera menu, it should have a section called Initial setup or something like that.
Jun 27, 2017 | Canon Sure Shot 80 Tele/Date 35mm Point...
Canon EOS 300x battery problem: it doesn't work, even with fresh batteries. The LCD battery indicator blinks as they we're dead.
First make sure the batteries are in the correct position/orientation clean both battery terminal and look down inside the battery compartment make sure the "lower" connection is clean (shinny) if not you may need to use a pencil eraser with a piece of sandpaper affixed to it to get down in there and scrub off the corrosion. Another thing and I've run into this myself on a Canon Elan IIe was the battery indicator showed new batteries as dead but the camera attempted too function so, I just used it and used it and withing a few minutes the battery indicator showed the battery state of charge more accurately.
Mar 04, 2011 | Canon Photography
Hopes this helps.
Apr 07, 2010 | Canon T70 35mm SLR Camera
My battery bars blink and make a sound every time i put batteries in it. it won't load the film. what's the problem?
A blinking battery bar indicates that the camera thinks the batteries are nearly discharged. If you're using fresh batteries, check and make sure that the battery contacts, both on the battery cover and down inside the camera are clean and shiny -- no corrosion. Clean them if necessary and try new batteries again. If you still have flashing battery bars, there may be something wrong in the internals.
Feb 05, 2010 | Canon T70 35mm SLR Camera
Need the sleve that cover the battries
According to the pictures I see in the T70 manual, there is no sleeve required. It shows two AA batteries in the battery compartment, but no sleeve. Try just placing the batteries (properly oriented) into the well and closing the cover, and see if the camera powers on OK. You should be fine using it that way.
Film won't load.
check batteries, if they are old substitute with known good batteries. One of batteries may be problem test individually under load test! . good luck
Aug 27, 2009 | Canon T70 35mm SLR Camera
Film won't load...
Check for batteries, film pressure plate on the back door of the camera, film leader and perforations ,freeness of the spool of the film cartridge,.
Apr 02, 2008 | Canon T70 35mm SLR Camera
Canon T70 35 MM SLR Camera
It sounds like your camera is having problems advancing your film, which could mean it is jammed inside the camera. The other thing you should check is to see if the battery is weak & doesn't have enough power to advance the film (and thus the beeping). If it is not the battery, then go in a darkroom (completely dark) and take out the film (if you're unable to rewind it inside the camera). Look at the transport rollers (in the back for the camera) and make sure they're clean (sometimes film chips get jammed in there) Let me know if this helps you. Thanks.
Sep 11, 2007 | Canon T70 35mm SLR Camera
Canon T70 35mm SLR Camera Logo
1,174 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
