Question about Roper RAB5232E
Dropped foreign object into corner opening
I have a Roper RAB4232EW1 top-loading washing machine.
While wiping down the crevices and corners around the "big ring" (at the top of the drum), I accidentally dropped a wet paper towel into an opening in the  front right corner.  Are there any mechanisms in the space between the drum and the inner cabinet wall that this foreign object might harm?
THANKS!
It will dissolve away, as long as it's a paper towel
Posted on Feb 23, 2009
    Genius:
  • 1,073 Answers
No you can lean the machine backwards and should be able to remove it with out any disasembling of the unit, if it did not fall all the way to the bottom and you can not remove it it will not hurt anything
Posted on Apr 16, 2008
HOW DO I REMOVE TOP AND SIDES OF A ROPER TOP LOAD DISHWASHER, RAS8245EQ1
STEP ONE DISCONNECT ELECTRICAL AND GAS LINE AFTER SHUTTING GAS SUPPLY LINE VALVE!!!!!!
Tops are ususally held down with spring clips near the front corners on the sides. pull gently upward while insetring a putty knife from the side in the groove between the top and the sides. The idea is to compress the clip to release the top. when the top swings up it's usually held to the back with insert clips that form a hinge when seated in their slot. when you lif, slide the top forward and it should come free. Watch out for the wires.
Feb 24, 2011 | Roper Washing Machines
Roper washer will fill up with water and wont stop. What could be wrong?
The air hose from the tub to the pressure switch (inside the control panel) is either disconnected or plugged with debris. Open the control panel by removing 2 screws in the front corners and check for disconnected hose. Otherwise disconnect the hose and blow through it to see if it is plugged.
Jan 12, 2011 | Roper RAX4233PQ Top Load Washer
I have a roper rtw4340sqo when it gets to the spin
Hiya,
if it was not spinning & then started again after you tilted it & set it back down i would suspect maybe a foregn object of some sort was stopping it & by tilting the machine you have dislodged it from where ever it was trapped most common cause is a coin or could be a loose screw dropped out from somewere.. you could check the filters if you have any to see if it has worked its way there if not i would leave it till it happens again then see if you can locate anything.. often tilting the machine will dislodge any objects making them fall to the bottom & preventing them causing the same problem again..
Hope this helps
Apr 22, 2010 | Roper RAX4233PQ Top Load Washer
Top loading Roper Washer id leakinf water
ok tom ...ready,,,look in the back of the console you will see at each corner a recess with a phillipshead screw,,,make them come up but dont remove them,,when the console comes lose from cabnit,,flip it back,,flip it back only and let it hang backwards..now theres a connect for the lid switch 2 gray wires connected to a brown and redess,,,ok now disconnect,,next in each corner is a brass clip 1 on each side take a screwdriver and pry them up softly...now pull the hold cabinet towards you,,but leave machine..keep me posted onthejob
Jan 27, 2009 | Roper Washing Machines
Roper washing machine
Unplug. Remove 2 screws on both back corners of top acess panel. Slide panel foreward and lift up. It will flip back out of the way. Unplug door switch harness. Pull up on and remove 2 retainer clips that attach backing plate to body. Pull up from back and remove housing.
Oct 18, 2008 | Roper RAS8445KQ Top Load Washer
Washing machine won''t drain
HI thanks for your questionOn your washer theres a electric pump sometimes foreign objects get caught in pump remove front panel . Using a blade screwdriver insert between top & front panel about 2 inches from corner .The front should now come off .The pump is on the left side . Disconnect pomer If your washer is full of water now put drain hose on floor or in bucket to drain water . Now remove hoses from pump & clean reinstal . Thanks for your question The appliance doc
Sep 06, 2008 | GE WHRE5260E Top Load Washer
Whirlpool TAWB600EQ1 - Washer
ck lid switch usually on right side of lid opening or on later models under back corner at lid hinge area
Aug 10, 2008 | Roper RAS8244KQ Top Load Washer
Lidswitch
To access the lid switch, REMOVE POWER, lift the console by one of three ways.
1. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward.
2. The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw.
3. insert a putty knife under each corner, push to release a latch. With console lifted:
1. You will find a lid switch connector (white or gray in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
Jun 16, 2008 | Roper RAS6233KQ Top Load Washer
GE Top load clothes washer
using pudy knife prees down on clips holding front on they are on each corner just below top ..after removing front panel ck pump on bottom right some had small fans on end of shft try turning fan if won't turn remove as much water as possible remove pump hoses remove pump and ck for foreign object inside pump
Jun 13, 2008 | Washing Machines
Creda IWD12 filter.
As far as I remember it goes like this.
take the filter in your hand and turn the knob counter clock wise intill it almost comes off. Then gently shuff it into the filter hole. Push it in as far as you can and than tighten it again.
Maybe the following link will help you
CREDA IWD12
Apr 20, 2008 | Creda IWD12 Front Load Washer / Dryer
Washing Machines Logo
119 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
