Question about Dell (Fan Only) M/N AFC0912DE, DC12V, 2.50A, D/N P2780 P2780
Fan I have a dell computer and during start up, the fan runs extremely fast to the point it seems like it is going to explode. My computer won't start because of this happening. I used to be able to try starting it over and over and sometimes after 5 or 10 tries the fan would slow down and the computer would start. But sometmes after a while it would lock up or shut itself down.
  • 5 more comments
  • Mike929963 May 08, 2008
    same problem. fan runs very high all the time
  • Anonymous May 27, 2008
    Same problem with ADC0912DE- Fan sounds like a jet engine.
  • Anonymous Dec 01, 2008
    Hi
    I have the same problem with a Inspiron 530 - how to find out what is wrong in the POST check ?
    Best regard
    Lars
  • holtwood5 Jan 27, 2009
    Same problem - PC is a Dell 8400 P4 3.4ghz with Windows XP professional. Nothing major done to computer...working fine up until now. I did have it running a few times and then it would hang up. I tried disconnecting everything except mouse, monitor and keyboard - still locked up. At this time, it dosen't boot and fan runs at very high speed.
  • Anonymous Feb 16, 2009
    8400 2,8 GHz cpu
    Same problem.
    -Melis-
  • John Timermanis
    John Timermanis Apr 16, 2009
    Hi have the same problem, same DELL 8400 Desktop machine running XP home. The issue only started happening recently (have had the machine for several years now) the CPU cooling fan just started racing (seriously fast) not sure if it will blow or if it is able to run at this speed by design. I found that this seemed to be caused by a bad connection in a plug on the mother board next to the CPU. This has two yellow and two black wires on it. I found two of the pins inside the plug were scorched (brown) and the side of the plug scorched also. Reseating the plug seemed to fix the problem temporarily but after a few restarts, the racing fan would happen again. As of this morning, I cannot get the computer to start normally at all, that is monitor not connecting (green light) and fan running at normal speed. Tried resetting the BIOS but this has not made any difference. I am not sure if the problem is purely related to that plug (with yellow / black wires) being truly unserviceable now. Would like some feedback please. Thanks John Timermanis jt@timermanis.com
  • IQUIT May 11, 2010
    You have it backwards. The fans are racing because the system is not completing the POWER on Self-Test (POST). One of the symptoms of a POST failure is the cooling fans running 100%. Under normal circumstances, they go to 100% then slow after the srlf-test completes.
    The fact that the system eventually completes POST and boots indicates that you may have a heat issue where one component is not making contact until the system board warms up during several starts. Sometimes a slow spin up of the hard drive will have the same symptom.
    Post the model information of your system (Example Dimension 2400, Inspiron 530 etc) and I might be able to give you some more detailed advice.
  • 3,940 Answers
No reply
Can't help without details, sorry
Posted on Jun 11, 2008
Dell laptop runs fast
When my fan runs loud this usually means the heatsink behind the fan is clogged with dust. So your fan is working harder to get the same amount of cooling. Just go buy a can of compressed air belower and spray that clogged dust out of your heatsink
Mar 14, 2013 | Dell Studio Computers & Internet
Dell 370 fan runs loud and won't start
If the fan is failing the most times the computer will not start because it will overheat. There are two fans inside the system, one inside the Power Supply and one that sits on the motherboard.
Remove the Power Cord, Open the case, Remove the cover and with a can of compressed air blow out the dust inside the computer. Clean the dust away from the Fans, Vents, CPU and Heat Sink are that sits under the Fan on the motherboard.
Apr 23, 2012 | Dell Precision 370 (370TREC) PC Desktop
DELL 8400 MAKES A LOUD FAN NOISE AND WONT BOOT
There are 2 basic fans in Dell tower one for the power supply and the other for the Processor. If your computer is not booting then the Processor fan is most likely to be the culprit. What could be happening is that the Processor fan is no longer turning fast enough to cool the processor, so normal the processor when it over heats there is either protection to switch off the computer automatically or the computer won't boot. The best thing is to change the fan and make sure it is working properly but checking on the cables that they won't entangle on top of the fan to impede it's movement. You can easily damage your processor if the fan is not working properly.
Oct 18, 2011 | Dell Dimension 8400 PC Desktop
What's your problem?tower fan is always running off and on
Your computer's Processor/CPU fan is set to run faster when it is hot and slower when it is cool. That is why it get's quiet and loud. A clean may reduce the noise, by removing the dust from the computer system the fans will be able to operate more efficiently and effectively meaning that they won't have to spin as fast.
Install fans in your chassis to provide your computer system with freash air, an exhaust fan is also an idea to push warm air out of the system. Generally the larger the fan the quieter it will be, as a large fan can spin at a slower rate to provide the same airflow of a smaller unit.
Remember that it is that fan over the CPU heatsink that is keeping your computer alive. Overtime they can wear, replacing the fan is an option.
Take care!
damnor01
Oct 06, 2011 | Dell Inspiron 531s Desktop Computer
My computer dell gx 620 desktop fan is running fast and it keeps on restarting and hanging especiall during heavy games and also videos and the fan is running fast
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Aug 30, 2011 | Dell OptiPlex GX620 PC Desktop
Turn on computer power up fan spins fast monitor
Here is some diagnostic information. The Fans running at full speed are an indication of a NO POST failure
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Apr 17, 2010 | Dell Inspiron 530 Desktop Computer
Fan blows high speed and computer wont start
How long havew you had the present motherboard in your computer? if over 3 years (and used on a dayly basies more then likely, your motherboard is in need of replacment because the capasitor/s are leaking (not giving the proper voltage to start and hold your computer at proper levels
Jan 14, 2010 | Dell Optiplex GX280 (99301) Motherboard
I just installed a Hunter five minute fan which says it is called the augusta. I have also installed several other hunter fans in my house through the years, and they seem to move extremely fast especially...
Speed is not a factor in moving air. You can move air with a little fan that runs real fast or you can move the same amount of air with a big fan that moves slow.
It is the pitch of the blades that moves air. Big blades with steep pitch moving slow are comparable to little blades with shallow pitch that move fast.
It seems to me someone is trying to baffel you with bull**** when they tell you CFM = watts or something similar.
The real question is, is the fan moving the air necessary to achieve the result you desire? If yes, speed is not really a factor.
Let me know if this helps you.
a
Sep 22, 2009 | Dryers
My car runs at normal temp even when its extremely
a late opener will make it run cooler as it cools the radiator for longer
Jul 20, 2009 | 2000 Ford Crown Victoria
Dell 5160 intell pentium 4
Inspiron 5160 is probably at least 3 or 4 years old. If it is running slow, (and maybe fan is running all the time and fast) you might need to check if the heat sink/fan assembly is in need of cleaning. You have to remove this assy from the laptop, and remove all the accumulated dust and gunk from the INSIDE of the copper fins. Inside meaning remove the fan from the assembly and with a fine brush, GENTLY remove the gunk from the fins, or with the fan removed, try canned air.
Dec 04, 2008 | Dell Inspiron 5160 Notebook
Computers & Internet Logo
1,169 people viewed this question
Alun Cox
