Question about Gateway 7510GX Notebook
Disassembly I have removed all screws from the bottom of the machine, but it apears to still be held together near the hinge line. can you help me?
  • stuz0r May 16, 2008
    I have a gateway 7510GX I am trying to take it apart to give it a good cleaning. I know how to take apart laptops but this one is .....different. I have it basically apart except the screen is somehow staying on. All screws have been removed. I cannot for the life of me figure out how it is staying together...I can see 4 screw holes that are right under the monitor lid, but it is impossible to get to those unless the screen is taken off, which I can't figure out how to do...(can't see any screws that are keeping it attached..) Could someone show me where the secret button is? :)
    Thanks!
  • devinology Mar 21, 2009
    Yes, i have the same problem. trying to take the whole thing apart to clean it out since you can't get to the fans or heatsinks any other way. the chassis is held together at one end by 4 screws that are right under where the monitor hinges. the monitor needs to come off but there does not seem to be any way to do this. my screen is actually cracked so i am thinking of just forcing it off since i don't really care if it breaks, but this is not really much of a solution. this laptop SUCKS for taking it apart. i never thought of looking at how easily a laptop comes apart as a plus for why i should purchase it, but now i will never buy one that is this difficult. it seems they made it so you just can't take it apart without breaking it. i would love if someone could answer how to do this.
Trust me, do you know how to replace the keyboard of 7510gx?
Posted on Apr 07, 2010
    Scholar:
  • 26 Answers
You didn't explain why you are taking it apart, but the two main reasons are Hard Disk drive Replacement
& memory (RAM) Replacement
The chassis of the computer is built sort of like the frame of a car
so I will detail how to do the two operations below
Hard Disk drive for 7510GX Laptop:
  1. Back up any data you want to transfer to the new hard drive.
  2. Before beginning, review electrostatic discharge (ESD) precautions.
  3. Shut down the computer, and then disconnect the power adapter.
  4. Disconnect the modem and network cables.
  5. Turn the computer over, and then remove the battery.
    1. Slide the battery lock to the unlock position.
    2. Slide the battery release latch.
    3. Lift the battery out of the bay.
  6. Remove the hard drive kit screw.
  7. Slide the hard drive kit out if the computer.
  8. If your new hard drive already includes the hard drive kit bracket, go to step 13. – OR –
Adding or Replacing Memory Modules
  1. Shut down the computer, and then disconnect the power adapter and modem and network cables.
  2. Turn the computer over, and then remove the battery.
  3. Loosen the memory bay cover screw.
  4. Remove the memory bay cover.
  5. To remove a memory module, locate the two clips on each side of a memory module, and then slowly press outward on the two clips at the same until the module tilts upward.
  6. Pull the memory module out disassembly - 350191569.jpgbr /> 350191569.jpg
  7. Hold the new or replacement module at a 30-degree angle and press it into the empty memory slot. This module is keyed so that it can only be inserted in one direction. If the module does not fit, verify that the notch in the module lines up with tdisassembly - 350191572.jpg memory bay.
  8. Gently push down on the SO-DIMM and make sure that the two clips on each siddisassembly - 350191573.jpgdash;DIMM click into place.
    Replace the memory bay cover.
  9. Replace the memory bay cover screw.
If you need to do something further, write back.
I hope that helps :)
TrustMe
Posted on Apr 16, 2008
I have a Simpson Ezy Loader. I need to replace the door hinge which I have purchased but I am unable to get the broken door hinge out of the door as the door wont come apart.
may i ask why are you replacing the hinge? the door is in two halves and held together by a few large screws, once you remove the screws you will need to put a flat blade screw driver in between the two halves of the door and pry it open, theres a heap of tiny clips that hold the two pieces together, it will be quite hard and may make a loud crack when you pop it open, dont worry you wont break anything.
Feb 04, 2017 | Simpson Washing Machines
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
HOW TO CLEAN THE GLASS DOORS
Hello larryjkelly - This may or may not be specifically for you model, however below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side.
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lies onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
I do hope this proves to be helpful.
Feb 25, 2013 | Electrolux ICON Designer E30SO75ESS Oven
Hello, I am looking for the basic instructions for replacing the keyboard unit on a Samsung NP-R720 laptop. I am not a computer novice ! The first computer I owned, I built in 1983, but there can be some...
First, not that the keyboard is held by two long screws (as marked in the picture below), which are to be opened from the bottom.
After removing the battery and bottom screws, you have to remove the top cover (near LCD hinges, above keyboard). After that you would be able to pull the keyboard and remove the connecting ribbon cable to detach it. Below is a video for Laptop keyboard replacement.
Also, have a look at some Similar Laptop Disassemble Guides
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 12, 2011 | Computers & Internet
Remove top
Hello- You will actually need to remove the front in order to access the 2 screws holding down the top. Unplug the machine before doing any disassembly. To remove the front panel there are 2 screws located near the bottom of the panel on each side. They are hidden by the bevel on the panel and located under where the panel angels in about 4" from the bottom. Look under that bevel and you will see the screws. Remove these and pull the bottom of the front panel towards you and up, the panel will hinge from the top and once you get the bottom up high enough it will drop free of the top. To hinge loosen the top there are 2 bolts located under the top where the side of the cabinets meet the front of the top panel. Once these are removed the top hinges up and back. There is a hose, tube, that comes from the bleach dispenser that you need to pull off from the bottom of the dispenser, there is usual no clamp on this at the top (you will see it on the front right side when you pull the front off). Hope this helps, best regards.
Sep 28, 2010 | Maytag LAT3600A Top Load Washer
Replace boot gasket
Hello, Remove the door hinges and plastic covers on the unused hinge screw holes on the opposite side of the door opening (door is reversible, so there are places to mount hinges left and right). Front panel will now snap out at top and lift off lower spring clips. One screw on each side will now release top panel and it will hinge up. Prop up with broom handle or something. Now you can get at everything. Rubber gasket is held onto drum with a cable loop and very strong spring. It rolls off the lip easily to disassemble but is VERY difficult to get back on without special tools or at least two people. Door side of rubber gasket is easy in comparison with rubber tabs inserted into slots and working the gasket into a groove. Hose clamp at bottom of rubber gasket to connect drain hose.
Thanks
Jun 10, 2010 | GE WSXH208A Front Load Washer
I purchased a Lanier 5435 at a garage sale here at work and I need to disassemble it to get it home. A manual would be a big help, or is there an easy way to disassemble it and reassemble it at home?
Hello sir; There have foer part to be separet; 1, auto doccument feeder. 2, machine body , 3 base, 4 finisher. Now let's separet finisher; open the finisher door, on the right hand side first screw lock the cross bar, unscrew it ,pull out cross bar move finisher away, next to remove ADF lift up ADF you can see two big hinge, unscrew it and remove it ,nex to separet body and base;on the back cover of the machine on the lower left have a small cover with one screw on it release open it out you will see the connector, disconnect it, now pull out the second tray there have a screw inside the bottom screw the body and base together, unscrew it next remove the plastic strip between the front door and 1st paper tray, you will see two handle , good luck !!!
Jan 04, 2010 | Lanier Office Equipment & Supplies
Same Problem with dirty glass 1600n
You will have to remove the back and sides first I'm afraid. But do not fear, this Dell is held together with screws unlike HP that snaps together forever. All you need is some guts and a little experience with computer sockets like inside laptops if you need to do complete disassembly. The tricky part was figuring out that the control panel can be pried up and hinges up exposing the three hidden screws that hold down the glass holder cover.
Sep 01, 2009 | Dell 1600n All-In-One Laser Printer
How do i change which side the door opens
I have a different Bosch but changing the door over is straightforward.
1. Remove the plastic cover above the top door which fits over the controls. There are 2 screws under it holding it on. Lever it up from the back on top and it pops off.
2. Remove the hinge for the top door held on by 2 bolts
3. Take the top door off
4. Remove the central hinge between the doors held on by 2 screws
4. Lift the bottom door off
5. Pull off the bottm plastic cover
6. Move the post in the bottom hinge to the other side. It screws out
7 Replace the bottom door
8 Replace the central hinge on the other side (Take off any plastic caps covering the holes)
9. Unscrew the post on the top hinge (there are 2 possible holes left and right) and put it in the other hole.
10. Put the top door on
11. Bolt the top hinge back on the other side
12 Replace top cover and screws.
13 Move handles (unscrew and pull towards the door edge to get them off)
Jul 10, 2009 | Bosch Classixx KSR32623 Refrigerator
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
Gateway 7510GX Notebook Logo
684 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
