I have a Fujitsu Split air-con system - have power, but the maintenance and timber lights are flashing but unit not working - have cleaned the filters, changed the batteries to remote control unit.
  • legs11 Apr 16, 2008
    What a waste of my time
  • Mick Ferreira
    Mick Ferreira Aug 18, 2008
    FOr some reason the condensation tube that takes the moisture from the coils to the drip pan seems to be clogged resulting in water overflowing the drip pan and leaking onto the wall and floor. I used a shop vac at the drain end to **** the obstruction out to no avail. I removed the covers and can see where the tube connects to the pan but it is inaccesable du to the motor unit for the vanes and other electronics. Will I havee to remove these electronics to get at the opening of the drip tube so that I may be able to root the tube or is there something that closes this tube for any reason that may be reset? In the past I was able to shop vac out some debris that was slowing the drainage of this unit but not this time. I I have to remove the electrical box is there a site that I may be able to get the schematic or a procedure?
I had the same problem with ast24rga-w which I resolved by removing the drain pipe from the outside and the use of compressed air towards the inside this made a bit of a mess on the ceiling which was cleaned with ease
Posted on Feb 11, 2009
  • 236 Answers
Try to disconnect the supply from circuit breaker for 10sec. and "on" again, if it doesn't work you need at qualified technician for that problem.
Posted on Apr 16, 2008
Split System Error
so like a faulty component look up Fujitsu web sight for trouble shooting should have answers on there web sight
Jan 03, 2014 | Fujitsu Heating & Cooling
Air con dead
Larger split system air con gets power from the external unit while smaller air con gets power from the internal unit. Can you find any power switch or power socket/plug around the external or internal units?
Nov 19, 2013 | Cell Phones
Air con not working. Operation and timer lights flashing, then operation light flashes and then lights go off. Air con is blowing air but the outside unit is not blowing any air.
First check your timer on and off. If you want to reset, remove batteries from remote and power off to unit. Reset it. Now run the unit. Set temp mode once again in your remote and wait for 3 minutes. If still out door unit not working, check power line to out door unit.
Dec 31, 2010 | Fujitsu Heating & Cooling
Fijitsu wall mounted split system operation and timer lights are flashing, and the air con is not blowing cold air, only like fan operating even in cool mode.
This the common problem with all a/c holders. Without knowing the function of Timer on and Timer off, if it's pressed the unit will start only at setting time.
Please remove the battery from your remote and reset it. And then with use of your manual, set the timer if you need., otherwise normal function will be activated.
Dec 11, 2010 | Fujitsu Heating & Cooling
Fujitsu split system air con leaking inside the house from the unit
The drain pipe must be plugged up or bent. Lift cover of unit and look for water in the tray, find drain hole and remove obstruccion inserting a piece of wire. Be gentle and careful. After the water in the tray drains out, pour a glass of water in the tray to rinse it out and make sure the drain pipe is completely clear.
While you are at it, clean the air filter of the unit.
Good Luck
Mar 07, 2010 | Electronics - Others
Fujitsu asya09lcc wallmount split lights flashing indoors
According to the service manual page 8, the unit has an 'indoor unit control error'. Below is the link to the manual. Hope this helps.
Jul 04, 2009 | Fujitsu 24R1 Air Conditioner
Will Not Heat
On the outdoor unit the fan should not be running, on the indoor unit the fan should be running. If you then check the outdoor unit with fan not running, you should be able to hear clearly that the compressor is actually working. If this is all correct, it is possible that your fourway reverse valve is seeping and needs to be replaced.
Apr 15, 2009 | Fujitsu 18R1 Air Conditioner
Outside unit not working
you most likely need a service guy to go out and take a look
Mar 15, 2009 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
425 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
