VHS VCR Repair
I have a GE Model VG4065 VHS VCR that has a carriage problem,
  • 975 Answers
Can you be more specific so I can better assist you, the more details the better , thanks
Posted on Apr 16, 2008
My sharp VCR wont accept tapes, they pop out when I insert them, help?
This often caused by a faulty carriage assembly. Another cause is a mode switch failure. The mode switch tells the electronics what position the VCR mechanism is in. When it goes faulty it will cause the tape to eject sometimes. However any kind of mechanism damage can cause the mode switch to go into a wrong position.
Aug 05, 2014 | Sharp Televison & Video
VCR remotes
It may not exist---Try to Google the model number with "remote" to see if you can locate one.
Jun 06, 2012 | Televison & Video
I bought the VCR without the remote. I have a universal remote that has been programmed to work with the VCR. However, I can not bring up the record menu. What can I do to record programs without using the...
Sometimes the codes used in the remote are the wrong type for your model VCR. Though functions will work with some codes. It's best to try some of the other codes for GE VCR's and see if that triggers it to life the missing menu.
Jul 27, 2011 | GE VG4256 VHS VCR
Everything works fine, replaced RF tuner, fixed carriage elevator, but whenever the VCR is powered on, it tries to eject whether a cassette is in the device or not. Any thoughts?
Try cleaning the mode switch with Servisol Video 40. When you fixed the carriage also, you did get put it back right, in the correct position, otherwise the VCR will think it's in the wrong mode, even if the mode switch is fine!
Sep 25, 2010 | Goldstar GVR-E445 VHS VCR
Vcr tape does not complete loading cycle-stops about 2/3 complete
Your load motor belt is worn or your load gear lubricant had hardened and needs to be cleaned and relubricated.
I had the same problem with my Emerson VCR.
Mar 10, 2009 | GE VG2050 VHS VCR
Broken Cam Gear
Thanks for model number update.
below is an image of VCR Mechanism used in this unit.
Part number details, exploded view of parts and timing information are available in related service manual which can be obtained from Manual Zone with little fee.
If you are familiar with VCR mechanical repair then it would be easy to fix.
You can check required part availability and price in Part Store.
I hope above info will help you to fix this unit. let me know if you need further info.
Feb 06, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Door jammed open, no power
oN THIS VCR THERE IS 8SCREWS TO REMOVE THE COVER, REMOVE THE COVER CAREFULLY THEN PLUG THE CORD INTO THE WALL, THE CARRIAGE TRAY WILL ACCEPT OR REJECT THE CASSETTE. oNCE THIS PROCESS IS DONE AN THE CASSETTE IS REMOVED UNPLUG THE VCR AND REPLACE THE COVER WITH THE SCREWS
Jan 13, 2009 | Panasonic PV-V4540 VHS VCR
Tape is stuck and I don't know how to get it out.
another way to eject tape is to turn the eject motor by hand in the direction that ejects the tape.
Feb 14, 2008 | GE VG4267 VHS VCR
Tape stuck in VCR
First locate the load and unload motor, it is the one with the rubber drive band. release the drive band and rotate the gear to raise and pull the carriage back into position.
This should remove your cassette, and put the carriage back into position.
Regards,
Eagle
Oct 19, 2007 | JVC HR-J461MS VHS VCR
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
