Question about GE WBSR3140DW Top Load Washer
GE Washer won't drain or spin
My GE washer is less than 2 years old. During a wash it held the entire load of water and does nothing else. I unattached the hose from the back and drained the water. I was able to get it through a cycle but it hesitated during the spin cycle like it was choking. Now it won't drain again or spin.
  • mrstg65
    mrstg65 Dec 12, 2012
    this is the first time that this website helped me to actually fix something.Thank you Albert!
  • Anonymous Mar 25, 2014
    water is not draining and machine not spinning.
  • 975 Answers
This is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Posted on Apr 16, 2008
  • mrstg65
    thanks albert! this worked..right on the money!
Washer won't spin. Motor goes thru cycle but not spinning
My kenmore washer won't spin - EASY FIX (PART ONE ...
? 5:45
www.youtube.com/watch?v=fRxKs2EEfbU
Feb 1, 2013 - Uploaded by Michael Borders My Kenmore washer's agitator stopped spinning my cloths during the wash. NO BIG DEAL!!!! EASY and ...
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - If your old or new washing machine does not spin we have some diy fix tips ... Fix Washing Machine That Won't Drain - Washer Not Draining ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Nov 02, 2015 | GE GTWN4250MWS 27" top-load washer with...
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
Ge wahing machine is leaking only when it drains or spins. never when it just fill and agitates
A washer that leaks only during the spin and drain cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
Nov 28, 2010 | GE WBSR3140DW Top Load Washer
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Mar 21, 2009 | GE Energy Star WCVH6260F Front Load Washer
Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Jan 28, 2009 | GE WBVH6240F Front Load Washer
Washer machine not draining water
The GE serviceman repaired my machine approximately 40 minutes. I paid $189 for the issue to be resolved in 5 minutes. This is no exaggeration.
The serviceman arrived at 2:50pm and finished at 2:55pm. It took another 5 minutes for me to write the check and he was gone.
My recommendation is...
- Purchase the GE service plan prior to calling GE to repair the service. A 1-Year service plan is $40 and 2-Year is $75. It costs $99 just for the serviceman to come to your house.
- Fix the issue yourself. Of course, this only applies if you are handy. I am handy and I tried to fix the problem myself. I just couldn't figure out the location of the access panel.
Solution...
The access panel is on the front. This can be removed in less than 20 seconds. The notches on the access panel is in line with the edging of the washing machine door. To remove, slide in a flat object like a flat-head screwdriver. Wiggle up and down on each side until door comes loose. Lift up door and set aside.
The water pump is on the lower right in the front of the washing machine. If your wash machine has any water in it, you want to use a shop vac to empty it out. The serviceman used a clamp to stop the water from running down. A little water still came out but he used my shop vac to get it up. It was less than a cup full and I had a 1/2 tub of water. Afterwards, he stuck his fingers in the water pump and pulled out the item that was blocking the pump.
Guess what was blocking the pump? The item was my two-month old daughter's sock. He recommends using a washing bag.
Remember this solution is for GE 315 model that is a top load washer. This will most likely work with similar models. I knew my water pump was still working because it hummed during the rinse and spin cycles.
Good luck and I hope this saves you $189 or any other fees.
Nov 21, 2008 | GE WBSR3140DW Top Load Washer
Takes hours to wash a load of towels
Just found out that there is a drain trap that can get clogged and needs regular maintenance. Take out the bottom panel by removing 3 phillips screws (7mm nut driver optional). Unscrew the trap (water will probably drain out so be prepared). Clean out debris. You may also have to remove the hose connected into the trap in extreme clogged cases. Just use pliers to release the hose clamp.
Replace the trap plug, hose (if necessary) and the bottom panel.
Good luck!!!
Bryan
Aug 24, 2008 | GE Energy Star WCVH6260F Front Load Washer
Probably a bad drain valve. As long as the tub is still full of water, the controls will not allow it spin, refill, etc. Have a service technician check the drain valve.
Jul 10, 2008 | GE Spacemaker WSLP1100D Top Load Washer
GE WBSR3140DW Top Load Washer Logo
5,075 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
