Question about Akai PDP-4249G 42 in. EDTV-Ready Plasma Television
Akai 42 inch plasma
My Akai plasma tv has color scrambling after it has been running for awhile. ie green, blue or red haze on different areas of screen. Not sure what could cause this
  • jsh31 Jul 15, 2008
    I have a similar problem with an Akai aswell but after a while of use the picture starts jumping. Does this mean I have a board over heating also? And is my test the same? If it is what do you do when you find the problem board?
    Problem Solver:
  • 8 Answers
Try putting a fan on the back of the tv to see if it is getting better. If it does then you probally have a board that is overheating. If that is the case then CAREFULLY !!! remove the back and place where you can turn on and safely access the open back NO TOUCHING STUFF !!! Mabey lay it face down on a glass table or lay it on a table with 25% hanging over the edge to see the screen. Then take a COLD blow dryer and blow it on the boards to find out which one makes it get better. If one does then it will probally be your problem board. Make extremely sure that is the one before removing it by blowing from all angles on the boards around it without air hitting the suposed problem board. Then try a little hot air to see if that starts the problem on that board so you can be sure. Of course check the surrounding and offending board several times to be sure before removing.
Posted on Jul 12, 2008
VIZIO Tv E422VA picture showing red or green color on dark areas of screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 29, 2015 | Vizio E422VA 42-inch Widescreen LCD TV -...
TV works but black colors on the screen are blotchy green or red.
same with everyone it is akai company speciallity and then they want money in free
Mar 21, 2010 | Akai PDP4225M 42 in. Plasma Television
Akai pt4298hd 42 inch projection tv has red and green haze.part number stk392-040 were replaced 2 years ago.that fixed the problems.the symptons are the same.are these chips easy to acces ?
Yes they are But CK 2 resistors 2.7ohms in front of ICs if they are Bad they can cause same Problem to order new ICs $9.50 each Call Mats Electronics
1-800-628-1118
Dec 20, 2009 | Akai PT4298HD Rear Projection Television
Whem first turned on has a white haze once it is warmed up it has a red haze in the dark scenes i have a 42 inch lg plasma
Contact your LG dealer to arrange a service call & have the software version updated, an older software may be present in the TV which can give a white screen start up problem
Nov 22, 2009 | LG 42PC3D 42 in. Plasma Television
I can't seem to correct a tint problem. The tv turns on and the tint doesn't change. A friend says it could be a vidoe card?
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
Nov 08, 2009 | Akai PDP4225M 42 in. Plasma Television
Curved red image on 46" Akai rear projection TV
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
Aug 29, 2009 | Akai PT4298HD Rear Projection Television
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
May 21, 2009 | Philips 42PF5331 42 in. Plasma Television
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Plasma tv screen has green pixelating into pictures
I had the same problem and solved it with a factory reset. hold menu button dowm for 10 seconds and it will alow you to reset all the colors.
Feb 01, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Akai PDP-4249G 42 in. EDTV-Ready Plasma Television Logo
200 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
