Question about BenQ FP731 17" LCD Monitor
BenQ FP731 17" Inverter transistors
I have the same problem as another user where my monitor turns on then flashes almost instantly off. You mentioned re-soldering transistors near the inverter transformer. Only problem is, I've got 5 transformers and I'm not sure which one you are referring too..
Are you able to supply the 'component' numbers for the transistors that need to be replaced? I'm thinking you are referring to Q808,Q809,Q815 and Q816. Any help would be appreciated - I'm a novice.. I can take a photo of the power board if that would be any help..
Thanks..
Daniel
  • sry6 May 24, 2008
    thak same power on led ok no bright
    Champion:
  • 220 Answers
T751,752,753,753 are the transformers to be resoldered ,and resolder Transistors Q759,60,39,40,43,51.
Please check them with a multimeter if you are adept .
Please rate the solution and provide feedback.
Samir
Posted on Apr 25, 2008
Benq T905 Monitor's green light turns on and then off
Check for blown MOSFET IRFU9024N and transistors C5707/5706, and fuse in the inverter circuits section. Also look for bad caps with bulging top/seal. See some pictures of failed Dell monitors (BenQ made alot of monitors for Dell), http://s807.photobucket.com/home/budm/allalbums
Mar 14, 2010 | BenQ T905 (Black, Silver) 19 inch LCD...
Benq inverter board schemtic
Post me a picture of the board and I might be able to Help.Normally transistors 2Sc5707 are defective.
Samir.
viziks@gmail.com
Aug 20, 2008 | BenQ FP71G 17" LCD Monitor
Benq monitor
Most of the time problem is Invertor transistors being defective and Inverter transformer dry solder.
But you must be technically able with soldering skills and be able to test transistors using a multimeter.
Samir
Aug 06, 2008 | BenQ FP737S-D 17" LCD Monitor
LCD panel no display
check transistors Q739,740,759,760.These transistors are near the Yellow inverter transformers.Resolder these transformers and check/ replace above transistors.
Please rate this solution.
Samir
Jun 03, 2008 | BenQ FP737S-D 17" LCD Monitor
Q7T4 monitor
I have the same trouble,with the Benq Q7t4 power, but can you tell me how I can get it apart, I have taken all the screws out but can't seem to dismantle it.
many thks colin
Mar 31, 2008 | BenQ FP731 17" LCD Monitor
Back light goes out after start up
You have BenQ syndrome.
Sounds strange I know, but the power supply in your monitor is a BenQ manufactured part.
The problem is in the inverter section of the power/inverter board.
There are 4 small transistors (marked C5707) 1 or possibly 2 of these will have shorted out. Using a multimeter find the shorted one, and replace both of that pair, even if only one is shorted out.
There could also be other underlying issues as well that caused the transistor to fail in the first place.
Mar 28, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Benq 17"Lcd monitor fault
Resolder the power transistors on inverter board and also check them.If display is not there at all some of this 4 transistors C5707 should be defective.Check associated fuse and Fet which drives the transistor.
Also check with Benq ,Normally offers three year warranty.
Samir
Mar 23, 2008 | BenQ FP737S-D 17" LCD Monitor
Secondary monitor
When you first switch on Does it show Benq?If not the inverter circuit has failed.If you are technically able you can try resoldering transistors on inverter board.If your display is black all of the time transistors could have failed as also related fuse etc.
And yes please check with BenQ Normally these have a 3 year warranty.
Mar 05, 2008 | BenQ FP757 Monitor
Can repairs be made to BenQ FP731 17 inch Flat Screen.
The power and Inverter board has a problem.Check Inverter transistors and the related fuse.
Jan 30, 2008 | BenQ FP731 17" LCD Monitor
Benq FP731 17" monitor goes Blank after start up
Change the 2SC5707 transistors and electrolytic caps in the inverter
section. Also check the 3A picofuse, and resolder all transformer
pins
Aug 09, 2007 | BenQ FP731 - 17" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
304 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
