Hi I have an Indesit WD11 front loader washer/dryer. Run into a problem today. Once we start it up as normal, the selector knob keeps on turning. The washer does not spin at all, only the selector knob does. I've tried turning it off, unplugging the machine. But nothing works. Thanks
  • 1 more comment
  • ingaa May 13, 2008
    Mine does the same its driving me crazy!!
  • helenglenn Jul 13, 2008
    Mines doing the same,(Once we start it up as normal, the selector knob keeps on turning. The washer does not spin at all, only the selector knob does. I've tried turning it off, unplugging the machine. )
  • Anonymous May 10, 2009
    my wd11 will wash but does not spin on the final cycle?
  • 139 Answers
SOURCE: washing machine
The knob keeps turning when you have a problem with the machine the most common problem with indesit is the pump. check to see if there is any thing in the filter compartmet located at the bottom on the front of the machine if so clean and replace.. THEN you will have to reset the knob. you do tis by turning the dial to one of the off position (the big black dot ). Then leave the door open and keep switching the machine on and off quickly from the button on the front of the machine untill you c the lights flicker rappidly.. once this happens the machine is reset and ready to wash ... p.s The pump can be one source for a problem... others include brushes on motor.....but most likely it will be the pump tell tell signs are water in the drum
Posted on Nov 21, 2007
  • 1294 Answers
SOURCE: ariston margherita wont drain and selector knob keeps turning
Plug off the wall first. The spin normally does not work when the outlet filter is clogged; be prepared for a flood of water. If the filter is clean you should then check your pipe coming out from under the tub. Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
You can also drain water from the tub thru the rear hose in the wall. Keep bucket handy. The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground. Do not push the pipe too much down the stand pipe.
Posted on Nov 30, 2007
Candyhelp
  • 136 Answers
SOURCE: Hi, I have just moved into
yes make sure your door is closed and locked all the way if theres a lock
Posted on Mar 30, 2008
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
SOURCE: Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
Posted on Sep 24, 2008
My washer test runs great I hear every thing working correctly but when I do laundry it doesn't spin. How can I fix this issue. I am getting an error code f7 e1
I know how frustrating it can be when appliances do not function properly.
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
I am including a document below that will describe how to view the old error codes. Use the section that starts with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
I hope this is helpful. Post back your results.
Click here for image
Nov 12, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Program selector knob continues to turn
COULD BE THE SPLINES ON THE SPINDLE PULL KNOB OF AND SEE IF CRACKED OR THE SPLINDES WORN ON INSIDE OF KNOB .IF OK THE SELECTOR NEEDS REPLACING.
HOPE THIS HELPS
NORMAN
Aug 23, 2011 | Indesit W 123 Front Load Washer
What does it mean when the selector knob on washer keeps on turning when you have a wash in and also it does not spin i have to put it on drain to take clothes out
try selecting wash programme before switching power on to machine, as often with indeset if you move timer while on this will happen
Feb 13, 2010 | Indesit WA 125 Front Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Selector knob on my Indesit Washing Machine WI 121 keeps turning & light flashes twice before light turns off. This happens approx 4 times in a whole turn of the knob. Indesit want £100 to come out to fix!...
Hi.
Sounds like you have faulty control module, which is quite expensive to replace.
Also the E.P.R.O.M would have to be replaced as well.
Probably cheaper to buy new washer.
Good luck.
Nov 18, 2008 | Indesit W 123 Front Load Washer
Washing machine
did you reset the machine after you checked the filter? if not put the selector switch to any of the stop positions the switch on wait till the on/off light flashes rapidly , then switch off and try again.
Aug 16, 2008 | Indesit W 123 Front Load Washer
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Main selector switch
I suggest if you recently purchased the SELECTOR SWITCH , to get an exchange for another one , it could be a manufacture defect .
Apr 11, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
