Problem with setup. another device in conflict
    Brigadier General:
  • 6,966 Answers
Normally conflicts would be with the IRQs assigned to a device. Some methods of resolving conflicts are:
1. relocating the device to another slot;
2. manually configuring the IRQs in the CMOS/BIOS setup;
3. manually configuring the IRQs in Device Manager.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 16, 2008
Toshiba Satelite M35X-S111 Beep codes on boot
You need to go into the BIOS (setup) and reset to factory defaults first. This should clear up the issue.
May 28, 2012 | Toshiba Satellite M35X-S161 Notebook
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
Al encender mi ACER Aspire 5100 suenan 2 pitidos y en la pantalla me pone: Sistem BIOS Version:V3.13 Bus:06, Device:01, Function:00 ERROR Resource Conflict - PCI in slot 03 Bus 06, Device:04, Function...
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
Aug 16, 2010 | Computers & Internet
I have an Acer Aspire 5100 with Vista Home Premium on it...when starting the laptop acer 5100 it tries to start beeps...and it shows the following page of errors Bus 06, device 02 ,function 00 error...
It might be possible some kinda a BIOS corruption. Let us try this first. ASA computer starts keep on tapping F2, it will enter the BIOS setup utility, then press F9 and then F10, save the seeting and restart the computer. It should resolve the issue. But if the issue still persists, then update the BIOS. Visit the webiste mentioned below:
http://support.acer.com/drivers_download.aspx
Select the model and update the BIOS.
May 07, 2010 | Acer Aspire 5100 Notebook
Laptop hasn't been used in a while. I turned it on and got an error. Resource Conflict - PCI Network Controller How do I fix this? Running Win98
  1. Go to Start » Settings » Control Panel to launch the Control Panel window, and then double-click on the System icon. In the System Properties window, click on the Device Manager tab at the top of the window.
  2. If the operating system has detected a resource conflict, it will indicate this with a special symbol (a black exclamation mark within a yellow circle) next to the name of the device with the resource conflict:
  3. Single-click on the device with the resource conflict to highlight it and then click on the Properties button at the bottom of the window. This will bring up the Properties window for your PCI Network Controller. Select the Resources tab. You should see a screen similar to the one below:
  4. Deselect the Use automatic settings checkbox, and single-click on the resource with the conflict to highlight it.
  5. You may need to change the entry in the Setting based on menu ring to a different basic configuration, in order to disable the use of certain resources. The basic configurations range from a "base I/O address only" setup to various combination's of base I/O address, IRQ, and DMA. (Note: some devices only have one basic configuration.)
  6. Click on the Change Setting... button to bring up the editing window for that resource. You will be able to cycle through the available resource settings for your system. If Windows 98/95 is aware of any devices that are already using that setting, you will be informed of this in the Conflict information area at the bottom of the resource editing window.
Jan 26, 2010 | IBM ThinkPad A21m 2628 Notebook
Esource Conflict - PCI Mass Storage Controller in
sounds like a printer or someother device was unplugged improperly has has created a conflick
Oct 03, 2009 | Computers & Internet
Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
Jul 19, 2008 | Toshiba Satellite A105 Notebook
Sound driver
Missing or lost sound in Windows 95 / 98 / ME / 2K / XP.
Cause:This issue could be caused by any of the below possibilities.
  1. Bad software settings.
  2. Corrupt or missing sound drivers.
  3. Compatibility issues with the operating system and/or other hardware.
  4. Speaker related issues.
  5. Bad or missing sound card.
Solution:Verify software volume control settings
First verify you see a small sound icon sound3.gif in the systray (generally at the bottom right hand corner of your screen). If this icon is missing follow the below section.
Windows XP
  1. Open the Control panel
  2. Open the "Sounds and Audio Devices" icon.
  3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
  4. If you were able to check this box, click ok and close out of this window and the Control Panel.
  5. Double-click the sound icon in the systray and verify that all the sound volumes are mid-way or higher.
verify the installed driver settings
  1. Open the Windows Device Manager
  2. Verify there are no conflicts or errors listed anywhere in Device Manager. If conflicts exist skip down to conflicts section.
  3. Verify no other devices are listed. If other devices are listed skip down to other devices section.
  4. Verify that your "Sound, video and game controllers" category is listed, if not skip down to the missing sound card section.
  5. If no conflicts or other devices are listed and your sound card is listed with no conflicts, skip to the next section.
Conflicts section
If conflicts exists with your sound card and/or other devices installed in your computer it is likely that either the drivers are not properly installed for that device and/or the sound card and/or other devices are conflicting. If you open the properties of the device that is conflicting and view the properties, additional details about the conflict can be found. Additional information about error codes as well as help with Device Manager can be found on our Device Manager section.
If you are unable to locate additional information about your issue or are unable to resolve the issue, follow the below steps.
  1. Under Sound, Video and game controllers highlight each device and press the delete key to remove the device.
  2. Reboot the computer.
  3. As the computer is booting the system will detect the sound card and any of it's devices and re-install those devices. If prompted for a location of drivers, try pointing it to your sound card CD and/or your Windows CD. If this does not work or is unable to locate the proper files, you will need to get the latest sound drivers from your sound card manufacturer.
Other devices section
If other devices are listed, it is possible that these other devices could be the sound card or other devices conflicting with the sound card. If any other devices are listed it is recommended you remove those devices, reboot the computer and let Windows redetect the devices.
If this does not work, attempt to determine which device is not being detected and resolve that issue first.
Missing sound card section.
If you are missing the "Sound, video and game controllers" category in Device Manager, it is likely that the sound card drivers are not installed properly, sound card has been disabled, sound card is bad, or no sound card is available in the computer. First, verify no conflicts or other devices are present in the Device Manager; if these are present it is likely they are the sound card and/or devices causing the sound card not to be detected. Second, verify that the computer has a sound card and/or that the sound card is enabled on the computer.
If this is an on-board sound card you can verify that it is enabled in BIOS setup. Additional information on entering the BIOS setup can be found on document CH000192.
If you have no adapters and/or cannot click the down arrow to select the correct adapter, close out of this Window. In Control Panel double-click the System icon / click the Device Manager tab within Device Manager and ensure there are no yellow ! or red X.
If you have either of these on any of your sound devices, attempt to remove everything under Sound Video game controllers and reboot the computer. If after rebooting the computer you still have the same conflicts, double-click on the conflicting device and refer to our Device Manager error code section giving you additional information on the error code you are experiencing.
Verify speaker connections
Verify the speakers settings and speakers are not at fault by running through speaker troubleshooting steps in document CH000034.
Sound card drivers
If you have followed the above recommendations and you are still unable to get the sound card to work, download and install the latest sound card drivers from the computer or sound card manufacturer. A listing of sound card drivers can be found on our sound card driver page.
Dec 26, 2007 | Toshiba Satellite U205 Notebook
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
