Question about Panasonic KX-T7630 Corded Phone
MANUAL how go we set the radio through the speakers on the phone and other features the phone may have
Try press sp-phone & *7511. it should work.
Posted on May 15, 2008
How to I turn the universal volume on a Norton Networks T7316E Phone?
Have you tried to call the phone and adjust the volume on the set while the call is coming in? I think the only way you can adjust the ringer volume is if the phone is ringing.
Jun 25, 2015 | Nortel Networks T7316E Telephone Platinum...
Why does my volume not return to normal levels after using a motorola headset? Is there a way to return the unit to factory settings?
the volume control for the headset is typically the same one you use for the phone. plug the headset in again & use the volume control to increase/decrease volume as you require, remove the headset and use the same volume control to increase/decrease the volume on the device..
Nov 12, 2014 | Motorola Talkabout MT352R Two-way Radios,...
I have a TRC 502A CB radio that hasn't been used in about 5 yrs. I recently tried to use it and when I transmitted, the audio came thru the speaker. Any idea what's wrong?
it could be grounded inside...Somebody may had it set for Talkback features.. Take it apart look for speaker wires (see if soldered to resistors) if its shorted seperate wires ..just have speakers wires attached. Try external SPKR. Try different mics or radio may have gone bad completely.
Apr 07, 2011 | Radio Shack TRC-503 CB Radio
How do I use my cell phone with the radio feature in a 1999 XK8 Jaguar? I cannot locate the telephone instruction manual.
you have a bluetooth feature somewhere in your phone menu that you activate 'search for bluetooth device' while near your car radio (it needs to be on as well, set to search)
Dec 23, 2010 | 1999 Jaguar XK8
Unknown Phone on Lincoln Navigator
It means your phone is activated somehow. Cellular Phone NOTE: The audio system does not operate when the portable cellular phone is in use because the audio-mute feature will mute the audio system when a call is placed or received. Portable Cellular Phone Features
The portable cellular phone system is available only with the P100i audio unit and has the following features:
  • hands-free operation
  • radio muting while phone is in use
  • radio displays the phone number, signal strength, and call timer
  • radio can be used to dial stored numbers and adjust hands-free operation volume
For more detailed information, refer to the User's Guide.
  • Entering ACM Self-Diagnostic Mode.
  • ACM (Audio Control Module) Self-Diagnostic Mode
    NOTE: To enter the Speaker Walk-Around Test or ACM self-diagnostic mode, the ACM must be turned on and in radio tuner mode (AM/FM).
    ACM self-diagnostic mode can only be entered while in the Speaker Walk-Around Test.
    1. To enter the Speaker Walk-Around Test, press the ACM Preset Buttons 3 and 6 simultaneously.
    1. The Speaker Walk-Around Test stops at each speaker and applies a different tone to each speaker for about 1-2 seconds. Each speaker is tested and displayed on the ACM in the following sequence: RF, LF, LR, RR, SUBWOOFER I, SUBWOOFER II.
    1. The Speaker Walk-Around Test automatically continues and tests:
    • the antenna and displays ANTENNA II, for five seconds.
    • for a speaker short. If a short is present, SPKR SHORT will be displayed.
    • for the CD/DJ. The ACM display will show NO DJ if not present. The Speaker Walk-Around Test will end and the ACM will return to its previous setting.
    1. ACM self-diagnostic mode has five tests available:
    • Preset button 1 = Audio internal/external SELF TEST. If SELF FAIL is displayed, press TUNE > to scroll view the DTCs stored. Refer to the ACM Diagnostic Trouble Codes (DTC) Index. If the system is OK, SELF PASS is displayed.
    • Preset button 2 = View/Clear continuous diagnostic trouble codes (DTCs). NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > button to view the DTCs retrieved. Refer to the ACM DTC Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
    • Preset button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting.
    • Preset button 4 = Software configuration level. This test queries each radio system controller for the software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
    Controller Description Radio Display Example Main Main micro software version MAIN ##.##.## CDSP CDSP micro software version CDSP ##.##.## ADSP ADSP micro software version ADSP ##.##.## Auxiliary Auxiliary software version AUX ##.##.## CD/DJ CDDJ software version DJ ##.##.## CD Changer CDR software version CD ##.##.## Tape Deck Tape Deck software version TAP ##.##.## RSC Rear Seat controller software version RCP ##.##.##
    • Preset button 5 = DISPLAY TEST. This test will light all the ACM display segments for five seconds, then turn all segments off. When the test is complete, DISPLAY TEST is displayed on the bezel.
    1. To enter these tests, press the preset button desired while in the Speaker Walk-Around Test. This will abort the Speaker Walk-Around Test and start the selected test.
    1. To exit ACM self-diagnostic mode, turn the ignition switch or ACM OFF.
    1. If the concern remains and the fault is not detected, proceed to Symptom Chart to continue diagnostics.
    the module is under the floor console. Do you have the phone user manual.
    Apr 03, 2009 | 2000 Lincoln Navigator
    Cant find speaker phone feature on my Motorola Razr V3 cell phone
    Yes, This phone does have a speaker phone setting.
    When in a call it should be the top right button on your keypad.
    Dec 17, 2008 | Motorola Mobility RAZR V3
    Motorola T6310 Talkabout Sound only comes out of earphones
    We have discussed your dilemma. Check your audio jack hole to be certain nothing is still in the hole. Check to see you have the VOX setting turned to a normal or off setting. Typically the radio will shut off the front speaker when an audio device is plugged into the jack. If the radio senses the device, or a small piece of the plug is stuck in the jack, or the jack is damaged, it will shut off the front speaker.
    Since you can hear when using the headphone, it is apparent you have the radios programmed to the same frequency and code settings. This leads us to believe it is not a programming issue, short of the VOX feature, or mic gain. You might double check these settings.
    Here is a link to the manual: http://www.usersmanualguide.com/motorola/2-way_radio/t6310
    Nov 14, 2008 | Motorola Talkabout T6310 (14 Channels)...
    No audio but transmits ok
    Hello dgbuhl,
    Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a Privacy Code or Quiet Code. The actual name of the feature may vary.)
    In order for your radios to communicate with eachother all of the radios need to be on the same channel and have the same CTCSS / Privacy Code programmed (or the CTCSS feature must be disabled on all the radios). If CTCSS is enabled on one of the radios, but not the other, the situation you describe would occur.
    Check your user's manual for more information on the Privacy Tones and how to set them.
    Best Regards,
    Ken
    Go Ahead. Use Us.
    May 12, 2008 | Cherokee FR-465 (14 Channels) 2-Way Radio
    Nec DTerm Series i - Feature Light Flashing URGENT
    Thankfully I have found a solution that has worked.
    A 'winking' (flashing) feature button indicates the station is in call forward - all calls mode.
    To cancel this setting do the following
    Lift the handset or press speaker
    Dial the access code 4 + 2 (set as default)
    Receive confirmation tone and restore handset or press speaker
    I have found the manual at the following link to be the best resrouce ever - very easy to understand
    http://www.nec.co.th/html/download/Manual/Features%20&%20Specifications.pdf
    Jan 16, 2008 | NEC Dterm DTP 16D-1 Corded Phone
    Panasonic KX-T7630 Corded Phone Logo
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
