Question about Cyberhome CH-LDV 700B Portable DVD Player
Unit will not recharge - Cyberhome CH-LDV 700B Portable DVD Player
  • Anonymous Apr 26, 2008
    i try to charge it but it does not do it i think it needs a new battery that is what i think but if you have a sulution to help me i would appriate it thank you all
    Problem Solver:
  • 3 Answers
I had to contact the company and tell them the problem. They then sent me a separate battery conditioner/charger. Once they found out the manufactured date they sent it to me for free.
Posted on May 14, 2008
No power when recharging the unit what is wrong?
it was a plug to recharge but after plugged in to recharge it would not charge
Nov 07, 2017 | The Audio Players & Recorders
How do i recharge the gl-pac-08e4
needs to be recharged by a trained technician
Aug 04, 2014 | Soleus Powered by Gree Powered by Gree...
Can a fedders air conditioner A7Y15F2A-E be recharged?
Hello, anytime the unit does not blow out cool air I like to start with checking the airflow, check the filter and the evaporator coil for a buildup of dirt. If that check out ok then either the unit has a refrigerant leak or the compressor is not operating if the compressor is running than the unit is low on refrigersnt and can be recharged. In order to recharge the unit a piercing valve must be installed on the low side of the system, most window units do not have valves so one must be added to be able to charge the unit.
Jun 29, 2012 | Fedders X Chassis A6X08F2A Air Conditioner
How do you put freon in a whirlpool window unit
you will need a AC Tech to first 'repair' the leak and then to 'recharge' the system. Also, the Tech may have to 'weld in' service valves on the unit if it does not have them - which most window units do not have.
Note: unless you've had a 'leak' you'll never need to recharge the system. I would 'be sure' you needed to recharge the unit before having it recharged.
Sounds like you might really need to have a AC Tech look at the unit before you do anything.
Aug 04, 2011 | Whirlpool Electronic Window Air...
Ac window unit, can it be recharge?
Hello, yes the Ac can be recharged however you will need to install a piercing valve on the low side of the system in order to recharge the unit.
May 05, 2011 | Heating & Cooling
I am trying to recharge my Breezaire WK8000 cellar unit (which Breezaire said could be done), but the unit has Rivits at all corners. How do you get to the compressor to recharge this unit?
DRILL RIVETS OF WITH A 1/8 DRILL BIT AND ADD AN ACCES VALVE.
UNIT SHOULD NOT BE RECHARGED WITH OUT PRESSURE TESTING UNIT AND FINDING THE LEAK FIRST, OTHERWISE THE FREON WILL SCAPE AGAIN
Apr 30, 2011 | Breezaire WKE8000 Wine Cellar Cooling Unit
True GDM-12 - Unit runs, but won't cool below 60 degrees,
Is it very hot out side the unit.recharging may not hurt is it cleaned the lint could be trapping the radiator were the coolan goes through to cool down try cleanning underneath before recharging
Jul 26, 2010 | True GDM-12 Refrigerator Commercial
Has leaked out all 'gas' from the cannister to the down tube. Can this be repaired and recharged?
If by 'gas' you mean refrigerant, then yes, it can be recharged. However, in order to legally recharge a refrigeration unit with refrigerant you need a special certification from the EPA. I recommend you get a certified technician to take a look at your refrigerator
Mar 23, 2010 | Dometic RM2620 Refrigerator
Identicial problem, and yes in the same room for 3 years
It's a sealed system wich normally doesn't need to be recharged. (compare with a fridge)
Frans Verhees
service engineer.
Sep 17, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Batteries will not charge
May I ask which type of rechargeable batteries you are using.
NiCad or lithium Ion?
Also, any rechargeable battery will not charge unless the unit is powered up or "running".
Feb 18, 2009 | Recoton Advent Advent AW-820 Main / Stereo...
Cyberhome CH-LDV 700B Portable DVD Player Logo
35 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
