I have a Brivis Ducted Heating MPS series and this morning woke up with ERR 50 Hi and could smell gas. What does that mean and what should I do? We had an extreme low in temp outside last night could this have something to do with it? Need ideas ASAP Kylie
386 people viewed this problem
This solution has been voted best by the Fixya Commnunity
Hi, This is what I found for you: Error code 50 Error 50 indicates the unit has locked out after 4 ignition attempts error 46. This error can be reset by using the reset button to restart the heater, but the unit will probably lockout again if the condition has not been rectified. Check List: ? Refer checklist for error 46. Error code 46 & 55 Error 46 indicates that the unit has failed to light within the specified time. Checklist: ? Check the gas supply is turned ON at the meter, and the appliance gas ****. ? Check if other gas appliances are operating such as Gas Cooker and Hot Water Service. ? Check the gas cylinders have gas, and the cylinder valve is open (LPG only). ? Check that there is gas supply to your home. Contact your gas provider to confirm this. There may be works in your area or a problem with the supply. ? The unit may require a general service. To know more about error codes, please visit the link below: http://www.climat.com.au/downloads/1224564933BrivisNetworkerSimpleInstructionsincErrorCodes1.pdf For manual, please visit the link below: http://203.47.8.188/web/BrivisInetQuest.nsf/54fb77b4318f809c4a256648001f64bb/d3f32c564c4270f24a2570070018bf64?OpenDocument
The screen on the wall has several buttons incl "fan" at the top and three at bottom..Auto, Mode and Prog. "Fan" starts...
I have brivis climate system wombat about 5 years old, the central heating fan will not switch off runs continuous, what...
brivis ducted heater making a banging noise every time it lights the burners
I have a Brivis Buffalo 85 ducted heating unit. My ducted heating continually blows cold air through vents. The fan is...
I have a brivis buffalo of about 20 yrs. My ducted heating continually blows cool air through vents. Just check the...
Hello, can anyone help me to turn my furnace fan on during the summer months for air circulation? I Have tried a...
anna41 Thank you very much for your advice and will follow up with all your solutions to the problem.
Very quick response
thanks
Jun 28, 2010
