Question about Whirlpool ED5SHAXM Side by Side Refrigerator
Rfrig Whirlpool ED25PQ
No water solenoids appear good. Jud
The door on my ice maker does not close so frost develops on the maker itself. How do I fix this?
Posted on Jul 14, 2008
Hi there my ice maker on a whirlpool model#ED25PQ,is making ice but the cubes are clearer looking than in the past also when water fills in to make new cubes it sprays all over refrigerator and water goes...
A) If water sprays like you say then there might be air trap on the line.
b) But most likely your Ice maker fill valve me be not closing and overflowing and creating the freezing mess.
Feb 14, 2015 | Whirlpool Refrigerators
Whirlpool side ed25pq
Water filters are located either in the toe kick at the very bottom of the unit, or inside the fridge, usually in the upper right corner. If equipped with one the filter number will be printed on the filter it's self. You provided a partial model number. Pleazer Appliance...
May 04, 2014 | Refrigerators
My ice and water taste funny in my Whirlpool ED25PQ. How can I soleve this issue
You can install a filter in the incoming 1/4" line leading from the wall to the refrigerator. These can be purchased from Lowe's or Home Depot and come with installation instructions. Be sure to buy the whole new filter system not just a replacement cartridge.
If you have copper water line you will need a tubing cutter to cut the supply line for filter installation. If the line is plastic a sharp blade will do.
Good Luck
Sep 06, 2009 | Whirlpool Freezers
ED25PQ quit making ice. Water dispenser still working
Pour about 1/2 cup of water into icemaker . If it harvests(dumps) then problem is the water valve.....if not , then icemaker is the problem .
Jun 26, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
WATER DOES NOT DISPENSE FROM DOOR
Sounds like the water solenoid valve poppet is sticking in the closed position. You will need to replace the assembly. It is located behind the fridge at the lower corner.
Jun 18, 2009 | Whirlpool ED5SHAXM Side by Side...
Ice and water don't work
This could be several reasons, water valve on back not working, thermostat in ice tray not working, heating element below ice maker not working, we just need to start with the dual water valve on back first. The side that feeds the ice maker needs the solenoid checked. I am ready to help you solve this, Let me know, Thanks, Sea Breeze
Apr 16, 2009 | Refrigerators
Whirlpool side by side refrigerator, model # ED25PQ
Under the right side of the fridge in the back there is a dual valve for water and ice. Try changing it out, most likely the ice side is not working. Make sure you unplug the unit first
Nov 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water dispenser on my Whirpool side by side refrigerator Model ED25PQ is not working. How do I fixed this? Is there anything I should check?
did u check the value from your water line? the value could be shut. If the value is on...did you connect it correctly to your water system? let me know!
Jun 16, 2008 | Whirlpool Refrigerators
Whirlpool ED5SHAXM Side by Side Refrigerator Logo
649 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
