Question about Saeco Vienna De Luxe Espresso Machine
Trouble with Saeco Vienna Deluxe
Hello, We have had our SVD for less than a year. Everything has been working great until this morning. The red light comes on after dispersing only a small amount of coffee. The catch trays are all in place and water and beans are there. I have tried to run the water through the steam valve and it eventually cuts out there too, with the red light (steady, not blinking) coming on. I can turn off the machine and turn it back on to reset but the same thing happens over again. I have descaled and cleaned the machine, even going so far as to remove as many beans and water as I can to "clear it out" but it doesn't work. Please advise! THanks! L.M.
    Scholar:
  • 70 Answers
Could be the pump gone bad or the flow meter.
Neither is easy to replace. Needs to be brought in for fixing.
Posted on May 22, 2008
On Vienna Deluxe after the beans are ground and ready to drop the espresso shots, nothing comes out and the red light goes on? I shut the unit off for a minute or so, turn it back on and it works ok, but...
Solid red light is a ventilate light.. Try Priming the machine to see if the light goes away.
Something may be in the flow meter. Its the while device between the water tank and the pump of the machine. You would have to open the machine and clean out the flow meter.
Also, if you haven't descaled the machine already, I would start there.
Saeco Espresso Parts Brew Groups Pumps Boilers Water Tanks Drip trays
Mar 07, 2015 | Saeco Vienna De Luxe Espresso Machine
It sounds like you are doing everything right.
From what i have read, a lot of people have had the problem of the red light coming on and staying solid.
When they called to find out what to do they were told to clean out their machines.
I would take the whole machine apart (all of the parts you are supposed to), empty all the beans and all the water. Then try putting it all back together. Remember to prime and see what happens.
Sorry that i can't be more of a help. Others have completely taken the machine apart and emptied all the beans and water, and when they put it back together it worked for them.
If this doesn't work i would phone the company and see if its still covered under the warranty.
Good Luck
Apr 16, 2008 | Saeco Vienna De Luxe Espresso Machine
Machine does not make coffee and make a loud kicking sound
you have a problem with the gears of the mechanism that drives the brew unit. They are 2 in number and change easily if you can open the covers of the machine and remove it.
You can try to make the quantity of ground coffee a bit less . It can fix it for litlle period of time. But the gears must be changed.
Have a nice day
Oct 04, 2017 | Saeco Vienna Deluxe
How do I descale my Saeco Vienna Deluxe?
Purchase the Saeco descaler. Mix solution accordingly. Pour into water tank. Run a cappucino cup full of water through the wand. Wait about 20 minute and repeat. Do this until all the water is gone in the tank. (Don't run all the water at once!). Rinse water tank well. FIll with clean water and run through the wand. I do this twice just to be sure I have gotten all the chemical out.
Aug 15, 2009 | Saeco Vienna De Luxe Espresso Machine
Only half of a cup of coffee dispensed from Saeco Vienna
the trouble is the pipe that goes to the water tank follow it its hook to a white plastic sensor go in that piece and come out that the level sensor that broken that the first thing and most likely broken if not the circuit board
Apr 04, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Vienna Deluxe
http://cerinicoffee.com/Saeco_User_manuals_free.asp
Apr 26, 2008 | Saeco Vienna Deluxe
Saeco Vienna Deluxe odd burning smell
gears are probably broke. Happens when to much coffee and coffee ground too fine get compacted into the brew drive unit.
Shreds the plastic gears like butter.
Machine has to be sent out for service, gear replacement is long and impossible for anyone untrained. Trained techs it takes at least an hour if not more.
Apr 21, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe
ok which red light are you talking about. the water or the beans or the warning
Apr 15, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
210 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
