Question about AOpen MX46-533V (91.89U10.061) Motherboard
My problem i try to install xp in my machine but when i get the second screen when i am suppose to press enter to continue (or R to repair ....) my keyboard became dessapear it not able to communicate with my PC. Please help me
  • 655 Answers
Fissy,
check out your RAM first.
Remove the RAM from slots.
Clean the connection points with pencil earaser.(Rubber)
Fit it again gently.
Keep to put RAM preferebly near to CPU.
Then try out.
If still problem, then try to use other RAM.
Please post your feed-back.
Thanks
Iqbal
Posted on Apr 16, 2008
After update the windows i restart my computer but the bluse screen of HP come and come restart and restart i press f8 and after i press stafe mode put nothing happen the blue screen of HP come
Repair the Operating System.
  • Insert your Windows XP CD, save the bios settings and exit. Soon "Press any key to boot of CD" will appear on the screen, hit the space bar to continue.
  • Now setup will inspect your hardware and software, it then will load various files required for the repair. Just wait and be patient, this may take a few moments.
  • Soon a menu will appear (as pictured below), press enter to continue.
  • Now the "End User Agreement" Press "F8" if you agree, "ESC" if you don't.
  • You will now have to select the installation you wish to repair. Usually there is only one, but sometimes, there may be 2 or more (i.e. you have done a parallel install to resolve a problem), use the up/down arrow key to select the install, and then press "R" to continue.
  • Setup will now examine the disk be patient, it can take a few minutes.
  • Setup will go through a percentage - 1 to 100%
  • A screen will soon appear. Press "F3" to continue
  • Now setup will reboot system, wait 15 seconds or just press enter.
  • Now it is time to see if this has solved your problems.
Regards,
Riztech
May 23, 2011 | HP dc7100 SFF PC Desktop
Boots up but goes to the xp screen and then shuts down and restarts. what do i do?
You will need your XP CD to run a Repair install.
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will need to press enter to setup Windows XP.
3. To setup Windows XP now and Repair Install, press ENTER. DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read the fix at the end of this post.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
If you don't have an option to repair, try this:
1. Boot with XP CD.
2. Press R to load the Recovery Console.
3. Login to the Recovery Console using your Admin password if needed.
4. Type bootcfg
5. This should fix any boot.ini errors causing setup not to see the XP installation.
6. Try the repair install again.
If the Repair is still not an option, try the following:
1. Boot with XP CD.
4. If the CD letter is K: give these commands
* copy K:\i386\ntldr C:\
* copy K:\i386\ntdetect.com C:\
While still in the Recovery Console, try this as well:
1. Type: attrib -h -r -s C:\boot.ini del C:\boot.ini
2. Type: BootCfg /Rebuild
3. Now Restart and try the Repair Install again.
Feb 23, 2011 | Gateway 704GE PC Desktop
Start menu issue
If a system restore does not take care of this issue, then i recommend backing up all data then reinstalling the operating system. If you need further assistance, you can contact us 24/7 at 800-595-3564. Thank you.
Jan 18, 2010 | Dell Inspiron E1505 Notebook
My Dell OptiPlex GX 520 has frozen. It runs Windows XP. Here in the UK, we have had a cold snap in what the papers are calling "The Coldest Day". Dunno if that's got anything to do with it. Anyway, I came...
The weather has nothing to do with the operation of your computer, as long as the computer is indoors and it is operating within a temperature of about 15 degrees and above.
The problem must be on your Operating System (OS), it must have been corrupted and is failing to load the operating system. This could be caused by a number of reasons, which may include, a recently installed program or hardware, viruses.
You need to repair the operating system to solve this problem.
Use your Windows XP OS installation CD to perform a system repair.
To perform a system repair, follow these steps:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Procedure for performing a Windows XP Repair:
  • Insert the Windows XP CD.
  • Restart the computer, and then press any key to boot from CD.
  • Windows will ask you to press R to repair using recovery console, ignore this message and press Enter to continue with setup.
  • After the files have been loaded, Windows will start and a list of options will be displayed. These will include, “Press Esc for a new installation”, “Press R to repair Windows”.
  • At this point, press “R” to repair Windows XP.
  • Windows will restart and the repair process will continue automatically.
  • Windows will restart and ask you again to press any key to boot from CD, ignore this message and let the process continue automatically.
  • A blue screen will appear and the installation will continue.
  • You will also be asked to enter your product key, enter the product key that came with the CD, then continue with the setup process.
  • Windows will restart for the last time, ignore the “press any key” message again. Windows will welcome you in for the first time, the repair process will have been complete.
Performing a system repair will not delete your data or change your settings.
If this doesn't solve your problem, you will have to make a new installation of you Operating System, let me know and I will show you how to do this.
Thank you for using Fixya,
Kenneth.
Jan 13, 2010 | Dell OptiPlex GX620 PC Desktop
Need to reinstall windows message says,"problem with system32,please use windows start up CD and select r to repair the problem."
Set your first boot device in the Bios to CD-Rom. Insert your Windows XP CD, save the bios settings and exit. Soon "Press any key to boot of CD" will appear on the screen, hit the space bar to continue.
Jan 06, 2010 | Acer Aspire 5100 Notebook
My Acer Aspire boots up but hangs at the Aspire screen after the Windows XP screen. What do I do?
check the RAM of your system and the OS for virus, if possible try formatting the OS or REPAIRING it.
Nov 22, 2009 | Computers & Internet
I forgot d password on my hard drive and i need 2 no how to load windows without enterin the password
you have few options for login to windows, without entering a password.
1. Add another hard drive to your machine, then try to boot through this hard drive. you just go to your hard drives in my computer and open your system drive (here the volume name may be different).
go to system32(windows xp) in your hard drive and you will find one file "SAM". now remove that file.
after deleting the file. you have to reboot your machine, now login to your windows. here you can login without providing the password.
2. this is the second option, commonly helpful for all. downloading the password recovery boot software. by using of this option you can find the same thing without provide the password.
thank you.
Jul 26, 2008 | Acer Computers & Internet
I have a problem
Suggest you replace the keyboard & or try another keyboard & see if that fix's you're trouble.
Mike
Apr 16, 2008 | AOpen MX46L Motherboard
Driver error upon boot
You have a corrupt OS, assuming you have XP, you should do a repair installation. Don't worry, none of your files or settings or installed programs will be deleted. You may have to reinstall some old device drivers though. * Insert the XP CD and boot to it * When you see " To setup Windows XP now, press ENTER", go ahead and press ENTER * You will now see an option to repair Windows by pressing "R". Do not select this option - it will only take you to the Recovery Console which is not what we want to do. Instead, choose to continue the installation * When you see the license agreement, press F8 to agree * On the next screen make sure your current XP installation is selected and then press "R" to repair XP * At this point XP will begin to install on top of itself, replacing damaged, missing or altered system files. Follow the instructions on the remaining screens to complete the Repair Install. It will look very much like a normal (new) OS installation. If all goes well your repaired XP installation will remain intact, keeping your personalized settings and installed programs as they originally were.
Aug 08, 2007 | Acer Aspire 3680 Laptop
Help!!!!!!!!!!!
you may want to remove the cmos battery for at least 15 - 20 minutes from the motherboard. afterwhich, you can put back the cmos battery and try and restart your computer in safe mode.
Aug 07, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
AOpen MX46-533V (91.89U10.061) Motherboard Logo
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
