Question about Insignia 26 in. LCD Flat-Panel HDTV
Bad color color sucks - how to fix?
  • 70goathead Jul 13, 2008
    Same problem except mine is green and black.
I have new a Insigna LCD 37" inch TV . LAst month i bought this TV and now the problem is with the colors since last 1 week am havng issues with color there is no color all am geting is orange and black thats all. Need help i tried to change settings but nothing happend its still the same.
Posted on Apr 17, 2008
How to run a cigarette lighter for a 97 Saturn sl2 all the wires are taped off and many colors
Hi Nate:
Black is usually ground, so check with your continuity meter between a black wire and a frame component such as the bracket that the brake pedal is mounted on. The outside of the lighter will need to be connected to ground.
Check to see if there is a fuse for the lighter. You may be able to see the color of the wire. If not, you could use trial and error and your meter to find the wire. Pull the fuse, and from the "downstream" side, check for continuity to the individual taped off wires. Eventually you will find the right one. It will need to be connected to the center or positive terminal of the lighter.
Put the fuse back in, and it should work.
Now that I've tried to help you, I get to give you some more free information:
- I am a cancer survivor.
- Surgery sucks.
- Radiation sucks.
-Chemotherapy sucks.
- Central nervous system (spinal cord) chemotherapy REALLY sucks.
- Cigarettes cost a LOT of money. If you don't think so, don't smoke but put $10.00 a day in your savings account. Total $3,650 a year.
- Your car will smell bad. (so will you and chicks will notice)
My advice? Use the lighter as a power port for charging your electronics.
If that's what you were going to do, then pass on my un-necessary information to some young person who is just starting to smoke.
Cheers in good health!
Jul 09, 2016 | Saturn Cars & Trucks
White smoke coming from tail pipe and wont stay ruanning
Failed Head Gasket
Major Repair
Coolant into exhaust-- no matter
what the fix is
Nov 27, 2014 | Mazda MPV Cars & Trucks
Is There Any Way To Fix Cosmetic Damage On A Gameboy Color Plastic Shell?
There are videos on youtube that will show you on how to fix the plastic cover parts on the Gameboy colour system since the Nintendo repair center no longer fixes them which sucks but all well. 2q==
Aug 24, 2012 | Nintendo Gameboy Color Console
Sony color sucks model kdfe42a10 piece of
Please follow the instructions below to check that sometimes the lamp cove does not properly closed,
1. Remove the Lamp Cover.
2. Turn the lock to the OPEN position to release the Lamp Door and remove.
3. Pull out the Lamp Assembly, then reinsert the Lamp Assembly until it is locked into place.
4. Replace the Lamp door and turn the lock to the CLOSE position.
If the problem persists then you have to replace the LAMP Assembly, For estimate contact any nearest SONY SERVICE CENTRE.
Thanks for using fixya.
Nov 17, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
White screen with some colored vertical lines
christoph430. Your TV is hosed. Olevia will not fix it even if it is still under factory warranty. They are having lots of issues with their products and it will be too costly for them to pay for the repairs they should be covering. They are hoping you have an extended warranty through whomever you bought the TV from and will let that company deal with what should be THEIR problem. The repair company has to try to fix the TV at their cost. Nothing but a scam. We will never buy an Olevia TV again. Respond to rlarocque1@cox.net if you would like to understand details about our frustration with them. Unbelievable. Sorry for the bad news.
Feb 23, 2009 | Olevia 237T 37 in. LCD TV
No dial tone or characters on hand phone,Phone charged for 12 hours.could battery be bad
this company sucks I call it and it just has automated features and hangs up where is the real customer service...
Jul 03, 2008 | Xact Communication Xact XG2400 2.4 Ghz...
Converge problem
That sucks. I just did my convergence and now I am having mixed colors that I have to adjust. Sucks, Good luck!
Mar 29, 2008 | Philips 60PP9202 60" Rear Projection...
Green is tilted
Put the convergence controls at roughly center and manually adjust the green tube for the best pix. Then, go back and set up your electronic convergence and see what that does for you....accordianman
Feb 24, 2008 | JVC AV-56WP74 56" Rear Projection...
Color changes
Your tv has three crt guns that correspond to how it makes colors.
If its just one color acting weird it might be the crt gun for red. That sucks cause it will be hard to replace. I think its possible to fix it but it might not be worth it... Sorry...
Feb 20, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Color print lines
try to replace with colour catridge bye
Sep 24, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Insignia 26 in. LCD Flat-Panel HDTV Logo
493 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
