Question about Singer Featherweight 132Q Mechanical Sewing Machine
My thread often becomes unthreaded from the part that raises and lowers the needle causing the thread and fabric to jam up
  • mctigerlily Mar 25, 2009
    I have the problem of the lower looper coming unthreaded, but it DOES NOT break! It seemingly comes out of the lower looper. HELP!
Your needle should not come unthreaded in the middle of sewing.. if it does, it is because the thread breaks. this can be a simple tension problem or brittle thread.
if you are talking about at the beginning of sewing that the needle comes unthreaded, then you should just pull out 6-8 inches of thread through the needle before putting your fabric under and begin sewing.
i hop that helps.
Posted on Jul 16, 2008
Thread suddenly jams , bobbin won't turn,after cleaning, re-threading etc makes one stitch with wheel turn then jams again.
Besides installing a brand new needle (which you've already done), unthread the top thread. (Cut the thread below the spool, raise the presser foot, and pull the thread DOWN from the thread tail end--NEVER PULL thread UP!)
ALWAYS RAISE the presser foot and rethread the top thread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point and then tweak it so both threads meet in the middle of the fabric.
Jun 24, 2017 | Sewing Machines
My thread keeps breaking and coming unthreaded
Install a brand new needle. Make sure the needle, thread, and fabric are compatible.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwjA9Nbo-57NAhUHRVIKHf4hDmgQFggzMAI&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
http://www.schmetzneedles.com/all-about-needles/
Use good quality thread--avoid old or bargain bin threads. Sometimes changing to a different thread will alleviate the problem.
Remove the thread from the machine. ALWAYS RAISE the presser foot when threading. Rethread from the beginning. Verify the thread path is correct. Be sure to pull at least 6 inches of thread through the needle eye and from the bobbin.
Set the upper tension to the midway point and retest your machine. The ideal tension is achieved when the upper and bobbin threads meet in the middle of the fabric.
Make sure the thread is not catching on something causing it to break. If it's catching when the needle sinks into the fabric, check there are no burrs or sharp nicks in the bobbin area or on the needleplate.
Sewing Machine Problem 1 Thread Breakage
Why is my thread breaking
Sewing Machine Thread Keeps Breaking
Singer Sewing Machine Breaks Thread
Jun 11, 2016 | Sewing Machines
Why does lower looper thread keep breaking?
Usually, thread breakage is due to incorrect threading. When a thread breaks or becomes unthreaded, the best policy is to remove all the thread and rethread from the beginning. Be sure to RAISE the presser foot before threading to allow the thread to seat properly in the tension disk. Also, be sure to thread each in the order specified in the manual or it is unlikely your machine will ever function properly.
Jan 28, 2016 | Sewing Machines
Bobbin unthreads my needle and will not sew
Try changing the needle to a new one, size 12, a dull or bent needle will cause this.
Jan 28, 2015 | Sewing Machines
My singer HD 110 will sew a bit then suddenly the needle will slow down to a stop & the handwheel seems stuck, yet the motor is still running.
Hello there! Make sure your pattern selector is compatible with the presser foot. Good idea to test with a straight stitch setting: Tension: 4. Width:4-5. Length 5 after you insert a new needle and re-thread machine. Your previous needle may have become bent when machine malfunctioned. Use fabric compatible with needle size. Always raise presser foot when threading! Then always lower presser foot before sewing. Remember to use blue tip scarf needles with synthetic fabric silk thread 50. Purster thread 50, mercerized cotton thread 50-60; #11 or #9 for fine or lightweight fabric with silk thread 50 or fine Pollyester thread; #18 leather needle for leather, #14 - 16 denim . Jimmy Sweep out shuttle carefully with small brush for broken threads and lint.
Mar 31, 2012 | Singer Sewing Machines
I needle comes unthreaded whenever we try to sew. We've both tried numerous times and it doesn't make a sitch. The bobbin seems to be done correctly b/c the bottom thread comes up with no problem....
first let's deal with the needle becoming unthreaded, Keeping the needle threaded is easy, always keep thread tails of 3 to 6 inches on the top thread & bobbin at all times, & make sure the thread tail are pulled behind the needle before you start to sew,, this will ensure that the thread will not come out of the needle when you start to sew.
you mention the fabric is thin,, do you have a needle that's right for the fabric your sewing?
thin fabric needs a different needle than blue jeans fabric, check your top tension & see what the setting is on, usually 3 to 5 is good.
when the needle & thread are right for the fabric then the sewing is good.
also clean under the needle plate & bobbin area for loose threads or lint
also it's a possibility that the machine could be out of time & would need to be serviced by a sewing machine repair shop-as they have the tools for the job
Sep 22, 2011 | Brother LS-2125 Mechanical Sewing Machine
The needle comes unthreaded when machine is started brother 2600 I
Pull both bottom and top thread to the back of the machine for about 10 cm or 4 inches out before you start stitching. Hold them loosly. Put fabric under the foot (the whole foot, don't start at the raw edge), make sure foot is down (to ensure tension). Start with the needle in the top position.
Your needle is likely to become unthreaded when the needle goes down and back up. But not if you hold the thread (and enough of it). Happy sewing.
Dec 24, 2010 | Brother XL-2600
Hi, I'm trying to sew a silky fabric and the stitches on the bottom keep getting jumbled and the top thread breaks
My guess is that you have lost all of your upper tension and you may have your needle in backward.
Unthread the machine.
Raise the presser foot. Turn the handwheel until the take-up lever is at it's highest position. Set the upper tension dial/knob to 5. Remove the needle and replace it making sure that the flat side of the needle shank is to the back. Thread the machine.
With the presser foot up, the upper thread should pull through easily and then grab when the presser foot is lowered.
Test sew.
The upper tension pulls the stitches up and the lower tension pulls the stitches down. When they pull properly, the stitch is even.
Oct 29, 2010 | Husqvarna Huskystar 215 Sewing Machine
Thread jams in bobbin case
Open the bobbin area and make sure it is clean.
Change to a new needle.
Thread the machine with the presser foot up.
Make sure the bobbin thread is feeding in the correct direction from the bobbin spool and through the guide on the bobbin case.
Take hold of the end of the top thread and lower, then raise the needle to pull the bobbin thread up.
Take hold of both thead ends and pull them under the presser foot and to the back of the machine.
Place fabric under the presser foot. Lower and hand walk the first couple of stitches.
When sewing, and you need to stop to adjust the fabric, make sure the needle is down into the fabric. This will keep the stitch from malformation and causing a possible tangle.
If you need a manual, you can download one free at the Brother website.
Mar 20, 2010 | Singer 3116 Simple
The top needle unthreads after just a few stiches. I have a Singer 2950 and am new to sewing.
Are you saying that the thread is breaking?
CAUSES of upper thread breaking
needle is in backwards
improperly threaded
tension to tight
needle bent or blunt
thread to coarse for size of needle
needle too long for machine
burr on needle
tension discs worn so that thread works in grove
neele too fine for size of thread and fabric
lint or dirt around bobbin case holder
irregular sewing speed
AND THE BIGGEST PROBLEM IS:
threads not properly pulled back under pressure foot when starting to sew
This means, Have enough of the upper and lower thread pulled to the back and hold for the first 2-3 stiches,
Do this every time and it will become second nature and you will do it automatically
Aug 28, 2009 | Singer 2950 Mechanical Sewing Machine
Singer Featherweight 132Q Mechanical Sewing Machine Logo
260 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
