Question about Saeco Incanto Classic Espresso Machine
How can I return machine back to default settings ( ie I overrode the setting to make a large cup and now want to return it to the small cup 30mls??
  • 487 Answers
Ok this is easy
you place your cup under the dispenser. Press the button but keep it pressed in to the desired level. Release and you have reprogramed the machine.
Posted on Apr 16, 2008
Why does my Keruig.one cup coffee maker only disperse small cup
Should be a button that gives you the option to select cup size. The owners manual will explain this.
Feb 25, 2016 | Coffee Makers & Espresso Machines
Tried to set it up for the first time and the small cup & large cup both flashed ... I pushed the small cup and nothing happened so I turned off machine and unplugged and started again ... still same...
Call Keurig's customer service office. Their customer service rep will attempt to troubleshoot the problem by phone or replace the unit if unsuccessful.
Mar 02, 2011 | Keurig Elite B40 Coffee Maker
Machine stopped working and both buttons are flickering, if I push the left (small coffee) button then the machine starts to pump cold water. If I push the left (large coffee) button nothing happens. Not...
May be busted, but before you take it to the shop try these few things. 1. Unplug machine for 30 seconds 2. Then plug back in, (lights should still be blinking) Take silver handle that you lift when you put in coffee pods and gently push back handle as far as you can for 3 seconds. This should reset your machine,back to factory settings. To then reset coffee cup settings to your personal taste by: 3. You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. Do the same for small coffee side. Hope this works,it has for me; just not sure because of the cold water pumping out issue. good luck
Nov 11, 2010 | Nespresso Essenza C100 Espresso...
When you press the button for a large cup of espresso (Nespresso Essenza) only small amount comes out
You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. The small cup that you are currently getting was probably set at the factory. Good luck
Nov 19, 2009 | Nespresso Essenza C100 Espresso...
Saeco Incanto Classic Espresso Machine Logo
80 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
