Question about Memorex MVD2042 DVD Player
Can't get remote to work
We replaced the battery but can't find the back to the remote and so can't get it to work.  Any advice?
  • KHall867 Apr 28, 2008
    We have two of these machines - on one the remote works, on the other machine, the same remote does not work. So it is NOT the remote. One of my machines does not respond to the REMOTE. Any ideas?? We are past our 90 day return window. thanks!
  • 667 Answers
Do you want a way to hold the batteries in or find a place to get a new one? ( maybe a universal generic)
Posted on Apr 16, 2008
Would someone recommend a universal remote that will work with the Koss KS5 190,expert advice don't buy anything from a flea market
thats not expert advice,that is rookie advice,
Remotes com Search Results
Replacement Remote for KOSS KS5192 KS5190
KOSS Replacement Remote Control for KS5192 KS5190
now,here is some EXPERT ADVICE! when at flea markets,buy every remote control you find and sell them for 35 bucks a piece on ebay!!
May 14, 2015 | Koss Televison & Video
I have 2 craftsman garage remotes and they do not work. Replaced batteries and still not working. The numbers for the remotes are 139.18790B and 139.18791B. Needing some advice please
First question Did they work with this opener before? If Not then they probably need to have the code set in them. There should be a set of switches inside the remote that are used to match it to your opener. If they worked before then it is possible that they have a bad circuit on the board or just a bad battery connection.
Sep 12, 2014 | Building Materials
Remote quit working. Even replaced the batterys.
Try this advice:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Jan 22, 2011 | Bose Wave Radio
Brand new replacement RM-ED0009 remote will not function. New batteries fitted. Suspect TV fault - advice, please
it might be from the TV remote sensor. To confirm this, test the remote with another TV and if the remote works, then it would be obvious that the remote sensor of your TV is dead.
Take care.
Mar 10, 2010 | Televison & Video
Alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Feb 20, 2010 | Televison & Video
I had packed away my sony system for a while, I
The remote has not calibration to it try cleaning the lens on the radio itself and see if that helps if it does not you might want to get a univeral there only a handful of bucks. My suggestions would be www.remotes.com.
Thanks for using fixya.com
Dec 02, 2009 | Sony CMT-EP707 CD Shelf System
Sony RM-ASP001 for 400 disk changer stopped working
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Dec 23, 2008 | Sony RM-ASP001 Remote Control
Problem with wii controller charger
Sounds like you broke your remote to me. did the batteries leak on your remote? If so, try to clean the contacts on the remote (the spring on one side and the flat one on the other). You may need to use a nail file to scrape off the gunge.
Now, why did this happen? Did you put rechargable batteries in your wiimote before you put it on the charger? And if so, did yo put the CORRECT TYPE of rechargables? There's a big difference between nickle cadmium (Ni-CD), Nickle Metal Hydride (Ni-MH), and Rechargable Alkaline. Putting the wrong type of battery, or a non-rechargable battery into the wrong recharger causes leaking, explosion and fire... as the charger and the batteries warn you of all over.
Feb 04, 2008 | Nintendo Wii Console
Zenith B27A11Z remote stop working
remove the batteries from remote ,then put im back and then try again
Jan 01, 2008 | Zenith B27A11Z 27" TV
Safe mode
To get your 550 out of safe mode, follow these steps.
1. Remove the batteries.
2. Hold the '2' button down.
3. While still holding the '2' button down, replace the batteries.
4. The remote will boot into the normal functionality.
Note: If the 'Off' button is held down while inserting the batteries, the remote will boot into 'Safe Mode'.
Sep 29, 2007 | Logitech Harmony 550 Remote Control
Memorex MVD2042 DVD Player Logo
29 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
