Question about Kirby G4 Bagged Upright Vacuum
Good armature maybe needs new brushes
I have a G4 kirby. Can you replace the brushes? If so where can I buy them? My armature looks good but I think my brushes are bad. I cleaned the armature with a pencil erasure and it worked for a little while then I noticed alot of blue sparking on the armature.I could not get it to come on again. I think this is due to carbon build up. Can I clean the brushes out and be fine or do they need to come out and replaced. My vacum is 11 years old? What do you suggest
  • 357 Answers
Carbon brushes wear over time and may need completely replaced...it doesn't cost a lot and i have guides available for the repair. Try my troubleshooting guide....
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
I have the brushes available as well. The changing process is also outlined in my guide for changing the power switch.
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope this helps...
Marci
Posted on Apr 21, 2008
    Scholar:
  • 116 Answers
Parts can be obtained from the Kirby service centre in the UK.
Tel 01515216688
email service@kirbyvacuum.co.uk
Posted on Apr 19, 2008
    President:
  • 1,673 Answers
You can replace the carbon brushes and most repair shops should have them. Also tho, the armature could be causing the problem, if you put in new brushs and it still arcs badly, then the armature is bad.
Posted on Apr 16, 2008
Kirby G4 spaking after repairs???
Often the armature needs to be resurfaced when the brushes are replaced...Why were you replacing the brushes? Did the fan break?
It's really not that expensive to take it to a Kirby dealership for repair. Will run forever....Also it came with a lifetime rebulid warranty so even if it's trashed you can ship it back to the factory for rebuild for like 200 bucks :)
May 26, 2013 | Kirby Generation 3 Bagged Upright Vacuum
Good Morning, after plugging the kirby in, I began to vacuum and a light started flickering from the back of the motor and then the sound while vacuuming starting getting louder and the light flickered...
The carbon brushes in your motor are worn out and "sparking" against the motor armature. DO NOT operate the vacuum in this condition or you may damage the armature so badly it will need replacement. Most vacuum dealers can replace the carbon brushes and resurface the armature. This should cost $40 to $50. If you need a new armature you are looking at $100 or more.
Jul 01, 2011 | Kirby G4 Bagged Upright Vacuum
Hello can you help me please? I have a Kirby G4 vacuum cleaner, It did work ok until it started to give off burning smell and lots of sparks from the brushes. I have changed these brushes, the motor still...
Some debris, even sand or dirt, probably got into the motor, causing damage to the armature. If this is the case, you will need to replace the motor. The burning smell from the motor is generally a sure sign of a bad motor.
Jan 02, 2011 | Kirby G4 Bagged Upright Vacuum
The motor shaft on my G4 kirby gets very hot....any thoughts
take it in for its service,sounds like it needs a good cleaning.
Oct 19, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby g4 brush wont turn belt ok
your belt has probably been stretched to the point where it will not work so good.
Jul 02, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I NOTICED SPARKS INSIDE THE UNIT WHERE THE HANDLE ATTACHES TO THE MOTOR....NOW IT IS NOT WORKING WHAT CAN THIS BE?
DO NOT TRY TO TURN THE KIRBY ON ANYMORE BEFORE YOU GET THIS REPAIRED!!! Your Kirby needs carbon brushes and if you don't already need a new armature, the worn out brushes will destroy the armature that you have. Here is a guide that will help you get down to the carbon brushes to change them...
It is a guide to replace the power switch, but will give you the step-by-step to get down to the carbon brushes.
Hope this helps,
Marci
Jun 10, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Sparks from the Kirby Motor
1. Do you think this may be the problem?
YES
2. How come it continues to rotate?
Motor armature consists of multiple coils and just some of them burned so even though it keeps spinning it does not function properly.
3. Do I need to replace the armature?
We have switch replacement instructions HERE and they will take you as far as accessing the motor. We do not have motor assembly instructions yet but if you get that far - motor is not that hard to reassemble. You may have to spend some time getting tolerance ring back in and make sure you install finger spring properly.
Good Luck
Dec 28, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Carbon Brushes wearing out quickly on Kirby Heritage II
4 possible reasons.
1 – one or both bearings are worn so armature (rotating part) wobbles as it is spinning and cause motor brushes to wear fast. Solution – change bearings too.
2 – Whoever replaced brushes – did not use some brush seating sticks to make cmutator smother and contour brushes to the shape of the comutator (not likely). Solution – appropriately install new set of brushes.
3 – Comutator is so warped that seating sticks do not help anymore – solution – new armature or turn the old armature.
4 – The fact that ONLY ONE brush was worn may mean that there is something wrong with the brush or housing. Maybe it could not move freely within the housing? I think this may be most likely cause it it may be a combination of all 4.Is it worth to fix? Hmm depends how much will it be. If this is 100+ - I’d say get newer Kirby for 300 ad enjoy the tech drive (Heritage does not have tech drive so it is much harder to vacuum with than the newer models)
Nov 05, 2008 | Kirby Heritage II Vacuum
G4 model is burning
May be the carbon brushes. DO NOT run the vacuum until you check them. If they are worn out, they can damage your armature and that is expensive to replace. Try my troubleshooting guide. It helps with do-it-yourself Kirby repairs. You'll also find links to directions and free repair guides!
Aug 22, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
523 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
