Question about Samsung WEP-150 Wireless Headset
How to charge WEP-150?
I am having a problem trying to charge WEP-150 I got it today but when I connect the charger all I get is red flash followed by green flash and than it is not charging, WHY?
  • hecket Jul 04, 2008
    i plug in my head set, it flashes green and then nothing.  Charge for hours nothing.  Seems like something may not be right with the charger.
WEP-150, I put it on charge, as soon as I plugged it in, the light went red, then green, then it went off. It is not powering after leaving it over night. HELP!!!
Posted on Jul 21, 2008
Why motorola radius cp200 flashes red while charging?
Typically when the charger flashes red you have one of the following conditions:
1) The battery is simply too low to charge. Leave it on the charger for a few hours to see if it resolves. If it is a new battery return the battery for a replacement.
2) Your battery is not making good connection. Clean the battery and charger contacts with a pencil eraser. Check your contacts in the charge itself to make certain one isn't damaged or broken.
3) Your battery has an internal short. Test the battery on another charger to see if you get the same result. If so, replace the battery. 4) If you have a charger problem, the best test is to try another battery in the charger. Reminder: be certain the insert is turned the correct direction for the battery you are using.
Best regards.
Apr 30, 2014 | Motorola Mint Radius Cp200 Uhf 4ch Radio
Samsung wep 150
then internal battery is dead sir
its clear
Jun 16, 2008 | Samsung WEP-150 Wireless Headset
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
What does the flashing red light mean?!?
The flashing red probably means that the charger is working correctly and is indeed charging the batteries. The light should turn green when charging is complete after anything from 1 to 16 hours depending on how this charger works.
Do the following test: Fit the charger with your batteries and connect it to the mains. After 1 hour check if there is a detectable temperature rise in the batteries. You can do this without interrupting the charge cycle by touching the cells with the back of your fingers. If the temperature is still low, let it continue for another 15 hours or so, checking every now & then for any temperature increase. Should the temperature rise more than a few degrees, then stop the charging by removing the charger from the mains. Should the red lamp remain flashing after 16 hours, then I suspect you to have a defective charger.
Dec 27, 2010 | Duracell AAA NiMH Battery Charger with 4...
My charger is flashing red when i place the battery in it
Ridgid charger lights read as follows: Solid red; charger has power. Flashing red; charger is evaluating the battery, checking if it's cool enough to charge and if it is in chargeable condition. If the battery is hot, i.e. just came off the tool after extended use, it won't charge the battery until it cools down. Flashing red & green; the battery is defective and the charger will not charge it. Solid red & flashing green; battery is charging. Solid green; battery is full.
Dec 07, 2010 | Ridgid Drills
My sony ericsson w995 won't start,ive tried charging it...but all that happens is that the red light on the back flashes...ive tried everything,please help!
Very simple.Just follow this steps:
1. Connect the charger.
2. While the charger connected, open the back cover and close the cover again. Your phone can be switched on now. This is because this phone got sensor that ensure the back cover always closed while the phone operate.
3. If the above steps not working, try remove the battery while the phone is connected with charger.
~ Please encourage me to help people like this by donating small amount to my PayPal account.Thanks dude.
My PayPal id : ruzaini88@gmail.com
Feb 19, 2010 | Sony Ericsson Walkman® W995 Cell Phone
Samsung WEP150MBE not working
whats the answer i have the same problem
Oct 01, 2009 | Samsung WEP-150 Wireless Headset
Samsung wep 150
I think i know why your bluetooth goes red then green. It is because your using a wrong charger like different make of the the charger or is it you never use it for a long time so is completely dead and you have to buy a new charger or bluetooth.
Nov 12, 2007 | Samsung WEP-150 Wireless Headset
Samsung WEP-150 Wireless Headset Logo
499 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
