Question about Mitsubishi WD-52627 52" Television
Ballast Assembly Circuit Board
This is related to another post but I have more specific information now. I have Mitsubishi WD-52627 DLP. It makes a buzzing/crackling sound when turned on and there is no picture. The lamp is fine. Yankeegurl pointed me to the ballast assembly in the area of the noise. (Thanks Yankeegurl!) I looked back there and sure enough I could see what looked like sparking/glowing that coincided with the buzzing. I can see the part on the circuit board that has the problem. I have the service manual and I opened up the tv and took a picture of the board. The part with the problem is circled. Anyway, I called Mits and they told me they would not sell me a new board, they would only sell to an authorized service center. They said the board would be just shy of $400. Does anyone know if there is a service center for replacing parts on these circuit boards rather than just replacing the entire board. If I can have the part replaced for even half of what the board would cost I would probably go that route. I am not having any luck finding a place but I thought someone here would know. Just want to make sure I have explored all options.
Thanks experts!!
If that is sparking the ballast is ok. Change the bulb although it looks ok it is not firing up. also make sure the bulb is plugged securely in its socket.
Posted on Apr 16, 2008
You guys are going to get killed messing around !
Posted on Apr 22, 2008
Bulb goes out after a few minutes
The ballast for the bulb is the culprit. That is the circuit board directly wired to the bulb. You can get a replacement on line at:
TV Parts Universal TV Stands DLP Chips ShopJimmy It's not difficult to change it yourself .
Aug 08, 2015 | Mitsubishi WD-52525 52" Rear Projection...
How can i get to the ballast board are fmt board on a mitsubishi wd62528 62 inch tv?
You're asking the way to access the ballast board, I assumes and posts this solution. You have to disassemble the set. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter" Disassembley procedure is given in detail with illustrations. I can't include all that illustrations and descriptions here by this window.
Apr 11, 2013 | Mitsubishi WD-52525 52" Rear Projection...
I need a lamp ignition circut board for a mitsubishi model WD-57734 DLP TV
you should be able to get the ballast from www.tvrepairworld.com if you dont see it hit the contact button to leave an email they respond quickly.
Oct 26, 2011 | Mitsubishi WD-57734 57" HDTV
Bad ballast board
your model uses the 938P127010 ballast which is available from www.tvrepairworld.com under the Mitsubishi DLP parts its 65.00 for a new ballast.
Aug 09, 2011 | Mitsubishi WD-60735 Projection Television
Mitsubishi wd-52627 dlp hdtv doesn't appaer as
I have seen alot of the Mitsubishi DLPs to get very dim and the colors appear dull and the cause was almost always caused by the small front mirror needing to be cleaned due to a dust build up. If you need assistance with how to access the mirror on that model send me a email and I will send you info on how to access the mirror. The file is too large to post here. slinteriors@yahoo.com
Jun 07, 2011 | Mitsubishi Televison & Video
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Where is the ballast board on a Mits. WD-52627
In order to reach ballast you have to remove optical block. Ballast is usually covered with metal shield. It's located on the right hand side of optical block (if to look from the back of the TV). and it have two black thick short wires that connected to the lamp cartridge socket.
Regards.
Russ.
Aug 12, 2010 | Mitsubishi WD-52627 52" Television
Looking for a ballast part number and price Mitsubishi WD-C657
encompass.com or parstore.com is a good store parts.
Just provide model number tv.
Thank you
Aug 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I cant find a part for my wd-52525
What makes you think the ballast is bad. Thats one part on the Mitsubishi DLP that very seldom needs replacement. Whats the symptoms with your WD52525
Jun 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52627 52" Television Logo
329 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
