Question about Yamaha RX-V995 Receiver
RX-V995 5.1 shut down
I hit the power and it goes on for a sec then shuts down
  • strojo Sep 21, 2008
    When I turn on the receiver, it immediately shuts down. No speakers or inputs are connected.
  • Gary
    Gary May 11, 2010
    I checked mine and one speaker had the wires reversed. But I correct that and the problem still persisted. I unplugged everything... no change. Mine is an RX-V992, essentially the "kid brother" to the V995. I saw in another post that there might be an internal fuse issue or a bad relay.
I am not an expert. I had the same problem. In my case, the receiver is too smart when the wires to the speakers were crossed in polarity and thus it would shut it down.
Good Luck.
Posted on Sep 09, 2008
Yamaha RX-V595 receiver won't stay on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
Around 4 second after power up the unit shuts down..
my jvc rx-8010v turns on and after 4 seconds it shuts down.
Jan 05, 2011 | JVC RX-8010V Receiver
Reciever shuts down by itself
Hi, i have similar/same problem, on initial power on, you have after 3 -4 secs an audible click from inside and all is good... if you then try to change inputs either via front panel and or remote, the unit switches off. if you change input prior to audible click, ie within 2-3 secs of power on , all is good and amp works fine, until you change input etc...very painful fault.. i thought it is sensing /checking the speaker outputs and detecting short etc ,so powering off to protect.. but then just my thought, i suspect something else, if anyone has the fix and can repair , please let me know.
Dec 24, 2009 | Yamaha RX-V800 Receiver
My Yamaha RX-V470 Kicks off after a couple of SEC.
Two possible problems , bad memory back up cap or weak voltage regulator.
Jul 10, 2009 | Yamaha RX-V995 Receiver
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
Can't wake up....gone into sleep mode...how do you wake it up
press and hold the power button down for about 5 secs. The computer will shut down. Restart it and right click on the desktop, go to properties then look for screensaver tab , then choose power options, click on hibernation tab at the top and uncheck enable hibernation. Or choose stanby options and choose a longer time before the computer goes to sleep.
Mar 21, 2009 | IBM ThinkPad T23 2647 Notebook
Turns on then shuts down
It sounds like the amplifier protection circuit is kicking in. This usually happens due to a fault in one or both channels. Check that your speaker wires are not shorting out - try removing them and switching on.
Dec 10, 2007 | Yamaha RX-V2090 Receiver
Power shuts off after 2 or 3 sec.
please remove all speaker from receiver-volume down and test if the receiver shut down it needs to fix in service center-if not insert speaker one by one until you find the bad one-change its cable first and then change speaker itself.
Nov 29, 2007 | Marantz SR-5200 Receiver
Immediate shut
Unplug all the speaker wires first, then unplug the unit from the wall for at least 24 hours, The plug back in without the speaker wires or anything else plugged in. Then see if it goes to the protection mode. If it does not, plug in each speaker at a time, and see if any speaker, when hooked up, makes the receiver shut down. If it does shut down, My friend, I'm afraid you will need to take this unit into a repair shop, OR get a new unit. Good Luck
Jun 06, 2007 | Yamaha RX-V630 Receiver
Yamaha Receiver RX-V630 not working (resets itself immediately)
This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
Jun 05, 2007 | Yamaha RX-V630 Receiver
Yamaha RX-V995 Receiver Logo
235 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
