Question about Whirlpool Duet GHW9150P Front Load Washer
FH on Screen
Im having with my washing machine because it starts
and then stops after a few minutes.
The screen is showing "FH", and after reading the manual, it seems that
means it is a "water inlet problem - no water or insufficient water supply". Below is
the link to the PDF file, and on page 17 it describes the issue under "troubleshooting"
http://www.abt.com/images/products/BDP%20images/8182400.pdf.
I have called in my plumber, thinking not enough water is being supplieed to the washer but he checked the pressure it sems to be ok. I unplged and restarted the machine but a few min into starting it shuts down and give me FH on the scrren. Any help would be great.
Thanks
Rai
If you have water pressure ck the supply hose, take it off and make sure there is nothing obstructing the flow of water.
Posted on Apr 16, 2008
FH error code frustration
Replace main control board and pressure switch together .
May 26, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whin washing 30 min left and it stops and flashes FH
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Inlet valves can be purchased thru the net and fitted by you easily.
Mar 12, 2013 | Washing Machines
It has stopped washing and is flashing FH what is the problem and what should I do ??????
First try turning off the machine for 30 minutes. Still FH? Next check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
Mar 06, 2013 | Kenmore Washing Machines
Fh showing on my kenmore washer
Feb 27, 2013 | Kenmore Elite HE4 Electric Dryer
Our LG washing machine 5.5 Kg WD-85260 NP is having problem as it is showing IE on the screen and then stops. So we have to restart the machine again. What is IE?
IE on the screen of an LG washing machine can mean a lot of things.
1.It can mean that the washing machine can't fill up with enough water in 8 minutes time.
2.It can also mean that the water hose screens are clogged up with dirt and dust.
3.It can mean that you hoses are reversed. Your cold water hose might be connected to the hot water hose.
4.The water valves might not be screwed in completely.
If you need to reset your machine you can just unplug the machine and hold the start/pause buttons for a few seconds.
Jan 16, 2011 | Washing Machines
Washing machine whirlpool awm8123/1 stopped and FH on display
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR If the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. Press PAUSE/CANCEL twice to clear the display.
check the fill hose screens or you my have to repalce water valve make sure water is turned on....
Sep 19, 2009 | Whirlpool AWM8123 Front Load Washer
After 27 minutes into wash get an FH error
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Aug 02, 2009 | Washing Machines
My duet washing machine throughs out a FH code
FH is a water inlet related issue, make sure your cold water supply is working correctly, sounds as if its trying to rinse(cold water) and has no water to do it
Dec 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer trouble
fh means no water coming into washer. remove cold water line from back of washer and see if the screen in the valve is clogged. if so, remove screen and clean it, if not replaced water valve
Nov 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
140 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
