Question about HP OfficeJet 6210 All-In-One InkJet Printer
Lightning broke my fax
I keep my printer plugged onto a surge protector. Somehow lightning has short circuited my fax machine. Every time I plug the machine on, the fax makes an annoying flatline noise. If I just power off the machine, the noise is still going. The only way i can make it go away is to unplug the whole machine. Besides the noise, I can't fax anything. My question is can it be fixed? I don't want to get rid of the machine because the printer, scanner, copier works just fine. Any information is helpful.
Thanks in advance
  • RMoch Jul 13, 2008
    I think the same thing happened to mine - plugged into surge protector - all was fine but the noise that won't stop unless you unplug the printer. I uninstalled the software and unplugged, etc., and it still makes the annoying and loud noise. Think it's a goner as a new one is $120.
    Scholar:
  • 176 Answers
Maybe the power supply of your fax is have a damage parts like capacitor .Because the capacitor stored power even you unplugged turn off the machine still working because of the stored power source it's still working but you need to replace this because it's already leaky and anytime it's going dead and you cannot use your printer anymore. Sent your printer to repair center to fixed the power supply problem.
Posted on Apr 16, 2008
I have a Vizio model E601I-A3, lightning struck outside my house and fried some of my electronics, despite everything being plugged into a surge protector, anyway it's getting power but I have no picture...
Replace the TV as it has been damaged by a power surge and the faults will be recurring.
A home surge protector will do nothing to break the power of lightning.
Oct 26, 2017 | Vizio Televison & Video
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
Dec 08, 2016 | Office Equipment & Supplies
Got hit by lightning and won't turn on. Power source is good. Need to find out how to take it apart.
Most of the time after an appliance has been hit by lightning, it is toast. In the case of a printer you can probably buy a new one for the cost of the replacement part. Next time make sure you also purchase a surge protector to plug your computer and printer into and then you will be protected from lightning strikes.
Sep 29, 2015 | HP Officejet 6700 Premium E-All-In-One...
Is the module of lg tv 32ld330-mb affected when theres a lighting strike???is there a chance to be fix??
The damage from a lightning strike tends to be random. Sometimes it's minor, and only a few parts are affected. Other times, many parts are ruined, or destined to fail soon as a result of the current surge.
If the strike came over the power line, the input surge protectors in the power supply should be replaced, even if they look good. It would be prudent to replace the entire power supply. If you had the set plugged into an external surge protector, that should have taken most of the hit and should also be replaced. (Some surge protector manufacturers will pay up to a certain amount for repair or replacement of equipment plugged into their products if it is damaged by lightning.)
If the lightning came over an unprotected input cable, fixing the set would be a gamble. You could end up changing a lot of modules, beginning with the main board.
Jan 30, 2015 | LG Televison & Video
I would like a replacement router as this one keeps turning its self off up tofour times a dayp tivo
Are you certain that it's the router that's at fault? Is it wireless or wired? What about your wall power?: Does it fluctuate too much?
If wall power is the true culprit, you may find that a UPS ("Unlimited Power Supply") proves quite useful. Basically, a UPS is a sophisticated battery solution--the units incorporate powerful lead-acid batteries--the same type of batteries as those used for starting autos--merely smaller and less powerful.
A surge protector can't bump up power--a UPS may, though--it attempts to "smooth" current--putting less stress upon devices-- perhaps making them last better and longer.
In the event of a power emergency, UPSes may continue to power your TV/TiVo and your router/modem (perhaps located in another room). At least for a few minutes, you may be able to obtain news and weather. Given that your smartphone or tablet is dead, a UPS certainly may keep it alive. (UPSes do "beep" when running on battery power.)
I've noted at stores that your TiVo proves quite expensive. The UPS concept has been invoked widely--practically since the beginning--in business/enterprise, educational, and government computing. Thus, the UPS proves out now as a better home theater solution.
Where your router is, your modem likely is nearby: Plug it into a UPS, as well. Don't get rid of your surge-protector!: Those will remain useful. Certainly, you may plug it into a UPS--if you need more sockets. (Naturally, every such solution has its limits.)
UPS batteries likely will last several years: Generally, DIY replacement proves relatively easy. A great many online vendors service battery customers--replacement batteries at stores now are proving increasingly more available, too. Many differing "brands" often prove compatible.
One fault of a UPS: It's yet another "vampire current" in your home. When you leave your home or sleep, you may switch off the UPS--that ends that current drain. When leaving for vacation, you may then switch it off and unplug it--then, all connected devices are protected from lightning surges while you're away!
Lightning damage proves more common than most Americans believe. Nothing, save perhaps unplugging, can prevent damage from a direct lightning hit. In most circumstances, I do believe that a UPS will protect better then than surge protectors. My brother's TV was damaged by a lightning surge during a crazy weather event--he used a good surge protector, too: My stuff never has been damaged by lightning surges, though. I live nearby.
Needless to say, I've been a big fan of the UPS for a long time!
Jun 04, 2014 | Televison & Video
I have a motororola model MBP8 PU babby montior quick working after power went out they turn on but but don't work
Is it plugged into a surge protector? When the power comes back on to a lot of residents at the same time, a power voltage spike occurs that can damage electronics. All items that have any electronic circuits, need to be protected by a surge protector. Surge protectors do not protect against lightning strikes.
Jun 04, 2014 | Computers & Internet
Lightning struck my Bravia
your tv is shot ,im sorry to say that but its burnt
Jul 29, 2012 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Lightning Strike
Replace with new will need new main board (170 bucks) and modeum board, for best protection it needs a fax filter that protects power line and phone line, standard surge protecter only protects power line
Nov 30, 2007 | Brother MFC 210C All-In-One InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
88 people viewed this question
Ben Johnson
