can't get any thing other than weather even if i know frequencies and am right never them no air port @air port no fire no far from hall work beside cab co. cant even get them unless i m in their building all it seem to do is say found
Sounds to me like the antenna connector is damaged or loose, or the scanners receiver is faulty. If the antenna connector is loose, you could try to reinforce it by soldering the separated wires or ports. If the receiver is faulty, you'll have to get a new scanner.
Hope this helps!
Was this solution helpful? Show your Appreciation by rating it:
