Release the chain brake, back off the chain adjustment screw several turns, then remove the side cover and the bar/chain. Clean the engine side case where the bar fits to and run the engine for a few moments--oil should ooze out of the side port in the engine. If ok, then clean the removed parts including the two small channels in the drive end of the bar that convey oil out to the chain groove on each side. Reassemble everything and then run the tip of the bar near some cardboard for several moments at speed--it should throw off a thin line of oil onto the board. Unless you have a leaking oil line or the tank is split, you should have minimal leaking problems. Hope this helps!
