Unpluging tv to turn back on
When tv is turned off at night, it must be unplugged in order to turn it back on again the next day. Tv will turn on, off and back on without unplugging if done within a few minutes, otherwise it must be unplugged again.
    Genius:
  • Televison & ... Master
  • 1,673 Answers
There is a failing part most likely in the power supply or logic control area. I suggest you get it fixed before the defective parts cause other types of fautls.
There are a number of sections in the power supply. The standby supply stays on, and thus radiates some heat. When removing the AC plug from the wall, the power supply cools down. Then the defective part has drifted back in to close enough specs to let the set turn on again. This means that the fault is most likely a thermo sensitive part.
Jerry G.
Posted on Apr 16, 2008
Purple and blue screen on dlp tv
Sounds like a problem with the Vertical Video Card.
Have fun finding one. If your TV is still under warranty... send your TV off for repair.
Oct 03, 2012 | Samsung HL-R5656W 56" DLP HDTV
Tv wont turn on
Hi!
Try to check the back cover. If it is wet may be their was a short circuit. Have i t check to a qualified technician so that no further damaged maybe incurred by the unit. Power supply is affected if it was plug in for a long period of time with out unplugging it from the outlet. If it was turn on again it must be unplugged and rest for about half a day coz the power supply still received the current from the source.
Please specify if you have experience checking it with the technician?
Jonags
Dec 31, 2009 | Televison & Video
I turned the tv off the other night with the remote just like i always do got up next morning to turn it on it won't come on I have tried everything unplugging it pushing the power button on the tv instead...
Good day sir/maam, chances are you tv's switching power supply circuit has gone bad, you may try the following.
  1. open the back cover and locate the fuse, check if the thin wire is intact, (unplug the unit before opening the back cover) replace and test if the fuse blew up. test again.
  2. if the fuse is intact. replace the cover.
At this point. you have no choice but to call your dealer or repair man for service.
Oct 08, 2009 | Panasonic CT-36SX31 36" TV
Will not turn on
Resolder,or replaced the FBT,the flyback tranformer,the big black block of plastic with a red wire a cap hook to CRT(tv tube).High voltage prob.
Mar 13, 2009 | Toshiba 27AF42 27" TV
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Tv not powering on
as per your statement there is a loose contact in power supply section of your tv. it is 1oo% sure that allthe parts are ok as tv runs ok when it comes on. but you will have to call tech. as without knowing technology it is dangerous to open tv due to high voltage.
Sep 15, 2007 | RCA HD52W58 52" TV
TV refuses to stay on
I'm the OP of this, and what I did was had it unplugged for about 2 days, plugged it back in and it has worked since.
Aug 23, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Electro Med Services...
