Question about Kitchen Ranges
I have a Westinghouse Tarragon Oven that required new knobs to operate the dials.
How do I operate my oven it has two dials...how do I get it to operate normally on manual...it is not digital...just has two knobs
One knob, the left one, is the the temperature knob and the other one the right one turns it on.
Jun 11, 2017 | Ovens
WHERE CAN I GET A NEW OVEN KNOB (DIAL) FOR MY DEFY SLIMLINE OVEN. HAVE BEEN TOLD THAT THEY NO LONGER MAKE THEM.
SADLY if they no longer make that type you might have to try and glue the old one back together ..we can not produce something that does not exist
Oct 05, 2015 | Ovens
We are renting a property with a Westinghouse mod 05-208307, never used it before, the setting have worn off around the oven nobs and don't know what they where pls help, can use over
The knob is the image of this link http://www.repairclinic.com/PartDetail/Knob-Dial-or-Button/5304441580/1063188 is pretty typical of all westinghouse knobs, that one shown is for westinghouse and perhaps can give you a good idea of the temp. set based on how far you turn it
Gene
Aug 13, 2011 | Ovens
Pizza, banana bread, etc. doesn't get done in the middle.
some oven temperature dials are adjustable by pulling knob off,turning a bit and pushing it back on in a different position.use an oven thermometer to determine the accuracy of your control knob.adjust knob or make note of difference between dial setting & thermometer reading.i.e.knob is at 350* thermometer says 300* set knob to 400* to achieve an oven temp of 350. could you E-mail me a slice of banna bread?
Sep 27, 2009 | Ovens
Numbers missing from Westinghouse oven knob, plus burner troubles
ok put a pan of water in your oven with a cooking thermometer in it. Turn your oven with the new knob you just got from repair shop. They are in the yellow pages Lots of laid of repair guys went out on there own. So they work at a lower price. As i was telling you.set your new knob @ 9:00 leave it there long enough to even out 10 minutes will do. next set it @10:00 next 11:00 @12:00 and so on. Till you get all your settings are compleat. Happy cooking from sawdust46
Aug 08, 2009 | Kitchen Ranges
My 1992 Frigidaire Elite stove has locked itself, how do unlock it?
1-turn oven control to lock
2-push in and turn the stop dial knob to set a cleaning time of aprox. 1 hour
3-push the start dial knob in . this will make the locking mechanism to operate (wait 15 seconds)
4- turn the stop knob back to the"0" setting on the cleaning dial. the knob will pop out waight 15 seconds to allow the mechanism to unlatch the door
5-open the door
6 push the stop dial in to return it to the manual position
7- turn the oven control knob to off
8- close door.
basically your just repeating a cleaning cycle to reset the lock mechanism
Sep 01, 2008 | Frigidaire Kitchen Ranges
How do I turn on my oven
look closely at ht e 2 dials push to stop cook manually.that s where theproblem lies. you need to set it for MANUAL cooking probably requires turning one knob till it pops out.its probalby set for timed cooking.Its usally labeled around the clock face in real small print "push in for manual operation"
Mar 22, 2008 | Kitchen Ranges
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
Westinghouse self cleaning oven manual or owners manual
Many White-Westinghouse manuals can be found here: http://www.frigidaire.com/support/manuals.asp I had the same problem and was able to solve it. They didn't have the exact manual for mine (a KF450G), but they had one that was similar enough (KF580H) to solve this issue. Setting the knobs to clean is only part of the process, to get it to run you need to set the timer. Read the key information below transcribed from the manual: --- To set the controls for the cleaning cycle: 1) Close the oven door. 2) Be sure the clock shows the correct time of day. 3) Be sure the Start Time knob is set for the same time as the clock. If not, turn the knob to the time on the clock. The knob will then pop out. 4) Push in and set the Stop Time knob for 2 to 3 hours past the Start Time. Example: If the Start Time and Clock read 1:00, set the Stop Time for 3:00 or 4:00. 5) Turn the Temperature Control to CLEAN. 6) Turn the Selector to CLEAN. If all controls are set correctly, the oven signal light will come on and stay on until the oven reaches its cleaning temperature. It will then cycle on and off. --- There is more information in the manual, but it's much too much information to manually transcribe - I've only typed enough for you to get it working. Note that the LOCKED light won't light initially, it only lights once the oven exceeds 550 degrees. Once that light is on, the oven will not reopen until the temperature drops below that point, even if you stop the clean cycle. Be sure to empty out the storage drawer under the oven before cleaning.
Dec 08, 2007 | Kitchen Ranges
Kitchen Ranges Logo
127 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
