You can change it. just right click on the desktop -> properties -> settings -> then on the screen resolution adjust it in lower pixels
First of all, by the sounds of it, it is booting to a very low resolution. ;)
Assuming that you run Windows, right click your desktop and go into either preferences or display settings. In one of those tabs, you'll be able to adjust your screen resolution. Usually the maximum setting it gives you is what your monitor is designed for. If not, just play around with the settings until you get the right resolution. If you screw something up, it's not a big deal; just don't do anything for a bit and it'll revert to the previous setting.
I hope this helps!
