Question about Sharp AL-1641CS Laser Digital Copier
Sharp copier al-1642cs
I have a code L-1 on the sceen and nothig happens and no buttons respond why? i have a code (L-1) when turned on and no buttons operate, why?
  • Anonymous May 28, 2008
    i have a code (L) EN ANY BOTTON DONT WORK PLZ i need help
  • solong Jul 22, 2008
    I have a code L1 flashing on the screen as well. Nothing works. What's the problem?
  • Sharp Master
  • 2,794 Answers
This error is caused when the scanner glass is in the locked position. Make sure it is unlocked underneath the scanner on the left side.
If you look into the scanner is the ribbon cable tangled up or frayed?
Posted on Jun 09, 2008
We have a Sharp AL-1642CS Copier machine. That currently isn't working. What does a CH code mean?
CH code = Toner Cartridge is missing or not installed properly. In rare cases it is a defective toner cartridge. Also double check the right side and front doors proper closure.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Sharp AL-1642CS Copier
I have a sharp al-1642cs that will not work it just keep flashing L1 can you help
www.cyberscholar.com/sharp/resources/cop_man_soho_AL1642CS.pdf
http://www.service-docs.com/store/catalogue.php?cat=281&exp=0&resultpage=10 L1 00 Feeding is not completed L1 00 Feeding is not completed
within the specified time
after starting feeding.
(The scan head locking
switch is locked)
1.unlock Scanner unit
2. chang connecter
Scanner unit
May 09, 2010 | Sharp AL-1642CS Copier
On line button on copier
it must be shared for all to access. The online button can be pressed to stop the print process when adding paper or toner.
Feb 17, 2010 | Sharp AL-1642CS Copier
Error code CH on sharp sf-2027
Hi olixrules
CH light blinking - The DV tank is not installed.
CH light steady - Door switch is not turned on (interlock switch is ON).
Source here.
Hope this gives you some idea, unfortunately I'm not sure how to resolve these error on this particular copier.
Scott
Feb 01, 2010 | Sharp AL-1642CS Copier
Error code h4 on sharp al-1642cs
I have a solution for this posted in the tips section. Just search for Sharp AL H4
Jan 16, 2010 | Sharp AL-1642CS Copier
L 1 flash alternately. Scan head is unlocked on the AL-1642CS.
L1 is the exposure lamp and mirror feed motor malfunctions code.Change the expo lamp therofuse or the mtors.
Dec 11, 2009 | Sharp AL-1642CS Copier
Sharp AL-1642CS
Hello sir; I believe that's drum cartridge problem try to change that see what going to happen.
Jan 22, 2009 | Sharp AL-1642CS Copier
Sharp AL-1642CS Copier, the scanner is jammed
Not familiar with that model but what I would try is to turn off the copier remove the glass and try moving it by hand, then turn it on and see what happens it may have a bad motor
Oct 29, 2008 | Sharp AL-1642CS Copier
Tray 1 is full on my Sharp AL-1642CS but when it ties to print to tray 1 the 'P' keeps flashing!
pull both trays out.....have a look in tray 2, is there a switch sensor actuator hanging down yes........is there a similar one in tray one?
No? They get knocked off and lost very easily
Jun 11, 2008 | Sharp AL-1642CS Copier
Error code L 1
probally little switch on "ceiling of where paper exits has been bumped locking lens, please rate as fixya or reply
Dec 27, 2007 | Sharp AL-1642CS Copier
Sharp AL-1641CS Laser Digital Copier Logo
79 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
