Unable to get to the boot from dos to reinstall the restore cd
  • 44 Answers
Try hitting and keep rehitting the F8 key as soon as your comp starts up and it should take you to the option of reboot from CD.
Posted on Apr 16, 2008
My acer netbook (winxp) won't load after the mouse cursor appeared
Sounds like you need to run the check disk utiltity but since you don't have a CD Drive, you're up the creek without a paddle. try booting up into Safe Mode and if you get there successfully reboot and see if the normal mode works, if not you can uninstall Microsoft Security Essential in Safe mode. Or you can use System Restore to restore back to a point (date and time) when the system was working ok. Click Start/Programs/Accessories/System Tools/System Restore and select a restore point before you loaded Security Essentials. In Windows 7 just click Start then type System Restore in the search box above the start then look at the returned results and click System Restore.
System Restore does not lose any of your data, documents, music, pictures, videos or programs (unless the programs was installed after the date and time you selected).
To get into safe mode follow the steps below:
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
You can try to get to a dos command prompt or you can see if the system will allow you to boot in Safe Mode to get to the dos command prompt.
May 12, 2012 | Computers & Internet
No boot sector on internal hard drive
Follow this procedure if the hard disk is detected. Insert dos bootable cd with fdisk in your DVD ROM. At the dos prompt a:\>fdisk/mbr
and press Enter. Your boot record will be restored.
Sep 13, 2011 | Dell Latitude D510 Notebook
Restore will not work comp goes thru the motions and comes back with unable to restore, it doesn't matter how far back you go
Hi, I believe you need to reinstall your operating system, follow these instruction:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 15, 2010 | Medion MD-1768 PC Desktop
I have an old laptop that partition and hd have been reformatted. I've tried using boot disk but keep getting the message that says, ''save to disk partition not found. So, can't get win98se to load as...
Haven't used win98 for a while so bear with me and this uses DOS COMMANDS too.
If useing restore cd/floppy you have to use a utility from compaq that creates two partitions on hard-drive.
They may have a restore floppy if you need it too.
One for "recovery files" and one for "OS Boot"
AHH, the memories, I still have my 95/98/ME Laptops up and running for older stuff. HP n CQ too.
Restore CD should do it all though.
If no restore CD - have Win98 CD?
if Harddrive partitioned and formated - Just do 1
1. boot from Win98 CD.
Partition n Format
2. Choose boot to DOS (puts u in virtual drive A)
AT PROMPT
3. Type drive letter of CD ( C: D: or E: )
4. Type CD Win98
5. Type Fdisk ( to partion drive)
reboot n do 1 + 2
6. Type format C: ( I do this to ckeck drive for errors)
OR
JUST Boot from CD and follow install instructions.
1 to 6 for if you have problem with Win98 CD setting up Harddrive.
Apr 04, 2010 | Compaq Presario 2140US Notebook
Unable to boot my Dell C521 and want to restore factory defaults
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?journalid=6C9BD953D22BB334E040AE0AB8E14D96&docid=336966#restore1_task3
Please follow the link above and ensure that u select the correct operating system to have the right procedure.....
PCrestore might not work in cases when the system has been reinstaled earlier via CD or if the restore partition is correct ...the above link also directs u to the manual reinstallation process
Jun 18, 2009 | Dell Dimension C521 PC Desktop
Having major issues with reformatting Acer Aspire One
Sure, calm down. You need to get a bootable cd like UBCD. This cd not only boots, but installs a cd driver, allowing full access of CD Drive in a DOS Environment. Check out the UBCD website, download it, and turn the computer on, with the cd in the drive, your computer will boot, so boot the cd, when the options load, hit the key "r", and windows will repair.
Good Luck
Jun 18, 2009 | Acer Aspire 4315 Notebook
Unable to restore to factory default. Boot up with 98 boot disk will not allow me to change to another drive. I am told that the operating syst is newer then what they gave me on the cd. I have gone to the...
go into the BIOS (Setup)(Should be F2, but look for the instruction on the DELL splash screen). Try to move the cd-rom up the list. The instructions should be on the screen somewhere, sometimes it is + to move up - to move down. It should say on the screen. Tthen save the settings and reboot. Let us know if it still does not boot from CD. You will have to hit a key when it says "Hit any key to start from CD.." before the timer expires.
Mar 11, 2009 | Dell Dimension 4550 PC Desktop
Trouble Updating BIOS: Medion M3 Director 5100
plz check the fsb of ur new memory.plz conform it the memory is supporting ur motherboard.
Jan 15, 2009 | Medion M3 Director 5100 PC Desktop
PC UNABLE TO BOOT UP WITH SAFE MODE
Hi when you switch your computer on you need to enter the setup mode you might have to press one of the f keys or the escape key to enter the dos setup mode then you need to change the boot up order if you have xp cd then you could boot up the cd drive first then hd or you can change it so it boots up off the hard drv first depending on what the problem is but if you have disk then you can boot up off this and then see what error occures when it boots up to the windows screen.
Also if you have a setup disk you can boot up off the disk then thsi should sort the problem allowing comp to boot up.
you could boot up in safe mode then do system restore if it lets you and restore it to a date that you know your computer was working fine.
Let me know if you need further assistance ok
Feb 11, 2008 | Computers & Internet
Restore factory settings
what i would do is go into dos. If you cant get into dos find a windows 98 setup disk 3.5" this will have the dos files that will allow the computer to reconize a generic cd rom. This should allow you to get your recovery disk working. Your software problem could of created a firmware problem also. Not reconizing the cd rom. This solution will provide the basics to get your cd rom loading the recovery disk for you. If you have questions or more problems feel free to contact me and i will take you through it step by step
Sep 18, 2007 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
David Payne
David Payne
