Question about Electrolux Lux 7000 Bagged Canister Vacuum
Temperature light keeps coming on
For a while now, the motor was making a whining noise when we turned off the vacuum. I kinda wondered if the bearings were going out on the motor.
Now, the vacuujm runs for a vey short time, the temperature light comes on, and the vacuum shuts off.
Are the bearings shot on the motor causing it to overheat? Or could there be a "cheaper" problem with it?
Thanks for any help you can provide!
    President:
  • 1,673 Answers
The whine tells you taht the bearings are bad. Now they may be putting a drag on the armature and causing it to shut down after getting hot. You will have to replace the motor.
Posted on Apr 20, 2008
Dyson dc17 makes loud noise on carpet setting. It's like a high pitch ringing almost but won't make the noise on hard floor, only carpet setting. Ive checked for blockages and cleaned all parts but makes...
It is probably the brush roll motor making the noise. Remove the brush roll & belt and turn both motors on. If you do not hear the noise when both motors are running the noise is likely coming from the brush roll
Nov 02, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
My vax vacuum has started making a high-pitched whining/whisting noise
Ususally this is caused by a forein object has gotten hung in the suction impeller attached to the motor. the noise flucuates due to the housing flexes with the movement of the handle and rod. the housings are usually made of plastic and something very small can easily get stuck in it and stay for a very long time. The vacuum needs disassembled and the forien object removed from the fan housing...
Hope this helps
Sincerely
Roger
Feb 07, 2012 | Vacuums
Very loud "jet like" noise,please
Vacuums are noisy, but shouldn't sound like a jet.....
Trying to find out what is wrong depends on what kind of noise it makes, i.e. high squeal, vibration, whining and where it comes from.
Here is a webpage with troubleshooting advice on noise in vacuum cleaners. Hopefully you should be able to track down the problem. http://www.ehow.com/how_7493926_fix-noise-vacuum-cleaner-motor.html
If you need further help with repairs, please reply back. Thanks,
Handie Andie
May 09, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
Dyson vac has started to make a loud whining noise when the roller brush is turning
Does the whining noise come from the motor or the brush area?
If it's from the brush area, it's probably the belt. Check to be sure the belt is not worn. Sometimes belts will glass up and slip. Also, check to see if it is still completely on as it should be. You may need to replace the belt.
I woHope this helps, if it does, please place a vote for me. Thanks,
Handie Andie
Mar 28, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
There are sparks coming out of the motor housing. It is making a high pitched whine.
I'm sorry to tell you that the motor is more than likely done.
Generally you will have a burning smell associated with the sparks and whining. You can source a motor at your nearest hoover dealer, but depending on the age of the machine, you may just want to consider a new one. It is hard to say.
Nov 05, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Loud whining sound and wont **** up the water on my f5914-900
Loud whining noise generaly indicates motor issues, which also provide suction to extract water from carpet.
Apr 10, 2010 | Hoover SteamVac F5914-900 SpinScrub...
The CV750 stopped working. It will come on sometimes but most of time it will not work. I installed new bag and cleaned filter. Green light on side of unit is on. Switch on side of unit will not make it...
The motor may have a sticking brush or a dead commutator segment. Turn off power to the unit to check for sticking brushes. Reapply power, does it now run? If not, shut it off, physically turn the motor a few degrees, and reapply power. If it still doesn't run, look for loose wiring around the motor. If it does run, replace the motor armature or the entire motor if the armature is not available as a separate part.
Oct 18, 2009 | Broan-NuTone CV750 Central Vacuum
Kenmore upright vac model 33922 - good suction but developed loud whining noise after accidentally vacuuming room without bag. Added bag and changed both filters. Still makes noise. How can I stop noise?
The bag is the first stage in your filtration. Most times what you did will draw fine dust right through the filters and into the motor itself, affecting the bearings and clogging the motor fans, throwing them off balance.
The fact that there is a new noise would seem to indicate bearing problems which will only worsen unless the vac motor is dismantled, fans cleaned and bearings either replaced or cleaned and repacked.
Sep 14, 2009 | Kenmore 33922 Direct Drive Bagged Upright...
Dyson vacuum cleaner doesn't start
check if something is stuck to keep the motor from turning
Mar 18, 2009 | Dyson DC05 Bagless Canister Cyclonic...
My vacuum won't work-
sounds like the motor might have bit the dust.try this,unplug the vacuum and reach under where the brush rolle is and try to turn the roller by hand a few times,if you can't turnit then then the roller is jammed.take the belt off and then turn it on and see if it runs then.let the motor cool down first the motorguard might be keeping it from running.just let it cool down for about 20 minutes then try it
Feb 08, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Electrolux Lux 7000 Bagged Canister Vacuum Logo
352 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
