My norton360is due to run out in15days but i wish to keep it as it is very good how can i keep it for another 12 mths can i just send in what it cost me last and if so where do i send it to
    Problem Solver:
Nortons should ask you to renew ,if not go to your nortons status/ subscription you should have a link to follow.
hope this helps. blue51
Posted on Apr 16, 2008
My Thetford keeps freezing the food
move temp sensor down if none replace temp sensor
Jan 01, 2017 | Thetford Refrigerators
Heater blower not working 2000 intrique
Most likely a failed blower motor resistor due to an excessive amp draw from the blower motor, recommend do both.
Dec 23, 2013 | 2000 Oldsmobile Intrigue
It keeps blowing my fuse for my stock radio. Pushing a 10" sub.. Fuse on my amp is good. In-line fuse is good. But it keeps blowing the radio fuse in my panel.. ? Please help.. Thanks Ryan
Check the amp turn-on wire. It's a blue/white wire running from the radio to the amp. It's probably label REM at the amp. This wire sends a switched 12 volts from the radio to the amp. It is probably shorting out somewhere between the radio and the amp.
Nov 28, 2010 | Alpine MRP-T220 Car Audio Amplifier
Door seals rotting out on westinghouse freestyle 920 dishwasher
If the machine is kept idle for long time without use, these types of problem happens.
When not in use, apply talcum powder over the gasket. Moist the powder and apply as it will fall off . Leave the door slightly open by keeping some folded cloth or some other soft material and close the door.
Contact the service provider and protect the electronics by a water-resistant cover.
May 26, 2010 | Kenmore 15129 Built-in Dishwasher
My internet will just stop working around 12-18 hours of running. After I reset it will be back up and running for 12-18 hours. I have to keep resetting my computer to get the internet back up and running....
Dear sir good day i think that to fix this problem follow these steps:
  1. Start Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. On the Advanced tab, click Reset.
  4. In the Reset Internet Explorer Settings dialog box, click Reset to confirm
and try and if the problem exists try download a new ver of explorer from the link http://www.microsoft.com/downloads/details.aspx?FamilyId=9AE91EBE-3385-447C-8A30-081805B2F90B
and i recommend that you install a new firm ware for *********** board too and try to make a good circumstances for your computer fresh cool air will be high recommend ... and at end i wish to you a good day
Dec 22, 2009 | Microsoft Windows XP Home Edition
Timex 1854 chrono,indigo lght not working. 2nd one in 4 mths?
the same problem, after 3 years of use.
Night Indiglo light was very bad.
thought the battery replaced it, the battery was okay.
began to collect but probably need a special tool, the glass cracked)
Sep 09, 2009 | Timex Watches
Fuel is not reaching from the pump to the injectors on a 1991 S10
so the vech starts? you should be able to hear the pump running when you trun the key to the run postion. remove the gas cap place a peice of hose down the fill neck turn the key to the run postion , remeber the pump will only for 10 to 12 seconds, the pump will not run all the time until the vech starts. on the fire wall off this vech there is a 20amp fuse for the fuel pump the relay is there also . there is also red wire that has a female spade connection on it also. you can take a fused jump wire from the battery to this connection 20 amp fuse and power up the fuel pump. if the pump still dose not work warrntey the pump. good luck kdc744
Dec 26, 2008 | 1991 Chevrolet S-10 Blazer
Service engine soon & brake light stays on
the service engine light is prob due to the oxygen sensor being damaged, not replace or you having the catalytic converter taken off---just messing with you. start at auto zone and have then do a free code read then go from there. you should troubleshoot the low fluid level switch for your brake fluid. unplug it and see if the light goes off and if it doesn't jump the two terminals on the harness. oh the car will have to be running. Let me know MrRodneyLong@gmail.com
Jul 04, 2008 | 2000 Ford Mustang
Very loud fan!! Sounds like jet engine and make the computer shutoff.
In side you're ZV5000 are two fans. These fans sit on a spindle which spins. The spindle may be worn which is giving you that loud noise. (Or a fan blade could be bent or warped from heat).
The fan it’s self may be loose & can be tightened.
The only way to check if the spindle is worn would be to dissemble the ZV5000. With the correct instruction you can check the fans. (And also clean the fans & copper heat sinks).
Here is a link to do this you're self, including pictures.
http://www.instructables.com/id/Cleaning-Your-Laptop-Cooling-System/
It's worth taking a look & saving you're self a few bucks.
Good Luck & take you time!
Mike
May 17, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
