Question about Dryers
Fan My fan takes about ten minutes to start turning once switched on. I can hear a whiring at the motor, but any assistance by moving the blade does not help.It is like a resistance which it has to overcome. It was OK when first bought but after 2 years developed this and is getting worse ie takes longer to start turning. Regards Deeno
  • Anonymous Aug 19, 2008
    cleaned fan still not turning. How do do you lubricate these fans?
  • 123 Answers
I would advise taking the fan cover off and the blade off of the motor and cleaning it. (Make sure its unplugged when you do this.) Maybe hair and dust has gathered around the motor and the blade. This would make the motor have to work harder, especially if stuff is wound around the motor. Good Luck.
Posted on Apr 16, 2008
My air conditioner tries to turn on, air comes out of vents but isn't cold, and outside the blades on the AC unit are not spinning. I hear a noise when it tries to turn on but they don't start...
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor
Jun 17, 2011 | Heating & Cooling
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    When the motor starts their is a rattle noise..When I looked in the back I noticed the fan blade had some play in it could that be the problem..
    The shaft of the condenser fan motor will have some play in it, meaing if you are looking at it from the side, along the plane of the fan rotation, it will float to and from the motor itself, or left and right as you look at it from the side. You can isolate the noise by unplugging the refrigerator no less than 5 minutes, a minimum of 5 minutes and for at least 5 minutes. Before you plug the appliance back into the outlet, grab and hold onto the condenser fan blade, it will only be for a few seconds, and the motor is not strong enough that the blade will be ripped out of your hands. If you prefer, you can hold the blades in place by holding a screwdriver in between the blades instead. Plug the unit in, and if you still hear this rattle noise, its the compressor, not the fan motor. If you dont hear the noise, remove the screwdriver between the blades, and listen for the refrigerator noise as the fan motor starts up. If it made the noise then check for any obstructions to the fan blades, check that the three screws that secure the motor are tight, if they are loose, the fan will bounce. if they are tight, you probably have a bad condenser fan motor
    Nov 09, 2010 | Whirlpool (ET1MTKXKQ) Top Freezer...
    Most of the time I have to take the front off and turn the blade by hand. Once it starts it runs great until I turn it off,
    You need to take a can of compressed air and clean out the motor, this will assist in start up.
    Sep 03, 2010 | Optimus F-1660 Fan
    I have a model 5BS520C. The light works but when I pull the chain for the fan, I hear the sound of three speeds but the blades do not turn. ed.pfohl@gmail.com
    Here some toubleshooting:
    Problem 1. Fan will not start.
    Probable Cause
    1. Fuse or circuit breaker blown.
    2. Loose power line connections to the fan, or loose wire connections in the switch housing.
    3. Reversing switch in neutral position.
    Suggested Remedy
    1. Check main and branch circuit fuses or circuit breakers.
    2. Check line wire connections to fan and switch wire connections in the switch housing.
    3. Make sure reversing switch position is all the way to one side.
    WARNING: Make sure main power is turned off.
    Problem 2. Fan sounds noisy.
    Probable Cause
    1. Blades not attached to fan.
    2. Loose screws in motor housing.
    3. Screws securing fan blade flanges to motor hub are loose.
    4. Switch housing binding against the blade hub.
    5. Wire connectors inside switch housing rattling.
    6. Screws holding blades to flanges are loose.
    Suggested Remedy
    1. Attach blades to fan before operating.
    2. Check to make sure all screws in motor housing are snug (not over-tight).
    3. Check to make sure the screws which attach the fan flanges to the motor hub are tight.
    4. Check to make sure that the switch housing does not bind against the blade hub.
    5. Check to make sure wire connectors in switch housing are not rattling against each other or against the interior wall of the witch housing.
    6. Tighten screws securely.
    Problem 3. Fan wobbles
    Probable Cause
    1. Setscrew in motor coupling is loose.
    2. Setscrew in the hanger ball/downrod assembly is loose.
    4. Fan blade flanges not seated properly.
    5. Hanger bracket and/or outlet box is not securely fastened.
    6. Fan blades could be out of balance.
    Suggested Remedy
    1. Tighten the setscrew in the motor coupling.
    2. Tighten the setscrew in the hanger ball/downrod assembly.
    3. Check to be sure screws which attach the fan blade to motor hub are tight.
    4. Check to be sure the fan blade flanges seat firmly and uniformly to the surface of the motor hub. If flanges are seated incorrectly, loosen the flange screws and retighten.
    5. Tighten the hanger bracket screws to the outlet box, and/or secure outlet box.
    6. Interchanging an adjacent (side-by-side) blade pair can redistribute the weight and result in smoother operation.
    WARNING: FOR YOUR OWN SAFETY TURN OFF POWER AT FUSE BOX OR CIRCUIT BREAKER BEFORE TROUBLESHOOTING YOUR FAN!!!
    Hope helps.
    Sep 02, 2010 | Monte Carlo Dryers
    You turn key on and a noise in the heater duck start about ten pop and stop turn key off same thing
    I had a leaf in mine hitting the fan blade, once the fan was up to speed it would stop. Had to take the fan motor out to get the leaf out.
    Jan 31, 2010 | 1993 Chevrolet K1500
    The motor was making a humming sound, we stuck a screw driver in the unit to get the blades moving again it worked for a minute and now the blades aren't moving and we don't hear the hummming sound, there...
    YOUR OUT SIDE CONDENSOR FAN MOTOR HAS WENT BAD ,REMOVE THE OUTSIDE FAN AND MOTOR TAKE WITH YOU FOR A REPLACEMENT MOTOR MAKE SURE THEY MATCHDON'T KNOW WHERE YOU LIVE BUT R.E.MICHAEL CO. IS A GOOD COMPANY
    Aug 10, 2009 | Heating & Cooling
    Blades will not turn
    The motor probally damaged while you are moving the fan to the new house.
    Jul 06, 2009 | Casa Vieja Probe Brushed Nickel Ceiling...
    Hello,help please
    My fan is doing teh same thing. I have been taking the cover off and spinning the fan blade manually. It takes about 1 minute of constant manual vigorus spinning but as soon as its warmed up the fan blade spins easy and just takes off and starts working. Im sure its not the safest thing to do but it does get the fan running for the rest of the night. Once the fan has been turned off for a while the blade is hard to spin again and I have to start over with teh manual process. I am thinking its the motor being I can manually get it started by spinning the fan blade and think I will check on the cost for a new motor
    Aug 20, 2008 | Honeywell HT-800 Table Fan
    GE Nautilus dishwasher wont run
    i am taking it to the dump... throw it in the gutter and go get another...
    Nov 28, 2007 | GE Nautilus 24" Built-in Dishwasher
    Dryers Logo
    382 people viewed this question
    Top Dryers Experts
