Question about Refrigerators
I just returned from a 5-day trip and found the inside of my GE Profile Arctica (PS123SC) hot and everything spoiled. After emptying everything, I pulled the back lower cover off and found that the compressor is not operating. Is there a reset button or technique to restart the compressor? The fan is blowing cool, not hot or warm air, from the back of the unit.
    Genius:
  • 1,073 Answers
Need to call ge for serviice it could be the compressor or the main control mother board , it also could be the compressor overload but it would be better for eyes on on this one since the parts are quite expensive if it trial by error
if you want to try and have a volt meter that reads ac voltage on 120 through 240 scale ,unplug the unit remove the cover on the compressor where the two wires are going to the compressor, place the meter probes onto the two wires and have someone pulg in the ref if u have 120 volts the compresso is bad, if 0 volts other problem
Posted on Apr 16, 2008
Profile GE PS123Sc about 6-7 yrs old. Freezer side seems fine. Fridge side is too warm, but is cooling (about 40F). Fridge side lights are intermittent and control panel at top is intermittently dark or...
Sounds like a bad motherboard and probley need control board. You can put in self dianoss. Press all the buttons on panel for 5 seconds. This will start the program. It will check all sensors. Come back with codes and I will help you. Wait to hear from you. I hopes this helps. david_gra582
Aug 27, 2011 | GE Profile PSS26NGS Side by Side...
I opened my freezer (arctica) and heard a sizzling sound -- i could see coils behind the grates on the back wall of the freezer that were bright red (like an electric stove coil on high) -- the water was...
I hope you unplugged your unit or tripped the breaker. If they are bright red then you have an electrical short that should have tripped the breaker a long time before they turned red hot.
Jul 15, 2011 | GE Profile Arctica Stainless Steel Top...
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Nov 17, 2009 | GE Profile Arctica 25.4 Cubic Feet...
My freezer (ge artica) temperature goes up to 40%, then cools dow
The main problem with the Artica/Profile is that they have a main control board and a thermostat board inside the fresh food compartment. I have a repair manual and will send you a copy if you want but we are going to have to look at the control boards for burn marks. Let me know if you need me. Thanks, Sea Breeze
Jul 15, 2009 | GE Profile Arctica Stainless Steel Top...
Help! My GE Profile Arctica runs 24 hours a day...sounds like a fan. It stops when either door is opened, then starts as soon as the door closes. The temps on either side are higher than what they are set...
It is normal operation for ARTICA fans to run continuosly except when the door is open. If the door remains open for 3 minutes the fans will run anyway.
The temperature will vary about 6 -8 degrees from the selected temperature. The temperature will increase during a defrost cycle.
I do not believe you have a problem.
Apr 21, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Refrigerator is running too cold - won't stop until 27 degrees
I'm having the same problem. Started several days ago. What's up?
Mar 17, 2009 | GE Refrigerators
Top Freezer Not Cooling...Fan Running...everything thawed :(
Check the thermostat in the refrigerator and make sure it's not accidently turned to the defrost mode
Jan 08, 2009 | GE Profile Arctica Stainless Steel Top...
GE PSC23SGRC SS refrigerator (Arctica) Profile
Main board is out. Replace. Located on rear of unit
Jul 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
201 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
